What oil on local shelves has the highest amount of PAO?
* You are here on BITOG and you hate changing oil ?
Originally Posted by Doublehaul
I have a lifetime powertrain warranty and am forced to change my oil and filter every 10k...if I didn't I'd run AP 5w30 for 20k and be a happy camper doing it
I hate changing oil
I hate changing oil
Yes...exactly. Would I better doing the ole 3 month or 3000 miles "cheap insurance" dance of the un informed.
Mobil 1 AFE 0W16 has the highest PAO % for over the counter at WalMart.
You didn't state the grade oil.
I thought PAO was so special you had to get a prescription to buy it.
As it stands now:
M1 AP/EP 0w20/16.
Other graded of M1 EP/AP also use a certain amount of PAO.
Castrol 0w40.
Pennzoil makes it pretty clear they use GTL.
Uh, where do you live?
Pep boys likely Euro Mobil ESP 0w30
This product has the following builder approvals:
PORSCHEC30
VW504 00
VW507 00
ACEA C3
This product meets or exceeds the requirements of:
Properties and Specifications
Grade SAE 0W-30
Kinematic Viscosity @ 100 C, mm2/s, ASTM D445 12
Kinematic Viscosity @ 40 C, mm2/s, ASTM D445 63
Pour Point, °C, ASTM D97 -51
Flash Point, °C, ASTM D92 230
Density @ 15.6 C, g/ml, ASTM D4052 0.845
^This 70-80% PAO per the SDS
(The Castrol 0W40 mentioned by buster has only 25%-50% per the SDS)
How can it be all PAO? Additives require a carrier oil. A 100% PAO oil would have some serious side issues too. That's why manufacturers blend oils to achieve the proper performance and specs.
What serious issue?
What serious issue?
Additive solubility for one. Seal compatibility is another. This is why base oils are blends. You can have a majority PAO base but there will be esters and some of the other groups mixed in.
Base oil makes up 70% to 90% of any fully formulated motor oil.
All-PAO means the base oil is all-PAO only.
High percentage PAO is good enough for any discussions. Yes, there are other chemicals and compounds in motor oil. I guess not everybody knows that, apparently.
It will be Mobil 1
No it won't, because I pulled up their data sheets.
Mobil 1 EP 0w-20 is 70% PAO.
Driven LS30 is on the shelf at Summit Racing and Jegs stores.
It will be Mobil 1
lol. gotta love fellow newmembers comments
It will be Mobil 1
But then again, not all "newmembers" are new members
