STP oil filter
by Stinky123 - 02/18/20 04:41 PM
How is this possible
by V10 - 02/18/20 04:07 PM
Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
PH10060 oversized?
by bullwinkle - 02/18/20 11:36 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
spbonus, mtnwzrd11, TnTA2, TimN3QE, musclecarscott
70742 Registered Users
109 registered members (ammolab, 01VFR, 2002 Maxima SE, andyd, 14Accent, 53' Stude, 19 invisible), 2,270 guests, and 16 spiders.
Topics301,621
Posts5,199,228
Members70,742
Page 3 of 7 1 2 3 4 7
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: antonmnster] #5188513 08/16/19 06:39 AM
B
BMWTurboDzl Offline
B
Originally Posted by Skippy722
Originally Posted by antonmnster
So much ignorance and fear of anything new. My n54 has 210,000 miles on it, original chains and turbos, and I'd be totally fine if the chains were on the back. I've had BMWs for 20 years, and had only one chain tensioner go weak on my 318is from 1991. The rest have been perfect for 250k+. I just drove to Detroit and back and loved the performance and relative efficiency, even running 5-40 Delo.
This engine looks like a simplified version of my n54 in some respects. The lack of driver engagement of modern BMWs is worthy of a lot of criticism, but not the engines.
Anything other than penalty boxes... I mean econoboxes... I mean boring appliances... er, frugal, reliable vehicles are automatically disregarded for being too expensive or referred to as “unreliable” with absolutely no real world experience. It is IMPOSSIBLE to drive a BMW 200k with no issues! wink
Any BMW can go 200k miles. It's just a matter of having the will and the $$. It's a question of durability. For example early electronic water pumps on the N54 would routinely fail just north of 50k miles. That's unacceptable to a Lexus owner who has 150k miles on his/her original water pump.
Well if you had the N20-N26 or N47 diesel you might have a different opinion about BMW and timing chains.
435i
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: Skippy722] #5188516 08/16/19 06:40 AM
J
jeepman3071 Offline
J
Yup.
I drove mine on a 2600 mile road trip and hammered the crap out of it. I drove through the smoky mountains, the blue ridge parkway, down mountain dirt roads, did tail of the dragon, and it didn't miss a beat. All while carrying plenty of gear for two people.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (58k) - Liqui Moly 5w40, MANN HU816X
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: BMWTurboDzl] #5188518 08/16/19 06:42 AM
J
jeepman3071 Offline
J
So would owners of the 3.5 V6 in many newer Fords.
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: andyd] #5188520 08/16/19 06:46 AM
J
jeepman3071 Offline
J
Originally Posted by andyd
School me please. What, pray tell, is the rationale behind a rear timing chain/belt? In the factory, the cabins are dropped onto the drive train The right way to take out an engine is on the sub-frame from underneath and then split off the engine or trans to service. KA- Ching!! and difficult to bodge behind the shop. The main reason I don't have a late model Ranger 4x4 is a rear cam drive 4.0L Take a good reliable little gas hog capable of 300K with little service and turn it into a grenade at 150K miles . A century of development going into push rod V engines. Then these OHC horror shows. What is the impetus to do this for Ford or BMW or any car maker? coffee
Wait, so you didn't own a Ranger with the 4.0 SOHC V6 because basically two years of production might have had an issue with the timing chain which was solved after 2001? ??? My friend owned a 2001 which was one of the "problem" years and it went to 200k with zero issues before he sold it.
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: jeepman3071] #5188619 08/16/19 08:43 AM
E
edyvw Offline
E
Toyota 2GR-FE had tensioner issues in first years too.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: BMWTurboDzl] #5188814 08/16/19 12:46 PM
Skippy722 Offline
Sounds like the 5.7 HEMI water pumps. I’d still take replacing water pumps every 50k over a Lexus though.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: jeepman3071] #5189020 08/16/19 05:01 PM
M
MCompact Offline
M
As I've said many times before, if your idea of the pinnacle of automotive excellence is an anodyne travel pod that can go 300k miles with minimal maintenance, than a BMW is not for you. As for me, the enjoyment I've derived from the BMWs I've owned since 1983 vastly outweigh the additional expense of maintaining them.
Yup.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: Bjornviken] #5189087 08/16/19 07:00 PM
M
madRiver Offline
M
Originally Posted by Bjornviken
looks like a solid engine
Looked not looks.....
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: MCompact] #5189090 08/16/19 07:02 PM
M
madRiver Offline
M
Yup.
These clowns just reduced the car to about 30k with problems once they put that back in.
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: madRiver] #5189123 08/16/19 08:05 PM
Skippy722 Offline
Ah yes... long term reliability is at the top of my list in a custom built 1,000hp vehicle. smirk2
Or, maybe it takes 1,000hp with no major problems. You have no idea.
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: MCompact] #5189189 08/16/19 09:31 PM
P
Pew Offline
P
As much as I dislike driving BMWs after being a porter for them, I must say, the M235i is pretty fun to drive. I'm just glad it's my friend's car and not mine lol.
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: madRiver] #5189441 08/17/19 08:43 AM
rooflessVW Offline
Originally Posted by atikovi
Originally Posted by edyvw
I am not big fan of chain in the back. So far it proved stout in since 2016.
That's probably what they said of Audi's S4.
The difference between the two designs is staggering; the only thing they have in common is where the chain is physically located.
No, looks. It looks like a beast of a motor that will handle big power - as he said in the video.
"Clowns" Not the word I'd use to describe the builder in the video. It's a word that suits several of the posters here though.
"Zed's dead baby, Zed's dead."
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: E365] #5193357 08/21/19 08:11 PM
G
Garak Offline
G
My position on this vehicle has mellowed a bit, considering that the pricing is significantly less than I expected.
Plain, simple Garak.
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: E365] #5193459 08/21/19 10:57 PM
Y
Y_K Offline
Y
How many M Series vehicles do they sell now?
Re: BMW (Toyota Supra) B58 Engine Teardown Video [Re: E365] #5193527 08/22/19 02:24 AM
M
mehullica Offline
M
This thread is going nowhere fast
