Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 08/23/19 11:32 PM
Castrol 5W50
by Snagglefoot - 08/23/19 11:29 PM
Camry Broke Down
by Nick1994 - 08/23/19 10:51 PM
Pumpkin Beer
by Capt - 08/23/19 09:26 PM
Possible bad Iridium plug
by Eric Smith - 08/23/19 08:57 PM
Is the 5.7gm engine still made brand new?
by motor_oil_madman - 08/23/19 08:19 PM
Motomaster OEPlus MOPH/MOCH Filters
by gamefoo21 - 08/23/19 07:29 PM
Man's best friend!
by Mad_Hatter - 08/23/19 06:53 PM
2007 Ford Fusion Cam Pics
by tig1 - 08/23/19 05:31 PM
Cloning a Lexus key
by Nayov - 08/23/19 04:23 PM
2011 GMC Acadia Shock/Strut Replacement
by panthermike - 08/23/19 03:49 PM
Confusion on oil to use on BMW 328i 2010
by goldenjava - 08/23/19 03:21 PM
ProSelect 27356 cut open
by Sayjac - 08/23/19 03:04 PM
Electrolux - Dryer reliability warning.
by pezzy669 - 08/23/19 02:37 PM
Microfiber Towels for different applications?
by Quattro Pete - 08/23/19 01:53 PM
Coated vs. painted rotors
by atikovi - 08/23/19 01:13 PM
New spark plugs, occasional misfire
by avacado11 - 08/23/19 12:34 PM
Boogyman, GeoffPD, CabanaBanana, tblack, goldenjava
69048 Registered Users
20 registered members (Duke, Duffyjr, GMguy84, ctechbob, 4WD, Deontologist, 4 invisible), 538 guests, and 18 spiders.
Topics293,713
Posts5,045,461
Members69,048
Most Online3,532
Jul 30th, 2019
8 Year Review 2007 MDX #5109396 05/19/19 03:18 PM
M
madRiver Offline OP
M
I purchased my 2007 Acura MDX Technology (Nav/Fancy Audio system) from a dealer who did every service according to CarFax back in 2011 with 84k miles for $19.5k. The leather interior was a not taken care of (dog)/hard owner and had body work. In my 8 year ownership it does not look that much worse smile.
Fast forward to now with 195,000 miles. It still has plenty of power (300HP) and nice VTEC growl from its 3.7 V6. Everything works except BlueTooth module (horrid sound quality anyway). Remains comfortable albeit a bit noisy with wind leaks.
Reliability:
Issues fixed by indy Subie Mechanic:
$80 exhaust fix due to bolts breaking (loud)
$100 serpentine tensioner
$200 speed sensor
$10 AC Relay
$500 Alternator replacement (DENSO part)
$100 Xenon bulb replacement
~$200 estimated Transmission light on for failed sensor(code in NAV!)
The only expensive maintenance was $600 timing belt change at dealer who I bargained with on a terrible winter storm day they should have closed and techs were hungry. I have changed oil every 6months with conventional random (3k-8k). Does not burn oil.
The body work came back to haunt me. The car is severely rusting along rear fender due to amateur pinch weld work and apparently did not rust proof the interior of replaced Acura door panel so eating inside out. The vehicle was also parked on the Ocean for first 4 years of life outside and appeared to likely launch a boat(very rusty around hitch). A receipt from PO showed I googled and found the vehicle on google maps. The rust is so severe I don't know if it will pass inspection in 2 years.
The biggest con of vehicle to is the fuel economy. 18MPG average with premium is pretty abysmal. The biggest pro's have been wonderful all around vehicle and it gives "Honda" level reliability. Also the SH-AWD is quite impressive and this is coming from a Subaru owner. Its also very inexpensive to maintain. $50 drain/fill's every 60k it seems.
Re: 8 Year Review 2007 MDX [Re: madRiver] #5109411 05/19/19 04:02 PM
M
mclasser Offline
M
Thanks for the review. Does your 3.7 use oil?
Got any pics?
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: 8 Year Review 2007 MDX [Re: madRiver] #5109416 05/19/19 04:06 PM
M
MCompact Offline
M
I have several friends who own Acuras; they all love them- haven't heard any complaints.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: 8 Year Review 2007 MDX [Re: madRiver] #5109521 05/19/19 06:54 PM
Snagglefoot Offline
Thanks for the well written review. I was just noticing an older MDX yesterday.
If you want the job done right......do it yourself.
Re: 8 Year Review 2007 MDX [Re: madRiver] #5109555 05/19/19 07:33 PM
cos Offline
madRiver,
Brake calipers, rubber brake lines, water pump, fuel pump, wheel bearings and shocks/struts are original?
