ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
Wear Metal Max?
by tsm750. 07/16/19 05:54 PM
Harbor Freight 25% off Thurs - Sunday
by JC1. 07/16/19 05:52 PM
80% Furnace exhaust silencer?
by PandaBear. 07/16/19 05:10 PM
Pennzoil Ultra on Sale
by Nyati. 07/16/19 04:39 PM
Not All Mid-Grade Blended At the Pump
by RayCJ. 07/16/19 04:30 PM
Determining if car battery has much life left
by paulri. 07/16/19 02:47 PM
kohker oil recomendation
by 1978elcamino. 07/16/19 02:44 PM
Rear Diff Seal Leak?
by Pike51. 07/16/19 02:31 PM
Using synthetic to clean a crankcase
by NavyVet88. 07/16/19 02:26 PM
Next Project: 1968 Cub Cadet Model 72
by Phishin. 07/16/19 02:14 PM
Mother's CMX
by rooflessVW. 07/16/19 01:54 PM
MBhuntington, captainfloss, Lyndol, Belczek, Bronco628
68681 Registered Users
128 registered members (2010Civic, 4WD, 2009Edge, aba4430, 14Accent, 13 invisible), 2,197 guests, and 21 spiders.
Topics291,966
Posts5,014,167
Members68,681
Most Online2,967
Mar 10th, 2019
Tie rod tapers #5048880
03/20/19 11:26 AM
03/20/19 11:26 AM
Hudson, NH
LeakySeals Offline OP
Hudson, NH
I'm wondering about the tapers for tie rods, idler arm, etc. Do I use anti seize or is that a bad thing to do with tapers. Can I leave the blaster or should it be dry? Will any kind of lubrication do more harm than good on a taper?
06 Escalade 6.0L LQ9 AWD 167k M1 0w40
03 Maxima 3.5L POS 170k ST HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
Re: Tie rod tapers [Re: LeakySeals] #5048881
03/20/19 11:28 AM
03/20/19 11:28 AM
RI
mattd Online content
mattd  Online Content
RI
Clean and BONE dry. ZERO any type of lube on joint tapers!!
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Tie rod tapers [Re: LeakySeals] #5048901
03/20/19 11:48 AM
03/20/19 11:48 AM
Apple Valley, California
Chris142 Online content
Chris142  Online Content
x2 no lube. Its a friction assembly.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Tie rod tapers [Re: LeakySeals] #5048908
03/20/19 11:51 AM
03/20/19 11:51 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Yes, whatever minimal anti-rust coating they ship with is all they need.
Re: Tie rod tapers [Re: LeakySeals] #5048911
03/20/19 11:53 AM
03/20/19 11:53 AM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
I have used grease and antiseize before but you can easily run into issues when trying to torque them as they will just spin.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
Re: Tie rod tapers [Re: LeakySeals] #5048937
03/20/19 12:17 PM
03/20/19 12:17 PM
High Tax Illinois
oldhp Offline
oldhp  Offline
High Tax Illinois
Dry, no lube at all. One more thing, make sure everything is clean, no dirt, sand etc so it's 100% metal to metal.
2018 RAM 1500 3.6/8 speed.
2019 Dodge Charger SXT 3.6/8 speed.
"When others cut you down, remember where they came from."
"I don't run...........I just wait."
Re: Tie rod tapers [Re: LeakySeals] #5048941
03/20/19 12:26 PM
03/20/19 12:26 PM
Hawaii, USA
anndel Offline
anndel  Offline
Hawaii, USA
Don't put anything. Just make sure it and the holder is clean and dry.
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - M1 EP 10W-30, Fram UG Filter
2005 Toyota Avalon XL, 3.5L V6, Amsoil XL 5W-30, Amsoil Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
Re: Tie rod tapers [Re: LeakySeals] #5048972
03/20/19 12:54 PM
03/20/19 12:54 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
Torque it dry and torque it TO SPEC. Too loose and you'll bugger the thing during use, too tight and best case you can mess up the female taper, have a rough time getting it off next time, or worst case: crack whatever that secures to
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Tie rod tapers [Re: LeakySeals] #5049027
03/20/19 01:36 PM
03/20/19 01:36 PM
VW Fanboy Island
maxdustington Online content
maxdustington  Online Content
VW Fanboy Island
I think I'd let it rust so I had a better chance of getting the nut off next time.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Tie rod tapers [Re: SnowDrifter] #5049044
03/20/19 01:54 PM
03/20/19 01:54 PM
Hudson, NH
Hudson, NH
40 ft lbs it is.. I could not get the pitman arm off the center link. Brand new. But I didn't do it so who knows how they put it on
Re: Tie rod tapers [Re: LeakySeals] #5049046
03/20/19 01:57 PM
03/20/19 01:57 PM
Hudson, NH
Hudson, NH
The mistake I was about to make was I used quite a bit of PB Blaster to get them separated. But I didn't plan on cleaning that off. I just sprayed them down real good with brake cleaner.
Re: Tie rod tapers [Re: LeakySeals] #5049145
03/20/19 04:05 PM
03/20/19 04:05 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
Rust is an issue here. I always butter them with antiseize. I don't see a downside to it.
Re: Tie rod tapers [Re: Kestas] #5049150
03/20/19 04:11 PM
03/20/19 04:11 PM
RI
RI
You don’t see an issue? The point of a tapered assembly is friction fit. You add a lubricant or anti seize then you are defeating the purpose of the assembly. If/when the joint spins in the taper while going down the road it will wear the taper out quickly and you’ll end up with sloppy steering and make the repair you made previously twice as expensive
With that mentality you might as well put brake grease on the face of the brake rotors when doing a brake job.
ASE Master, L1
Re: Tie rod tapers [Re: LeakySeals] #5049177
03/20/19 04:59 PM
03/20/19 04:59 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I have never seen evidence of tapers with antiseize rotating in use. And I have revisited tie rods that needed replacing again, so I'm sure I would have seen any problems. There is enough friction in a properly torqued assembly to preclude movement, similar to lubricated lug nuts.
But I have had a devil of a time getting tapers loose because of corrosion.
Re: Tie rod tapers [Re: LeakySeals] #5049215
03/20/19 05:54 PM
03/20/19 05:54 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
All sorts of ball joints on a 528e front end.. Getting the nut off was the easy part. Pressure and shock properly applied pops them out of the taper.. I used big washers to pull taper together tightly enough to get a good tight on the nuts.
Thick oil is better grin2
