If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Z08969, TCU_Adam, deaner1979, jdana24, KlenFrappe379
71061 Registered Users
43 registered members (bbhero, berniedd, Bailes1992, 14Accent, avi1777, 2 invisible), 815 guests, and 15 spiders.
Topics303,496
Posts5,235,112
Members71,061
Ecogard "Velocity Option" #4917213 11/06/18 11:20 PM
U
UG_Passat Offline OP
U
https://www.rockauto.com/en/catalog/toyota,2011,matrix,2.4l+l4,1447803,engine,oil+filter,5340
What the heck is the "Velocity Option" on the oil filter from Ecogard?
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Ecogard "Velocity Option" [Re: UG_Passat] #4917425 11/07/18 10:15 AM
Zee09 Offline
Looks like the short version of the ECOGARD X4477
Other than that I would think it would mean a higher flow rate.
Honestly I'd pass on either flavor
"If I walked on water, they'd say I couldn't swim."
Re: Ecogard "Velocity Option" [Re: UG_Passat] #4917538 11/07/18 12:21 PM
L
Linctex Offline
L
Same.......
Nothing about this filter brand inspires me to purchase it.
Re: Ecogard "Velocity Option" [Re: UG_Passat] #4917581 11/07/18 01:14 PM
A
Ablebody Offline
A
Most of them look good cut open but I try not to support the Chinese anymore than I have to by buying their goods. Won't even buy an iPhone for that reason
Re: Ecogard "Velocity Option" [Re: UG_Passat] #4919775 11/10/18 12:49 AM
R
Run Offline
R
I tried a basic Ecogard filter and was disappointed. The glue on the endcaps was inadequate and there were gaps in the filter media as a result. I don't reccomend them.
02 Escape
Re: Ecogard "Velocity Option" [Re: Run] #4919804 11/10/18 02:04 AM
P
PlzRepond Offline
P
Pics?
Re: Ecogard "Velocity Option" [Re: Run] #4919996 11/10/18 10:22 AM
T
Triple_Se7en Offline
T
Inadequate as in failure?
Gaps as in failure?
I highly doubt both. What's inadequate for you may hold up well for 10K.
Gaps in media mean absolutely nothing in protection. We have pics of Tough Guards going 20K with gaps. It help up marvelously. Proline filters have Gaps City. We have engines with 420K using them.
If there's no failure in your defintion of inadequate and no failure in gaps, then where's the problem?
Keep Your Pistons Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul X-Line 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: Ecogard "Velocity Option" [Re: UG_Passat] #4920598 11/11/18 02:21 AM
W
wdn Offline
W
I have seen the X4476 cut open here and they look fine. No gaps in the one I saw. They have crimped metal endcaps and a coil spring. Does not seem to be cutting corners on construction. Plenty of auto mechanics use Ecogard filters. They spend nothing on advertising or brand recognition so compete on price. Is it a WIX? No. Mechanic can mark it up to $4.75 on the bill it is still reasonable and make a few bucks on a $29 oil change with conventional oil.
Re: Ecogard "Velocity Option" [Re: UG_Passat] #4920648 11/11/18 07:37 AM
DuckRyder Offline
So no one knows what the “velocity option” is?
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Ecogard "Velocity Option" [Re: DuckRyder] #4920674 11/11/18 08:29 AM
W
WellOiled Offline
W
I just went to the Ecogard site and did a lookup for the Ranger.
The X2500 has Velocity below the description. I think it is a reduced diameter part. It should cross to PH10575.
The proper sized filters would be S4651 or X4651.
Otherwise I do not know.
Mazda 6
Factory fill
Re: Ecogard "Velocity Option" [Re: WellOiled] #4920683 11/11/18 08:41 AM
DuckRyder Offline
HMM you may be onto something.
For the Honda it gives a X4612 which appears to be the “short” filter and S or X 4610 for the “OEM”.
I think this may be what the call their consolidation program...
Robert
Re: Ecogard "Velocity Option" [Re: DuckRyder] #4920732 11/11/18 09:41 AM
W
WellOiled Offline
W
thumbsup
Mazda 6
Factory fill
