What's the inside of your engine look like?!
Can't believe that there isn't a thread showing what a engine looks like after using Brand X oil being how passionate everyone is on this website about motor oil ...
If you got pictures of a valve cover off, or maybe a engine being torn down, let's see those internals and how they look!
When I had the driver's valve cover off a few months ago at around 45k miles. There was a leaking spark plug tube seal and a new valve cover with all the seals pre-installed was a couple dollars more than just the gaskets.
O it has lived on Motorcraft 5W50 and FL-500S filters. changed every 5K miles its whole life.
back in the day 70's i hung around a friends auto parts + engine rebuilding shop + would strip engines for cleaning + rebuilds. took one small block chevy apart + filled a pound coffee can with sludge, no info on servicing or not but i asked the owner if he used pennzoil + he said yes!! on the other hand i stripped my oil drinking 307 chevy at 75 thou + it was spotless internally on valvoline conventional 10-30 of the 70's, i prolly did changes at 3 thou with mostly local + short trips,
GM 2.4l, Ecotec, with GDI, 89K miles, on quick lube oil changes and following the bogus Oil Life Monitor. This was taken during a timing chain replacement. Thankful it only slipped a few teeth and did not destroy the pistons and valves.
Originally Posted by Mad_Hatter
Wow, this is like engine porn!🤣
That's what this thread is about as I'm unaware of any other thread that has been created for this specific reason.
My son drives a 2009 328i. The car has been run on BMW TPT 5W-30 or BMW TPT 0W-30 since new- with a minimum OCI of 15,000 miles/12 months; here's what it looked like at 108,000 miles:
[Linked Image]
318 in my D150. Unknown millage since the ode stopped working over a decade ago. 150? 175?
Over the years mostly Exxon Superflo, VWB, or QSGB.
I took the valve covers off to change the cooked valve seals. Its had a few overheat events in it's lifetime
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Why do I sense a lot of Castrol use?
Originally Posted by Bailes1992
I agree that a sticky thread for people to post their internals pictures would be awesome!
ðŸ‘
* I'm about ready for a cigarette now and I don't even smoke ! ... A couple of these pictures will become my new screen saver (lol !)
