Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
126 registered members (2011335d, 928, 1978elcamino, 14 invisible), 4,134 guests, and 20 spiders.
Topics300,353
Posts5,174,003
Members70,491
Dodge Transmission #5291929 12/11/19 09:38 PM
B
Butterbean Offline OP
B
Anyone used tractor fluid rated for wet clutch service in a 93 auto tranny? Any detrimental effects? What has been your experience with it??
Re: Dodge Transmission [Re: Butterbean] #5291962 12/11/19 10:30 PM
clinebarger Offline
Drag racers use it because it's cheap & pressures so are wildly elevated that frictional characteristics aren't really a concern.
I build ALL my competition prepped GM/Hydramatic units for Dexron III, If the customer wants to run hydraulic fluid....More power to him but I'm not liable for it.
Chrysler A500, A618, & 42RH units perform just fine on ATF+4!
2001 Chevy Camaro L92/4L80E
Re: Dodge Transmission [Re: Butterbean] #5292003 12/12/19 12:24 AM
dave1251 Offline
In a daily driver I see no benefit using tractor fluid in a transmission.
don't use.
Re: Dodge Transmission [Re: Butterbean] #5292217 12/12/19 08:37 AM
J
jeepman3071 Offline
J
Don't use that.
Use the spec'ed ATF+4. Even with that they have issues, any fluid that is not ATF+4 seems to cause more problems.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (56k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Dodge Transmission [Re: Butterbean] #5292246 12/12/19 09:28 AM
R
ragtoplvr Offline
R
This transmission has electronically controlled overdrive, so it has to have the correct fluid. There is a torque converter clutch. Use wrong fluid, it will chatter.
Rod
Re: Dodge Transmission [Re: Butterbean] #5292323 12/12/19 11:02 AM
slacktide_bitog Offline
welcome
There is no good reason to do this.
Use Redline C+ ATF. It is the best ATF to use in your Dodge smile
Re: Dodge Transmission [Re: slacktide_bitog] #5292484 12/12/19 01:30 PM
dave1251 Offline
Originally Posted by slacktide_bitog
welcome
No it's not this myth should not be posted. C+ has one one only benefit over ATF +4 is Artic performance.
don't use.
Re: Dodge Transmission [Re: Butterbean] #5292587 12/12/19 03:16 PM
N
nthach Online Content
Online Content
N
Use any ATF+4 fluid in your tranny. You'll cause issues with non-Mopar approved fluids.
