AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1ยข at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
25 registered members (carlprop, FordCapriDriver, Falcon_LS, 2000Trooper, CharlieBauer, AndyB, 2 invisible), 682 guests, and 18 spiders.
Topics297,569
Posts5,118,193
Members69,899
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
What Vehicle and Trailer to Tow Tractor? #5218951 09/21/19 02:40 PM
L
lancerplayer Offline OP
L
I'm looking for a vehicle and a trailer recommendation for a total of 10K.
We have a family tractor that weighs approximately 2,300 lbs with implements. Dimensions are approximately 15' front to back (with FEL and box blade) and 5' side to side. It will need to be transported within a 75 mile radius of a few properties throughout the year.
In terms of the trailer, I was thinking a 7x16 open utility type with flip down gate. Tandem axels, 7,000 GVWR, trailer brakes, trailer weight of around 1,500 lbs.
In terms of the vehicle to tow it, I was thinking a half ton pick up would do the job. However, the thought of an SUV or Van came up too. 4WD/AWD is mandatory.
The issue is that this vehicle and trailer will be used maybe 20 times per year. The vehicle will not be a daily driver.
The used market will be utilized to find the right vehicle and trailer combination that falls within our budget of 10K.
I am open to all options.
Thank you for your time.
Re: What Vehicle and Trailer to Tow Tractor? [Re: lancerplayer] #5218959 09/21/19 02:46 PM
B
bullwinkle Offline
B
If you're thinking SUV, you'll want a 3/4 ton Suburban 2500 or a Ford Excursion. Pretty much any full size pickup should be able to handle it, but you'll need a brake controller on the truck (for trailer over 3000 pounds in Ohio). I personally am a fan of full-floating rear axles for heavy towing, that pretty much means 2500 HD/F-250 or 3500/F-350. An auxiliary transmission cooler, and preferably deep sump transmission pan & temp gauge are also a good idea.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: What Vehicle and Trailer to Tow Tractor? [Re: lancerplayer] #5218973 09/21/19 03:01 PM
dareo Offline
If you could forgo the 4x4 you can get a lot of vehicle in the full size 3/4 or 1 ton van market.
4x4 i would look for a v10 excursion as it will be way cheaper than a diesel and your mileage will be low enough to not care at fuel economy.
2500 suburban would also be good, harder to find.
Certain tahoe yukon half tons may be equipped to tow that much safely. Depends on year and packages, some tow very low and some have high ratings.
Maybe you could a 2008 Toyota Sequoia.
For trailer maybe a standard car hauler would work and be useful for cars too.
2018 Regal TourX, 2016 Golf Wagon 5MT, 2016 GMC 1500 SLT 6.2
Re: What Vehicle and Trailer to Tow Tractor? [Re: lancerplayer] #5219001 09/21/19 03:27 PM
A
Alex_V Offline
A
Any V8 1/2 ton pickup will handle that load easily. Don't be enticed by the prices on '97-up F150's - they have their share of problems.
A good, honest, no-frills '95-99 Chevy K1500 would be at the top of my list. Just take care of the 4L60E.
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: What Vehicle and Trailer to Tow Tractor? [Re: lancerplayer] #5219008 09/21/19 03:30 PM
CKN Offline
I can always tell which of the above posters don't tow anything by their answers. Your requirements are squarely in 3/4 ton truck territory.
Yes-don't reply with 1/2 ton specs. I know what they are and also what real world is.
Re: What Vehicle and Trailer to Tow Tractor? [Re: CKN] #5219013 09/21/19 03:37 PM
A
Alex_V Offline
A
So it takes a truck rated at 10,000 lbs.+ to tow less than 4,000?
Re: What Vehicle and Trailer to Tow Tractor? [Re: CKN] #5219046 09/21/19 04:20 PM
G
gman2304 Offline
G
^this^.....
approved
Re: What Vehicle and Trailer to Tow Tractor? [Re: Alex_V] #5219064 09/21/19 04:49 PM
K
kkreit01 Offline
K
That's what I was thinking. Where does 10k come from? Your total = 3800 lbs. Any V6 1/2 ton truck or the right Ranger/Frontier/Dakota can easily handle that. Was the weight of the tractor a typo?
