Originally Posted by ZeeOSix
Originally Posted by webfors
Originally Posted by Patman
Originally Posted by Snagglefoot
The 12060 has been released but instead of being the size of a 10575 which is just over 4 inches long it is the size of a 10060.This is from the Fram site. It's only 3.3 inches long.
We knew it was going to be the same size as the 10060 all along though, as it's that same filter just with a 22psi bypass. It's meant to be a cross reference to the PF64, which is 3.3 inches long.
Since the 10575 is the GM/ATS V6 filter, you would think a 22psi version of that filter would be on the way too.
It is ...
https://www.bobistheoilguy.com/foru...alve-pressure-on-the-xg10575#Post5034093
Excellent! The 10575 with a 22psi bypass would be the perfect filter on the ATS.
Downside, without any markings on the box, I have no way to determine if it's the new or old filter. Fram should have put some indicator on the box, even if only for us nerds that would have to look closely.
