lancerplayer
Originally Posted by kkreit01
Originally Posted by Alex_V
Originally Posted by CKN
I can always tell which of the above posters don't tow anything by their answers. Your requirements are squarely in 3/4 ton truck territory.
Yes-don't reply with 1/2 ton specs. I know what they are and also what real world is.
So it takes a truck rated at 10,000 lbs.+ to tow less than 4,000?
That's what I was thinking. Where does 10k come from? Your total = 3800 lbs. Any V6 1/2 ton truck or the right Ranger/Frontier/Dakota can easily handle that. Was the weight of the tractor a typo?
10k is the total budget to purchase the vehicle and trailer. My bad, I should've posted $10,000 in the original post.
Originally Posted by Chris142
Are you sure that the tractor only weighs 2500 lbs? Seems pretty light as my case weighs 3800 with no implement's.
Tractor is a Kubota B2650 (no cab) and the manufacturer specs it at just under 1,800 lbs. The FEL is about 500 lbs so I guess around 2,300 lbs. Some implements are around 500 lbs so the weight could be around the 2,800 - 3,000 lbs range.
