M1 0W-40 seems good for DI engines????
"Thanks to extensive cooperative development work with major manufacturers and the application of the latest lubrication technology, Mobil 1 0W-40 is recommended for many types of modern vehicles where it will help provide unsurpassed performance even under very demanding driving conditions.
Latest engine technologies including Turbo-chargers, Direct Injection, Diesels (without DPF) and Hybrids
High performance engines
Most operating conditions, from mild to extreme
Always consult your owner's manual to check recommended viscosity grade and specifications for your particular vehicle.
Specifications and Approvals
Mobil 1 0W-40 meets or exceeds the requirements of:"
https://www.mobil.com/english-au/passenger-vehicle-lube/pds/glxxmobil-1-0w40. just when you think all is good.