'15 Cadillac SRX
- Castrol Magnatec 5W30
Re: 8 Year Review 2007 MDX [Re: mclasser] #5109557 05/19/19 07:35 PM
M
madRiver Offline OP
M
Got any pics?
No significant oil consumption except occasional 1/2 qt at in 5k miles. My brothers similar generation 2011 drinks oil. (1qt per 800 miles).
Re: 8 Year Review 2007 MDX [Re: madRiver] #5109560 05/19/19 07:37 PM
cos Offline
Your mpg sounds about right -
'15 Cadillac SRX
Re: 8 Year Review 2007 MDX [Re: madRiver] #5109757 05/20/19 12:56 AM
The Critic Offline
No spark plugs or valve adjustment?
2011 Toyota Prius 1.8L - 195K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 138K - Mobil 1 EP HM 5W-30
Re: 8 Year Review 2007 MDX [Re: cos] #5109846 05/20/19 06:20 AM
M
madRiver Offline OP
M
The plugs were replaced by Prior Owner for some reason at 84k so never bothered. Valve's never inspected.
Originally Posted by cos
madRiver,
All original. A low tech honest repair/tire place did end up pulling a caliper off and cleaning/lubing the heck out as it was dragging at 100k. They wanted to replace but could not get the part quickly enough. it A tie rod was replaced and it needs a $100 sway bar link replaced but not that loud.
I used OLM for SH AWD fluid replacement (1-2 times? at $50/each). The transmission fluid replacement I think twice was around $70. I likely should have replaced brake fluid but indy mechanic said it was okay according to his old school tests. My indy($65/hr labor) likes to repair over replace, even attempted to fix my alternator.
Re: 8 Year Review 2007 MDX [Re: madRiver] #5111379 05/21/19 02:22 PM
H
HangFire Offline
H
My used 05 Pilot was a great experience from 98K on, so at 212K I had another timing belt put on it, water pump, plugs, and the valves adjusted ( all exhausts were tight and would have burned soon). Unfortunately at 214K the transmission was done and I sold it for less than that service cost. Still it was one of the cheapest vehicles I ever owned in terms of repairs and maintenance (not gas!)
I've heard so much bad about the 3.7L, but no personal experience. 300HP sounds like fun. The 255HP 3.5L in the 05 was no slouch.
No offense, but at this point you need to decide when to get out.
Various musings: http://hangfire.net
Re: 8 Year Review 2007 MDX [Re: HangFire] #5111400 05/21/19 02:40 PM
The Critic Offline
Why did you decide against installing another transmission?
Re: 8 Year Review 2007 MDX [Re: The Critic] #5112783 05/22/19 07:47 PM
H
HangFire Offline
H
Thought hard about it. I don't have the time for all the suspension work I know is coming, and I don't want to pay someone else to do it. The wife wants something new, and I needed more MPG for my commute. I am getting 27MPG from the V6 Camry I just got, and the Pilot got 17. It was the right call.
Re: 8 Year Review 2007 MDX [Re: madRiver] #5114313 05/24/19 08:29 AM
G
gofast182 Offline
G
We recently traded our 2011 MDX Tech on a new 2019 X5. The MDX was a great car for us. It was about as reliable as it could be, SH-AWD is a great system that made the car fun to drive both in deep snow and on dry roads, it hauled more plants home from the nursery and junk to the dump than I can count, and toward the end even over 100k miles it was towing my trailer with my S2000 on it. In the last year or so it was starting to use oil, the trans would slip a little bit when it was cold, and there was some sort of jiggle in the front suspension I never could figure out so we decided to move on before something expensive failed knowing that I'd continue to tow with it. MPG was never a strong suit, we'd get 21 on the highway and 17-18 around town (11 when towing). Overall the MDX was such a good car to us.
2006 S2000 - Berlina Black - PU 10w30, PCX-004
2017 340i xDrive - Black Sapphire - Dlr Fill, 114...898
2019 X5 xDrive 40i - Mineral White - Dlr Fill, 114...898
Re: 8 Year Review 2007 MDX [Re: gofast182] #5116992 05/27/19 07:23 AM
M
madRiver Offline OP
M
My brothers 2011 MDX with 115k is getting evaluated by Acura on three consumption tested over 1000 miles (dealer checks/documents). So far dipstick was needing 1 qt plus on first two tests. He is likely slated for major engine work on Acura's goodwill program.
Re: 8 Year Review 2007 MDX [Re: madRiver] #5117837 05/28/19 05:55 AM
G
gofast182 Offline
G
^ yep we were headed down that road, too. Ironically, the letter for Acura's extended warranty on the engine arrived literally minutes after we got home from ordering the new X5.
