I'm replacing the entire suspension on my 2012 Nissan Maxima SV. I can get all these OEM parts from Nissan for @ $800-$900. Are there better parts out there with different brand name I should consider such as Sachs, Moog, Mevotech, etc etc. Moog has all this stuff but as I understand, Moog quality has significantly gone down hill when reading numerous blogs. I can replace Strut Assembly & Shock with Sachs for cheaper. What about Control Arms, Tie Rods, End links etc etc? Anything better or should I just stick with OEM.
2x Complete Rear Shock Absorbers
1x Front Complete Strut & Spring Assembly (Driver)
1x Front Complete Strut & Spring Assembly (Passenger)
1x Front Stabilizer / Sway Bar End Link (Passenger)
1x Front Stabilizer / Sway Bar End Link (Driver)
1x Rear Stabilizer / Sway Bar End Link (Passenger)
1x Rear Stabilizer / Sway Bar End Link (Driver)
1x Front Lower Control Arm w/Ball Joint (Passenger)
1x Front Lower Control Arm w/Ball Joint (Driver)
2x Front Inner Tie Rod End Links
1x Front Driver Side Outer Tie Rod End
1x Front Passenger Side Outer Tie Rod End