2017 Jeep Grand Cherokee 4x4 3.6: 0w20 PP/Napa Gold filter
2018 Ram 1500 CC Hemi: 5w20ish QSUD/Napa Platinum filter
2007 Honda Civic Hybrid: ? ?
Re: What Vehicle and Trailer to Tow Tractor? [Re: lancerplayer] #5219065 09/21/19 04:50 PM
Chris142 Offline
Are you sure that the tractor only weighs 2500 lbs? Seems pretty light as my case weighs 3800 with no implement's.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: What Vehicle and Trailer to Tow Tractor? [Re: lancerplayer] #5219075 09/21/19 05:10 PM
M
madRiver Offline
M
You are in narrow spot 4wd/trailer under $10k. I think if you drop RWD options will open more.
Unless trailer is $2500 or less.
Re: What Vehicle and Trailer to Tow Tractor? [Re: lancerplayer] #5219076 09/21/19 05:19 PM
R
Rand Offline
R
I think he meant 10k dollars not 10k pounds.
-- below I'm assuming you have a decent size tractor
Tractor sounds fairly small, my 25hp deere 850 with mower is about 2800.
Trailer sounds light, a decent 7x14 will probably get pretty close to 1800, 7x18-2200lb.
So 6000lb capacity in a vehicle sounds like the minimum. Probably need half ton size truck. or similar.
not sure how familiar you are with towing but a 14ft trailer is pushing it for a large size tractor with implement(s)
you might need an 18ft to get the proper tongue weight for example.
If it was to move it once or twice a year.. you could get away with less.. but considering your use.. I'd get enough capacity to be fully safe in all conditions..
Also your truck needs to have enough beef to panic stop 5000lb..
used trailers are often almost new prices.
Checking chuck's trailer in medina shows around $3000 for a sure-trac 7x14 or 3500 for a 7x18, sure-trac is a giant leap above lowes,tsc,etc carry-on trailers.
Feel free to post more details.. for more detailed suggestions.
Re: What Vehicle and Trailer to Tow Tractor? [Re: lancerplayer] #5219077 09/21/19 05:20 PM
B
BrocLuno Offline
B
I like the tandem axle utility box trailer for light tractors. They work great for other uses.
I'd be looking at an older 1-ton flatbed with duel full floating rear axle. Not for load, but for traction and other uses. Maybe skip the 4x4...
3/4 ton van would be good too. Snow country means enclosed load box is nice in winter laugh
Re: What Vehicle and Trailer to Tow Tractor? [Re: lancerplayer] #5219089 09/21/19 05:38 PM
A
AVB Offline
A
I don't know what kind of tractor work you will be doing, but it sounds like your tractor should fit in a dump trailer. A dump trailer may come in handy if you need to move debris or dirt/rocks or other material.
Re: What Vehicle and Trailer to Tow Tractor? [Re: lancerplayer] #5219117 09/21/19 06:17 PM
E
eljefino Offline
E
If you get a 2wd truck stuck, can you use the tractor to free it? laugh
The value option would be something like a 97 F250 with the old boxy body style and small gas motor. GM and dodge have similar 60's small block tech until a little after the year 2000... old is reliable and cheap, but slow and worse on gas. Same with 4 speed automatics.
I haven't towed a trailer through mud (my presumed reason you require 4x4) and don't know if the 2nd axle would help it float over the mud better or just be another source of drag.
Re: What Vehicle and Trailer to Tow Tractor? [Re: lancerplayer] #5219126 09/21/19 06:28 PM
cpayne5 Offline
You don't need a 3/4 truck to tow 4k pounds, especially if you're not doing it regularly. A half-ton vehicle will certainly suffice!
Personally, I avoid Ford & Dodge in that price range. I'm very comfortable with GMT800s, so I'd probably start there. A first generation Tundra with the 4.7 would also be a good option, but it may push your budget.
I have a truck/trailer combo that would tow your tractor just fine, and I have $4200 in it. The truck is a '99 Silverado 1500. 5.3, 4.10 gears, 4x4. It has 185k miles and typical rust (rockers and cab corners), but you can't see the rust from the driver's seat! The frame is solid, as is the drivetrain. I paid $2700 for it. My trailer is a 16' steel deck, dovetail. I paid $1500 for it. It's an older (late 80s) trailer, but was stored inside by the original owner, who I purchased it from in 2015. I have a Tekonsha P3 to take care of the braking. Again, $4200 in a setup that does exactly what you're looking to do.
Page 1 of 3 1 2 3
