Has anyone done a financial comparison for say 20 years between an 80 gal hybrid and a 9 gpm propane tankless. I chose 20 years as that's the lifespan of a tankless propane water heater.
From a conservative point of view, the hybrid lasts 10 years (so two over 20 years) and tankless lasts 20 years.
The hybrid is close to $3000 each. So $6000. The tankless is $1600. Both plus install.
The garage is unheated so unsure how well the hybrid will work in the winter DE when it's cold. Garage is 47F now.
Obviously the heat pump will work very well in the summer. Dehumidifier is an extra bonus.
And hybrid heat pump water heater does not use a fossil fuel.
Sure seems you would need to save a lot via the heat pump.
Some of the comparisons may be between an electric water vs a hybrid electric water heater.
