Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
32 registered members (c502cid, alcyon, anndel, Bailes1992, Chris B., 4 invisible), 543 guests, and 56 spiders.
Topics286,442
Posts4,908,257
Members67,622
Most Online2,967
Mar 10th, 2019
Space heater burnt smell #4951309
12/13/18 08:13 PM
12/13/18 08:13 PM
CA
BossMoss Offline OP
BossMoss  Offline OP
CA
I have an electric space heater that heats up oil inside it, and it started smelling kinda bad when I turned it on. It made me feel physically sick. I had to open a window.
Is it the dust on it that is burning a bit?
Re: Space heater burnt smell [Re: BossMoss] #4951322
12/13/18 08:35 PM
12/13/18 08:35 PM
New England
gathermewool Offline
New England
You tell us. Clean it and try again.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Space heater burnt smell [Re: BossMoss] #4951330
12/13/18 08:50 PM
12/13/18 08:50 PM
Ceciltucky Maryland
Oldtom Offline
Oldtom  Offline
Ceciltucky Maryland
An oil filled space heater should not get hot enough to create a smell that bad. Sounds like a connection is arcing. Unplug it and look at the line cord connection where it goes into the heater.
Re: Space heater burnt smell [Re: gathermewool] #4951336
12/13/18 08:57 PM
12/13/18 08:57 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
That's about the only honest troubleshooting advice you can expect to receive.
Re: Space heater burnt smell [Re: BossMoss] #4951371
12/13/18 09:53 PM
12/13/18 09:53 PM
Hudson valley
Oildudeny Offline
Oildudeny  Offline
Hudson valley
Those oil filled heaters are usually fail safe with thermal over heating protection. They do emit somewhat of an odor while heating up but shouldn't be sickening.. did anything spill and dry on the unit that's now cooking off? Check the cord and plug end for any damage and does the cord feel warm or hot when the units powered on.
Did you buy it new? I've seen 2nd hand heaters where the previous owner bypassed the thermal fuse. Big No No and throw it out
Re: Space heater burnt smell [Re: BossMoss] #4951388
12/13/18 10:18 PM
12/13/18 10:18 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
I have one of those radiator looking ones. It seemed to kind of smell the first few times I used it every year.
Was it the first time that you used it this season? If not, try it again and see what happens, but don’t leave it unattended.
Re: Space heater burnt smell [Re: BossMoss] #4951423
12/13/18 11:05 PM
12/13/18 11:05 PM
Dallas, Texas
SuperDave456 Offline
Dallas, Texas
+1 clean it well.
I use Windex on mine when I use them. Anything, including dust, will make them stink as it burns off slowly.
I used to use them every winter in the cheapo apartments. I'd only heat the room I was in and turn the rest of the apartment to ~60-65
They do smell a little the first few times you use them, but it shouldn't be nauseating.
BTW they take about 30-45 minutes to reach temp. I'd run mine at about 50% of the first setting, one heating element. After an hour they are very hot.
Please mind that I wouldn't leave my room for hours at a time and this was a small bedroom for a small apartment.
Anything more than that, maxxed out of the 1st setting, or even the 2nd setting (2 heating elements), it gets VERY hot and kind of scary after about an hour.
These are not kid friendly.
I've seen one of these units pop a new 20 amp breaker by itself on full blast number "3" setting which is all the heating elements on high, so be careful.
Re: Space heater burnt smell [Re: BossMoss] #4951488
12/14/18 01:42 AM
12/14/18 01:42 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
The cord on my mothers heater was burnt from turning it up to 1500 watts and using her microwave at the same time. Be careful using them.
Re: Space heater burnt smell [Re: BossMoss] #4951528
12/14/18 04:20 AM
12/14/18 04:20 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Is this one of those radiator type electric space heaters? i.e., like this:
https://www.walmart.com/ip/Mainstay...OrP6e3wIVBwppCh2sFgbLEAQYASABEgK50fD_BwE
Is this space heater a new one(new to you) that you are noticing has a smell?
Or is this an older one that you've had for some time that is now starting to smell?
My experience with these type of heaters is that, the painted surface gives off a smell while the heater is warming up but then the smell goes away during its usage cycle. And this happens each time I turn it on.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Space heater burnt smell [Re: BossMoss] #4953451
12/16/18 02:38 PM
12/16/18 02:38 PM
New England
New England
Also, this is why I keep the box for all of our space heaters.
Come Spring, all three go back in their box until they're needed again. When they're fired-up, no unusual smells.
I can't say the same for our electric base-board heat. For our bedroom, we prefer to use the portable heater with LED read-out to maintain temperature, instead of the wildly inaccurate thermostat for the baseboards...
Re: Space heater burnt smell [Re: BossMoss] #4954466
12/17/18 08:20 PM
12/17/18 08:20 PM
CA
BossMoss Offline OP
BossMoss  Offline OP
CA
Yes, I bought it new a few years ago. It really was the dust on it burning up and smelling bad.
Yes, a radiator type. The dust built up after a couple years. I rarely use it in California winters.
I wish I kept the box. A plastic cover will have to do from now on.
This one is nice. It comes with a power saver option that intermittently heats up so it’s not on 100% of the time.
