Dodge Transmission
Alabama
Anyone used tractor fluid rated for wet clutch service in a 93 auto tranny? Any detrimental effects? What has been your experience with it??
Drag racers use it because it's cheap & pressures so are wildly elevated that frictional characteristics aren't really a concern.
I build ALL my competition prepped GM/Hydramatic units for Dexron III, If the customer wants to run hydraulic fluid....More power to him but I'm not liable for it.
Chrysler A500, A618, & 42RH units perform just fine on ATF+4!
Don't use that.
Use the spec'ed ATF+4. Even with that they have issues, any fluid that is not ATF+4 seems to cause more problems.
This transmission has electronically controlled overdrive, so it has to have the correct fluid. There is a torque converter clutch. Use wrong fluid, it will chatter.
Rod
There is no good reason to do this.
Use Redline C+ ATF. It is the best ATF to use in your Dodge
No it's not this myth should not be posted. C+ has one one only benefit over ATF +4 is Artic performance.
