What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
120 registered members (alteredtuning990, Aero540T, badtlc, avi1777, 97f150, 15 invisible), 2,171 guests, and 62 spiders.
Topics286,395
Posts4,907,493
Members67,614
Most Online2,967
Mar 10th, 2019
camry hybird 2018 oil -us.japan.china manul #4810305
07/10/18 01:35 PM
07/10/18 01:35 PM
Shanghai
BayTm21 Offline OP
BayTm21  Offline OP
Shanghai
The differences between countries can be so great(us:0w16 only)?i am in china…please help me…What should I choose
Re: camry hybird 2018 oil -us.japan.china manul [Re: BayTm21] #4810307
07/10/18 01:37 PM
07/10/18 01:37 PM
Shanghai
BayTm21 Offline OP
BayTm21  Offline OP
Shanghai
Re: camry hybird 2018 oil -us.japan.china manul [Re: BayTm21] #4810308
07/10/18 01:38 PM
07/10/18 01:38 PM
Columbus,Nebraska
Yah-Tah-Hey Online content
Yah-Tah-Hey  Online Content
Columbus,Nebraska
Mobil I 0W-30 and of course OEM oil filter.
Re: camry hybird 2018 oil -us.japan.china manul [Re: BayTm21] #4810323
07/10/18 01:53 PM
07/10/18 01:53 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
It looks like most weights are approved in your country, go with whatevers available. If youre within the temperature range, 5/30, 5/20, 0/xx works fine. Does the Chinese manual say anything having to use 0/16 like it does in the US one? Even the weight/temperature charts are different.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: camry hybird 2018 oil -us.japan.china manul [Re: Yah-Tah-Hey] #4810357
07/10/18 02:22 PM
07/10/18 02:22 PM
Shanghai
BayTm21 Offline OP
BayTm21  Offline OP
Shanghai
thanks
Re: camry hybird 2018 oil -us.japan.china manul [Re: Audios] #4810359
07/10/18 02:26 PM
07/10/18 02:26 PM
Shanghai
BayTm21 Offline OP
BayTm21  Offline OP
Shanghai
recommended 0w16...but the dealers not provided 0w16
Re: camry hybird 2018 oil -us.japan.china manul [Re: Audios] #4810361
07/10/18 02:26 PM
07/10/18 02:26 PM
Shanghai
BayTm21 Offline OP
BayTm21  Offline OP
Shanghai
Re: camry hybird 2018 oil -us.japan.china manul [Re: BayTm21] #4810365
07/10/18 02:29 PM
07/10/18 02:29 PM
PimTac Offline
PimTac  Offline
If the 0w20 or 5w20 grades are available those would work well for your Camry.
Cannot see signatures any longer so it doesn’t matter.
Re: camry hybird 2018 oil -us.japan.china manul [Re: BayTm21] #4810421
07/10/18 03:26 PM
07/10/18 03:26 PM
California
nthach Offline
nthach  Offline
California
Toyota says 0W-20 can be used in "emergencies" in the US owner's manual, but the Chinese and JDM ones is saying others can be used. The new A25A engine was designed around 0W-16 but Toyota realizes it's not available everywhere. Unlike Honda with thin oil clearances in the first 2 Insights and Civic Hybrid, Toyota is using a variable-output oil pump and polymer-coated bearings.
Use a 0W-20 or 5W-20. The viscometrics of the xxW-20s are close to the 0W-16 fill. You might lose a few tenths of MPG. Just keep an eye that the CEL doesn't turn on for a oil pump related code if the ECU/PCM is keeping tabs on the pump via PID/monitor or duty cycle.
Re: camry hybird 2018 oil -us.japan.china manul [Re: BayTm21] #4810473
07/10/18 04:08 PM
07/10/18 04:08 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
0w16 - 5w40, it sounds to me like the engineers designed it to run on 0w16 only and they know best! LOL Just more EPA horse manure. Truth is it can use almost anything found on any store shelf, it was designed with xw nothing in mind.
Re: camry hybird 2018 oil -us.japan.china manul [Re: BayTm21] #4810535
07/10/18 05:16 PM
07/10/18 05:16 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
In Shanghai? You are probably going to be fine running 0w20 or 5w20 even. I don't think 0w16 will make a difference there, not cold enough.
I wouldn't run anything 10w30 or 5w30 though.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: camry hybird 2018 oil -us.japan.china manul [Re: BayTm21] #4810868
07/11/18 12:34 AM
07/11/18 12:34 AM
Southern Oregon, USA
sdude2k2000 Online content
sdude2k2000  Online Content
Simple answer... US manual complies with C.A.F.E. - other country’s manual provides more options based on temps. The US manual even concedes that a higher viscosity may be better suited if operated at higher speeds or loads. Take it for what you wish. I run Mobil 1 0w40 in my Prius. Still get 50mpg just fine.
'08 Ford Fusion SEL 3.0L
'15 Toyota Prius 1.8L
Re: camry hybird 2018 oil -us.japan.china manul [Re: BayTm21] #4810869
07/11/18 12:44 AM
07/11/18 12:44 AM
NC
Vladiator Offline
Vladiator  Offline
NC
Read my signature.
Re: camry hybird 2018 oil -us.japan.china manul [Re: BayTm21] #4810890
07/11/18 01:40 AM
07/11/18 01:40 AM
So Cal
Jaha24k Offline
Jaha24k  Offline
So Cal
I would just use whatever is specified in your booklet for your region. However I would not use Chinese manufactured oil
Re: camry hybird 2018 oil -us.japan.china manul [Re: Jaha24k] #4813221
07/13/18 02:02 PM
07/13/18 02:02 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
I'd take a certified Chinese synthetic over an imported dino. What do you think their cars come from the factory with? The OEM sure as heck won't import oil and pay 2x for it.
