17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Tracing wires in walls
by Dave Sherman - 01/22/20 11:32 AM
WM Castrol HM magnatec 6 GALLON BOX $45
by GMguy84 - 01/22/20 11:30 AM
Steering Lubricant Suggestion
by lancerplayer - 01/22/20 11:08 AM
Neglected AW55-50 - Plan Of Attack?
by Bailes1992 - 01/22/20 09:14 AM
BMW caliper pins, no lube?
by ledslinger - 01/22/20 08:58 AM
Glock 44
by bradepb - 01/22/20 08:04 AM
Open up area in basement
by redhat - 01/22/20 07:42 AM
Briggs Intek Leaking Crankshaft Oil Seal
by UncleNorby - 01/22/20 06:26 AM
1ZZ-FE MR-2 (weekends and trackdays)
by geetar - 01/22/20 04:58 AM
Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
Phildrum, 335xiE92FBO, oldrover, sarojasaruu, someoldguy
70503 Registered Users
125 registered members (53' Stude, 32319, 1978elcamino, aircooled, 7 invisible), 2,347 guests, and 20 spiders.
Topics300,434
Posts5,175,674
Members70,503
Page 2 of 4 1 2 3 4
Re: What oil on local shelves has the highest amount of PAO? [Re: sloinker] #5285394 12/04/19 09:28 PM
B
burla Offline
B
Originally Posted by sloinker
Not on your shelf but Valvoline Premium Blue Restore 10W30 meant for diesel engines with carbon issue is more than 90% PAO/POE if I'm not mistaken. I think it may have the highest POE of any engine oil readily available at this time, even more than the boutiques that emphasize their POE content.
is that safe for every day 24/7 use?
Re: What oil on local shelves has the highest amount of PAO? [Re: enochian] #5285396 12/04/19 09:31 PM
B
burla Offline
B
compare pour points of different brands same weight. Most likely look at 0 winter rated oils.
Re: What oil on local shelves has the highest amount of PAO? [Re: burla] #5285478 12/04/19 11:24 PM
sloinker Offline
I wouldn't. They designed this oil specifically to address carbon/ring issues on Cummins OTR diesel engines and it is pricey. I like a dose of ester in my oil and have been using Red Line and Ravenol of late. I have 6 quarts of MPT 10W30 in my garage but am a little worried about poisoning my DPF's in my diesels and catalytic converters in my gasoline vehicles. I am going to use it in my ATV and for my snow blower.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: What oil on local shelves has the highest amount of PAO? [Re: burla] #5285500 12/05/19 12:02 AM
O
Oro_O Offline
O
Yes, absolutely safe and what it's designed for! In fact, it's recommended to run a 25,000 mile drain interval in that commercial diesel engine by Cummings. (They allow a 60K drain interval using the other Valvoline Premium, and up to 80k(!) with oil testing).
There are a number of people who've run it in gas engines and seen carbon coming out, oil usage dropping. It's pricey at $75/gallon. I am thinking I will get two gallons early next year and burn that through my SUV with ring coking issues and see what it does...
Here's some local commentary and visual evidence:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4995896/1
Re: What oil on local shelves has the highest amount of PAO? [Re: enochian] #5285503 12/05/19 12:09 AM
P
paoester Offline
P
The only ones at Walmart in 5 quart jugs that are almost all PAO are Mobil1 Extended Performance 0w20 and Mobil1 Annual Protection 0w20.
Mobil1 AFE 0w20 went to all Group3 or 3+ recently.
Castrol Edge 0w40 is half PAO if memory serves me. Mobil1 0w40 around 1/3 PAO.
Many VW 508 spec 0w20 oils are all or high percentage PAO since that is a higher performance specification for an oil.
The answers are in the Safety Data Sheets, at least approximate ranges.
Not on the shelves, but PAO across their line (blauparts.com sourced) is Ravenol from Germany.
Mobil1 Racing 0w30 is all PAO.
