Hello, I have a 2008 Honda Odyssey which I know has an aluminum pan and a 2011 Toyota corolla. I am not sure if the toyota pan is steel or aluminum, does anyone know?
What type of washer is recommended to use for each for the oil drain plug? I have seen a washer that is metal along the outside with rubber in the middle, don't know if this is acceptable or if it is better to use a crushed washer on both of the vehicles. Thanks.
