"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
71 registered members (A1O, aloe2018, AdditiveOCD, ARB1977, aircooled, arowbat, 8 invisible), 1,349 guests, and 54 spiders.
Topics286,321
Posts4,906,383
Members67,599
Most Online2,967
Mar 10th, 2019
45K severe service schedule for 2015 malibu #4807988
07/07/18 09:48 PM
07/07/18 09:48 PM
Missouri
gabriel9766 Offline OP
Missouri
Well the Malibu hit 45k yesterday and i follow the severe service schedule for the Malibu just because the way i drive. One the list of the 45k services is says, cabin filter, air filter, trans drain and fill, brake fluid flush, and check oil and fluids. OLM is at 27% with a lil over 5k on the PPPP 0w20. Plan on doing all these services at the next oil change which would prob b within 1K. Now i need to decide what products to use for what....
I went to Walmart tonight to looks at oil and i saw PPPP 0w20 that has new new sticker on it tht says "redesigned for modern turbo engines" mine aint turbocharged but it is GDI. i also saw ST has full syn on the shelf now tht is 0w20 and dexos1 gen2 certified. $15.88 for ST and $22.88 for PPPP. Ive had good results with PPPP but think ST is worth a try?
Now on to the transmission drain and fill... i did a drain and fill of about 4.5Q at 25k with autozone brand dex6 i got for $3Q. Walmart is now selling maxlife atf agin for $17.88 or Amazon had acdelco dex6 for $26.
Now the cabin and air filters i can get for $37 off Amazon and brake flush i can do at work on the lift.
What fluids should inuse for the trans and oil? Also im using up.my last napa gold oil filter next oil change.
2015 Malibu LT 2.5L PPPP 0w20 46.1K
2007 Escape XLT 3.0L 5Q STHM 5w30/1Q MC full syn 5W20 115K
2010 Fusion SE 2.5L MC 0w20 110K
2008 Escape XLT 2.3L MC 5w30 187K
2007 Fusion SE 2.3L- 173.5K STHM 0W20
Re: 45K severe service schedule for 2015 malibu [Re: gabriel9766] #4808025
07/07/18 10:55 PM
07/07/18 10:55 PM
USA
slacktide_bitog Offline
USA
I thought all the services went by the OLM now. That is, there is no set schedule that is published. Just change everything when the computer tells you to. it will automatically calculate the correct OCI and other service intervals for you. And you don't even have top worry about normal vs severe service because it does that for you automatically, too smile
Nothing wrong with Napa Gold. Their oil and air filters are both good stuff.
For the oil, any d1g2 oil. Napa's house brand synthetic is on sale for $2.99/qt until tomorrow (7/8).
Any licensed Dexron VI ATF will be fine, too, if you need to change the ATF. Advance Auto has Castrol Full Synthetic ATF on sale right now for $5/qt. It is licensed Dexron VI. Even Walmart has a house brand ATF that is licensed Dexron VI. Unfortunately, Maxlife is not licensed Dexron VI, so don't use it until after the warranty is over.
For the cabin filter, get the Mann "Frecious Plus" FP2442, if you can afford it. If not, there's certainly nothing wrong with the regular carbon/charcoal CUK2442.
Re: 45K severe service schedule for 2015 malibu [Re: gabriel9766] #4808038
07/07/18 11:22 PM
07/07/18 11:22 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
ST will be just fine for that engine...
Also would stick with Dex VI as well.....like the Valvoline myself.
Sounds good with pretty much everything else....
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: 45K severe service schedule for 2015 malibu [Re: gabriel9766] #4808154
07/08/18 07:43 AM
07/08/18 07:43 AM
Lake County, Ohio
ls973800 Offline
ls973800  Offline
Lake County, Ohio
Regular oil change intervals would be shown with the OLM but no other services. GM does not show when the brake fluid needs flushed, tires rotated, transmission fluid changed, etc like Honda or some other manufacturers do.
The original post also says the owner is following the severe condition maintenance schedule. The OLM could not be set to respond to that schedule.
Re: 45K severe service schedule for 2015 malibu [Re: ls973800] #4808238
07/08/18 10:14 AM
07/08/18 10:14 AM
USA
USA
Thanks! I did not know this. I thought GM's Simplified Maintenance Schedule was computer-based like Honda's MM
Re: 45K severe service schedule for 2015 malibu [Re: gabriel9766] #4808408
07/08/18 02:17 PM
07/08/18 02:17 PM
New Jersey
93cruiser Offline
93cruiser  Offline
New Jersey
that is a lot of service and money spent at 45k.
no to cabin filter if air flow at vents feels strong.
no to transmission service, unless you tow? doubtful.
no to brake fluid flush. really?
check oil and fluids? hopefully you can conduct this hard feat. oil? check. coolant? check. wiper fluid? check. add if needed. not hard
so basically change the oil at the next service needed, and change the air filter at that time. done. anything more is a waste of money and the dealer will love you.
Re: 45K severe service schedule for 2015 malibu [Re: 93cruiser] #4808429
07/08/18 02:48 PM
07/08/18 02:48 PM
Missouri
Missouri
Im doing all the service to the car, all in is < $100
