WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
97 registered members (53' Stude, 240_Ed, 2010Civic, 2015_PSD, 8 invisible), 2,221 guests, and 49 spiders.
Topics286,244
Posts4,905,134
Members67,587
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
2004 Pontiac GP running on hot side #4807350
07/07/18 06:10 AM
07/07/18 06:10 AM
US
clarkflower Offline OP
US
Hi
My 2004 Pontiac Grand Prix 90k has started to run on the hot side (hotter than I'm used to) while sitting stopped in traffic. It is very hot here. It does not get to the red but on the gauge shown here I'm getting close. About 5/8 with 3/4 being red. Normally I don't run above 7/16 maybe 1/2 at a red light and then it drops to 5/16. Now it's only dropping to 1/2 when I start running although it seenms to be a bit erratic. Drops to 1/2-7/16 and quickly pops back to 9/16, then back to 1/2 at a steady 50 mph.
http://gtcarlot.com/data/Pontiac/Grand+Prix/2004/1555158/Gauges-44231528.html GP Temp
expected it to be low on fluid but it was full. Both fans run. No anti freeze in the oil.
It did this 6 months ago after I bought the car. I added fluid and its been fine since till now.
Any thoughts?
Re: 2004 Pontiac GP running on hot side [Re: clarkflower] #4807355
07/07/18 06:20 AM
07/07/18 06:20 AM
Pennsylvania
Boomer Offline
Boomer  Offline
Pennsylvania
Are the fins in the radiator full of debris? Water pump OK? Thermostat failing?
2013 VW Passat TDI SE, 65,100 miles Castrol Professional VW507 5W-30
2017 VW Golf All Track 21,170 miles Castrol Professional VW505 5W-40
Re: 2004 Pontiac GP running on hot side [Re: clarkflower] #4807359
07/07/18 06:25 AM
07/07/18 06:25 AM
US
US
Thanks
No
Do water pumps fail like that or do they just go completely?
Could be.
Re: 2004 Pontiac GP running on hot side [Re: clarkflower] #4807360
07/07/18 06:25 AM
07/07/18 06:25 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I would get a new OE thermostat and Citric acid flush the system. As the other poster mention flush the radiator fins from behind.
Check the temp with a scan tool. If its a GTP it already has the thicker radiator, which is a good upgrade for the SE and GT.
Re: 2004 Pontiac GP running on hot side [Re: Trav] #4807362
07/07/18 06:27 AM
07/07/18 06:27 AM
US
US
Thanks Trav..Its a GT but it looks clean.
Re: 2004 Pontiac GP running on hot side [Re: clarkflower] #4807373
07/07/18 06:56 AM
07/07/18 06:56 AM
Trav Offline
Trav  Offline
Water pumps on these are not known to come apart, the bearings fail sure but its a noticeable and usually noisy fail.
A GTP radiator (OE) would be a great upgrade to this cars cooling system.
I got one (OE Modene made in Canada) of ebay one time for $50 because the guy thought it was too thick and wouldn't fit and sold it. GM used 10mm spacers from the factory to put the thinner radiators in the SE and GT, just leave them out and it fits perfectly.
Look at Rock for the delco OE for the GTP it is about $150 and well worth it, Delco was OE in 04, Modene the earlier ones. Same deal toss the spacers to fit. Temps will drop considerably, the part # ACDELCO 21555
Re: 2004 Pontiac GP running on hot side [Re: clarkflower] #4807402
07/07/18 07:41 AM
07/07/18 07:41 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Its possible that the vanes are worn on the pump, so its effectively flowing less coolant at idle than it should be. Id take a look at the pump, or you can try a coolant additive like water wetter to give it a little extra boost in the cooling power.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: 2004 Pontiac GP running on hot side [Re: clarkflower] #4807410
07/07/18 08:04 AM
07/07/18 08:04 AM
Cincinnati, OH, USA
bullwinkle Online confused
bullwinkle  Online Confused
Cincinnati, OH, USA
A cheap IR gun could be a good investment here-is it possible that the sender & gauge are incorrect? Shooting the thermostat housing when hot usually will give you an idea.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2004 Pontiac GP running on hot side [Re: clarkflower] #4807425
07/07/18 08:24 AM
07/07/18 08:24 AM
Idaho
sprite1741 Offline
sprite1741  Offline
Idaho
Did you check the coolant in the engine or just the overflow tank? I have seen engines low on coolant but still reading normal in the plastic tank. Means a leak somewhere. My V8 GP has been running in the middle in traffic but drops slightly when back to speed. I had a GTP before, I seem to remember on the V6 there was an cooling system air bleeder on it. Could have some trapped air. I remember fighting it once after a coolant change. Had an air lock. Might check for air in the engine.
2005 Grand Prix GXP 5.3L Supertech Synthetic Dexos 5w30 Fram Ultra 3506
1986 Dodge Lancer 2.2L Turbo, Supertech Synthetic 10w30 Fram Ultra 3614
Re: 2004 Pontiac GP running on hot side [Re: Trav] #4807508
07/07/18 09:47 AM
07/07/18 09:47 AM
US
US
Thanks Trav... As you know Im on SS now so I'm trying to keep some reserve in case I need intake manifold gaskets done.
I just did the thermostat..
Re: 2004 Pontiac GP running on hot side [Re: clarkflower] #4807514
07/07/18 09:54 AM
07/07/18 09:54 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
just did the thermostat? was that after or before it started getting hotter?
did you use an OE part? most aftermarket are junk.
Possible air in the system?
Re: 2004 Pontiac GP running on hot side [Re: clarkflower] #4807524
07/07/18 10:06 AM
07/07/18 10:06 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Flush the bugs out of the core. Feel for cold spots if you can get your fingers in there.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 2004 Pontiac GP running on hot side [Re: sprite1741] #4807539
07/07/18 10:18 AM
07/07/18 10:18 AM
US
US
Thanks. Because it was so hot I only checked it in the expansion tank and it was a little bit low in the actual radiator this morning.
Where it was low before, iím thinking I may have a small water leak somewhere but nothing visible.
The guy at the GM dealer thought I might need intake manifold gasketís because he said he saw oil.
I did the thermostat this morning after I was running hot and Iíve been out most of the mornning. It seems fine but I also added coolant to the radiator.
Seems I lost 1/4 gallon in 5 months?
Re: 2004 Pontiac GP running on hot side [Re: clarkflower] #4807591
07/07/18 11:22 AM
07/07/18 11:22 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
"Widetrack" LOL
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: 2004 Pontiac GP running on hot side [Re: clarkflower] #4807595
07/07/18 11:25 AM
07/07/18 11:25 AM
midwest
JamesBond Offline
JamesBond  Offline
midwest
I would make sure that the cap is clean and holding correct pressure and that the hose from the radiator to the overflow tank is clear and is tightly sealed at both ends.
If your radiator is low and the overflow tank is normal the radiator could pe pushing out water as it warms up as usual but sucking in air as it cools down due to a bad cap or hose.
Page 1 of 4 1 2 3 4
