Chrome Polish
by rrretiree7 - 01/22/20 11:57 PM
2009 Infiniti G37x
by mjk - 01/22/20 10:51 PM
Boy did I have a scare today! Still a little concerned...
by SubieRubyRoo - 01/22/20 10:32 PM
Castrol Edge 0w20
by Mr_Luke - 01/22/20 10:17 PM
Air purifier/vacuum scheme?
by The_Eric - 01/22/20 09:14 PM
Car for short, elderly person?
by BBDartCA - 01/22/20 08:34 PM
Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Jeff1024, EricWestland, Brian200001, Phildrum, 335xiE92FBO
70506 Registered Users
24 registered members (ctechbob, BlueOvalFitter, carlprop, CPA1989, dogememe, cdlamb, 2 invisible), 1,205 guests, and 24 spiders.
Topics300,450
Posts5,176,066
Members70,506
Vortex 6.0 water pump #5293835 12/13/19 08:51 PM
chilson450 Offline OP
I'm working on a high mileage Chevy 2500hd with the 6.0 gas engine. It seems to overheat when it's worked more than just cruising around empty. I was plowing snow a couple weeks ago and it was getting hot in a short time and I was not plowing any different than I ever have. Today I was pulling a trailer with a tractor on it down the highway and it was getting hot and it's pulled this load many times without trouble. This truck has had a new radiator and thermostat in the past couple of years. The fins don't seem blocked. I have also changed the fan clutch before. My question is can water pumps wear out without having a leaking? Can the impeller wear out? This truck has 460,000+ miles in it and it's still the original water pump.
2008 Chevy 2500hd 6.0
2011 Ford Explorer 3.5
Re: Vortex 6.0 water pump [Re: chilson450] #5293878 12/13/19 09:49 PM
clinebarger Offline
Cavitation could have done a number on that pump considering the mileage! You can pull the pump & pop the back cover off it to verify. Early LSx pumps had a bolt-on cover that made visual inspection easier & you could reinstall the pump if found good, Unfortunately that's not an option with the pressed in cover.
If you have a infrared thermometer.....Check for cold spots in the radiator core as your symptoms could point to a partially clogged radiator OR poor water flow!
Was the thermostat OE? I haven't had good luck with aftermarket ones!
2001 Chevy Camaro L92/4L80E
Re: Vortex 6.0 water pump [Re: chilson450] #5293933 12/13/19 11:36 PM
J
JEL01 Offline
J
It certainly sounds plausible assuming the fan clutch is operating per spec. Is it weeping at all?
Either way, impressive mileage, starting to see a lot of older (2000-2005/6-ish) GMTs with the LS based engines popping up with TONS of miles on them, guess they really built them right back in the day
Cars I maintain:
02 Mercedes CLK430
09 Honda Accord V6
13 Lexus RX350 AWD
02 Toyota Tundra 4x4
18 Lexus GX460
Re: Vortex 6.0 water pump [Re: JEL01] #5293942 12/14/19 12:06 AM
dogememe Online Content
Online Content
Yup 290k on mine. I think they are as good or better than the classic small blocks.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Vortex 6.0 water pump [Re: chilson450] #5294161 12/14/19 09:47 AM
G
GoldDot40 Offline
G
First and foremost, have the system pressure leak tested. A cooling system that won't maintain pressure will not function properly.
Equal Opportunity Offender
