Originally Posted by bbhero
Originally Posted by billt460
Originally Posted by FordBroncoVWJeta
A lot of stores have gone to the vacuum tube
so they do not screw up drain plugs.
How in God's name do you, "screw up a drain plug"? If someone is so mechanically inept they cannot remove and replace an oil drain plug without damaging it, or the car they took it out of, they have zero business being allowed to touch anyone's vehicle. I don't care who they work for.
So, just to make sure I get this straight..... They have these nit wits supposedly use an extractor, because they don't want to run the "risk" of ruining the drain plug, threads, or oil pan. But yet they have no problem allowing them to remove and install oil filters. That is the dumbest logic I've ever heard of.
Man that a doggone good point billt460...
I have never messed a up a drain plug since beginning in 2017. Only car I ever screwed up was the 2012 Jetta in my sig, long story short first time ever changing oil at 13.
There are probably around 10 times in thousands of oil changes the shop has screwed up a drain plug over thousands of cars. I find the most times people attempt to DIY and when they can't get it they bring it in to have us change it. Especially if they overtightened it last or it has a element filter they hired an ape to put on. They usually end up striping the drain plug or rounding it off, so then we use the vacuum. I know I have confirmed it with customers after I told them to take it to the last shop that did it because they jacked up your plug. Then they respond "My fathers cousins dad's sister's brother did it last." Yet we all knew you did it last as you have grease on your forehead. Some will come out and tell you. But most won't because you can tell they are embarrassed and they are trying to take the cheap way out.
Also we are talking about Walmart as a whole here. There a LOT of techs that shouldn't be techs. They come and go at my store, but they are usually weeded out after cars start to come back on them. Walmart some times doesn't hire quality.
It's hard to screw up a filter. Filter problems are known before they leave the shop.
Originally Posted by 4WD
Well, perhaps they stopped short and did not measure what was removed … but bet that many Mercedes Benz engines have had oil changed from the top.
On our vacuum you can't tell how much it has sucked out. You just know that its done because there is no pressure and you can't see any moving through the hose. It's very easy to misuse it if you don't know exactly what you are doing.
Sunday we seem to always have a car come in because its leaking oil and the place that did it Saturday is closed for the day. One that really sticks out in my head is a lady came in on a Saturday and wanted an oil change on a newer VW with the 1.8T, which is a cartridge engine. I play both tech and service writer so I see it all. Anyways I told her it would be around $80 before tax since its requires an off the shelf VW 502 oil and a specialty filter we don't carry in the shop. She walked and got it down at a smaller regional chain in town that's home to Kansas and Colorado. Well she came back Sunday and talked to me because it was leaking oil profusely. From the drain plug. She was also leaving town. I told her the standard line I tell everyone in this situation. "We are not a mechanic shop and we can't diagnose things. If I was to bring your car into the shop, you could come back and say it wasn't leaking before hand. Then I would get in trouble, and we also don't do it. We would take a look and see if we screwed up, if we did it. But we didn't do it in this case". She was mad at me
I tried to explain everything I can. from my POV. You might not agree with it but its just how I have seen things play out of the last couple years. Hopefully I get my degree this semester and not have to work at Walmart anymore. I'm not trying to defend Walmart but they have worked with me, paid me quite fairly, and let me bounce around as much as I want. I can almost guarantee that the Walmart TLE I work for is probably top 10% in the nation. We have a lot of smart people that I have worked with that know quite a bit, and the reason they switched to Walmart is because they are treated more fairly and compensated better than a lot of shops, even some dealerships. Some of you probably remember me talking about the VW dealership I worked at in May and told me to run. Well Walmart was right there and they took me back.
Also I tried to proofread and fix as much as I can, it is 6AM and I can't sleep, so excuse my poor wording and grammar.
