Show me this is the fault of a 20wt oil with a lower HTHS here and that a 40wt with higher HTHS would have solved this problem that's why I brought it up.
Of course fuel dilution in an engine is not a good thing but Honda wasn't pushing for owners to come in for 40wt oils for higher HTHS values in the meantime or as part of the solution to this problem.
Also it wasn't a ton of "complete engine failures" it was some engine failures and this was mainly because they were at some crazy fuel dilution number not the typical 2% or less we see in 20wt lower HTHS oil samples but enough fuel in the oil to raise the dipstick reading which wouldn't be acceptable for any engine.
