Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
35 registered members (berlyn, BobFout, billt460, AurionX2, Astro14, 4WD, 5 invisible), 667 guests, and 53 spiders.
Topics286,323
Posts4,906,447
Members67,599
Most Online2,967
Mar 10th, 2019
How much extra oil when using AC pf52 vs. AC pf47? #4977176
01/12/19 04:39 PM
01/12/19 04:39 PM
Wa
Corollaman Offline OP
Wa
I've got a 2011 Silverado with the 4.3 V6. Normally it takes the short AC pf47e filter, but I'd like to use the longer AC pf52e instead. There is plenty of room for the extra length of the different filter from what I can see. (I might actually use the Supertech equilivant ST3890 it looks the same) How much extra oil for the longer filter? The truck takes 4.5 quarts with the smaller filter. I was thinking maybe 1/4 quart. When Chevy spec'd these filters in the past (short filter for 2 wheel, long filter for 4x4) I don't know if the owner's manuals said the correct oil amount difference. Any help would be appreciated.
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: Corollaman] #4977177
01/12/19 04:42 PM
01/12/19 04:42 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Maybe 1/2 a cup? (about 4oz?)
1/4 of a quart is 8 oz - I doubt it takes that much extra
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: Corollaman] #4977220
01/12/19 05:44 PM
01/12/19 05:44 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Enough oil to bring the dipstick level to the full mark.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: CT8] #4977229
01/12/19 05:56 PM
01/12/19 05:56 PM
Coastal South Carolina
edwardh1 Offline
edwardh1  Offline
far too simple to do it that way!!!
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: Corollaman] #4977256
01/12/19 06:35 PM
01/12/19 06:35 PM
Ohio
hallstevenson Offline
Ohio
Use the same amount as you always use. You might be surprised at what the dipstick shows. If necessary, then adjust.
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: hallstevenson] #4977278
01/12/19 06:59 PM
01/12/19 06:59 PM
Wa
Wa
You're probably right, if it's a small amount of difference in oil it might not be enough to change the level on the dipstick by much. I'll just put in the regular amount 4.5 quarts and measure from there.
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: Corollaman] #4977281
01/12/19 07:02 PM
01/12/19 07:02 PM
Waterloo, ON
Bluestream Offline
Bluestream  Offline
Waterloo, ON
one tablespoon
2000 VW Beetle 1.8T M5
2006 Pathfinder 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: Corollaman] #4977286
01/12/19 07:06 PM
01/12/19 07:06 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
One pound.
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: Corollaman] #4977288
01/12/19 07:08 PM
01/12/19 07:08 PM
Martinsburg West Virginia
71Chevyguy Offline
71Chevyguy  Offline
I used to do this on a Chevy Lumina I had, I believe the difference was about 1/4 of a quart. But what you normally put in would be very close to full.
18 Focus 1.0 Valvoline Modern Engine 0w20 / STP XL filter
99 VW Beetle TDI M1TDT / Mann filter
98 Buick LeSabre Kendall HM Ti 5w30 GF4 / Bosch Dist+
85 Skylark 2.5
71 Nova 250
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: Corollaman] #4977301
01/12/19 07:26 PM
01/12/19 07:26 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
5 gallons, more or less...
Just kidding!
Start with what you normally add, then add just a taste more.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: Corollaman] #4977376
01/12/19 08:45 PM
01/12/19 08:45 PM
Ohio
Ohio
My G35 calls for 5-1/8 quarts. I put the oversize 7317 Fram on it vs the standard 6607, dump in a 5-qt bottle of Castrol Edge, and it ends up 3/4 of the way between the "L" and "H" marks on the dipstick.
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: Corollaman] #4977535
01/12/19 11:37 PM
01/12/19 11:37 PM
McLean, Va.
vssjim Offline
vssjim  Offline
McLean, Va.
Half pint for most of these type of short vs long smaller diameter filters maybe 6 to 8 oz for larger diameter filters, at work we always try to us longer or larger filters on customer vehicles when ever possible.
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: hallstevenson] #4980111
01/15/19 03:20 PM
01/15/19 03:20 PM
California
DGXR Offline
DGXR  Offline
California
Exactly.
So many of these enthusiast forums have people obsessed with keeping the oil level exactly and perfectly at the full mark.
In a healthy engine, THIS IS NOT NECESSARY. If the oil level is between the two marks, you are fine.
The capacity difference in these filters is probably around 4-5 ounces and no adjustment is required.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: How much extra oil when using AC pf52 vs. AC pf47? [Re: edwardh1] #4991658
01/26/19 06:03 PM
01/26/19 06:03 PM
US
JLTD Offline
JLTD  Offline
US
LOL
You have to take the measurement of the two filters, perform a volume calculation and increase the amount of oil by the calculated volume -10% for the additional filter media.
I use the overseas owner's manual to choose my oil.
Using AMSOIL
Hers: 2008 Jeep Liberty 143k, SS 5w30/Amsoil
His: 2015 4Runner 51k, OE 5w30/Wix