Eneos Racing Street 0w50 is all PAO.
Mostly you can forget PAO as long as the performance standard is high. Just let that be your guide. dexos1 is better than SN, and go to German oil specs for the best performance.
Re: What oil on local shelves has the highest amount of PAO? [Re: Doublehaul] #5285521 12/05/19 01:22 AM
ChrisD46 Offline
* You are here on BITOG and you hate changing oil ?
Originally Posted by Doublehaul
I have a lifetime powertrain warranty and am forced to change my oil and filter every 10k...if I didn’t I’d run AP 5w30 for 20k and be a happy camper doing it
I hate changing oil
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: What oil on local shelves has the highest amount of PAO? [Re: enochian] #5285569 12/05/19 05:30 AM
P
Polyalphaolefin Offline
P
MOTUL 8100 series
Car: KIA Ceed JD 1.4 MPI
OIL: 5w30 ACEA A5 / A3; 5w40 ACEA A3; 0w40 ACEA A3
Re: What oil on local shelves has the highest amount of PAO? [Re: ChrisD46] #5285676 12/05/19 08:02 AM
Doublehaul Offline
I hate changing oil
Yes...exactly. Would I better doing the ole 3 month or 3000 miles “cheap insurance” dance of the un informed.
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: What oil on local shelves has the highest amount of PAO? [Re: enochian] #5285719 12/05/19 08:51 AM
P
painfx Offline
P
Mobil 1 AFE 0W16 has the highest PAO % for over the counter at WalMart.
You didn't state the grade oil.
Re: What oil on local shelves has the highest amount of PAO? [Re: painfx] #5285723 12/05/19 08:55 AM
JohnnyJohnson Offline
I thought PAO was so special you had to get a prescription to buy it.
2004 Corolla 138385
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: What oil on local shelves has the highest amount of PAO? [Re: enochian] #5285725 12/05/19 08:56 AM
B
buster Offline
B
As it stands now:
M1 AP/EP 0w20/16.
Other graded of M1 EP/AP also use a certain amount of PAO.
Castrol 0w40.
Pennzoil makes it pretty clear they use GTL.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: What oil on local shelves has the highest amount of PAO? [Re: enochian] #5285729 12/05/19 08:57 AM
A
ARCOgraphite Offline
A
Just paid 52 bucks mail order for 4 litres!
I let you know if it is Magic or not next week.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: What oil on local shelves has the highest amount of PAO? [Re: enochian] #5285736 12/05/19 09:03 AM
A
A
Uh, where do you live?
Pep boys likely Euro Mobil ESP 0w30
This product has the following builder approvals:
PORSCHEC30
VW504 00
VW507 00
ACEA C3
This product meets or exceeds the requirements of:
Properties and Specifications
Grade SAE 0W-30
Kinematic Viscosity @ 100 C, mm2/s, ASTM D445 12
Kinematic Viscosity @ 40 C, mm2/s, ASTM D445 63
Pour Point, °C, ASTM D97 -51
Flash Point, °C, ASTM D92 230
Density @ 15.6 C, g/ml, ASTM D4052 0.845
Re: What oil on local shelves has the highest amount of PAO? [Re: painfx] #5285739 12/05/19 09:05 AM
T
tundraotto Offline
T
^This 70-80% PAO per the SDS
(The Castrol 0W40 mentioned by buster has only 25%-50% per the SDS)
Re: What oil on local shelves has the highest amount of PAO? [Re: Polyalphaolefin] #5285742 12/05/19 09:06 AM
P
paoester Offline
P
Originally Posted by Polyalphaolefin
MOTUL 8100 series
Wrong. See https://www.quickfds.com/out/18967-57685-02817-012005.pdf
Motul Specific 508 509 0w-20 is all-PAO though. https://www.quickfds.com/out/18967-57826-12259-015155.pdf The VW 508/509 performance spec is so high it causes Motul to use the expensive PAO.
Page 2 of 4 1 2 3 4
