WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
114 registered members (2015_PSD, Aichiguy, 2K2AcuraTL, 95oRANGEcRUSH, 14Accent, 12 invisible), 2,023 guests, and 52 spiders.
Topics286,244
Posts4,905,163
Members67,587
Most Online2,967
Mar 10th, 2019
New (used) car. What oil? #4804395
07/03/18 07:54 PM
07/03/18 07:54 PM
Raleigh NC
JLoy Offline OP
JLoy  Offline OP
Raleigh NC
She is a 2011 Honda Pilot 3.5 Engine.
What oil would you recommend? I have been a PYB guy for my 03 Tacoma and nearly anything in the 01 Accord which runs like a sewing machine.
Interested in any advice... The pilot specs 5w-20 but I'm not opposed to other weights. 130k on the clock.
Re: New (used) car. What oil? [Re: JLoy] #4804403
07/03/18 08:02 PM
07/03/18 08:02 PM
Michigan
khittner Offline
khittner  Offline
Michigan
No need to change past practice; it will be fine (well, it wonít suffer from oil-related issues, anyway) with the regimen youíve followed with your other vehicles.
Re: New (used) car. What oil? [Re: JLoy] #4804411
07/03/18 08:10 PM
07/03/18 08:10 PM
West Michigan
HM12460 Offline
HM12460  Offline
West Michigan
PYB is good stuff. If you have enjoyed using it in your Pilot, why change?
2018 Chevy Colorado
1995 Ford Thunderbird
Re: New (used) car. What oil? [Re: JLoy] #4804414
07/03/18 08:12 PM
07/03/18 08:12 PM
Raleigh NC
JLoy Offline OP
JLoy  Offline OP
Raleigh NC
Yeah but I thought I might finally justify buying some synthetic Pennzoil platinum or rotella t6 of some sort. I see the Napa synthetic on sale which is tempting...
Side note the wife has a 6 mile commute to work, not sure if that short trip should factor in.
Re: New (used) car. What oil? [Re: HM12460] #4804417
07/03/18 08:14 PM
07/03/18 08:14 PM
Raleigh NC
JLoy Offline OP
JLoy  Offline OP
Raleigh NC
Just got the pilot Friday... It has a maintenance minder (this guy does not know what or how that works). Daddy used PYB so I did too.... Lol otherwise we have used a ton of white bottle rotella in a dozen non car engines...
Re: New (used) car. What oil? [Re: JLoy] #4804422
07/03/18 08:23 PM
07/03/18 08:23 PM
USA
slacktide_bitog Offline
USA
Get the VCMuzzler if the previous owner didn't already install it. Because Honda's VCM is very hard on oil.
Since your car has the MM, use the cheapest synthetic on sale for the MM-suggested OCI. Napa Synthetic is on sale this week for $2.99/qt. Pick up a Napa Gold filter while you're there.
Re: New (used) car. What oil? [Re: JLoy] #4804426
07/03/18 08:26 PM
07/03/18 08:26 PM
Raleigh NC
JLoy Offline OP
JLoy  Offline OP
Raleigh NC
I had read about the muzzler. Do you have first hand experience with same? The vcm was.one of the reasons I was looking in to top shelf synthetic oils.
Re: New (used) car. What oil? [Re: JLoy] #4804431
07/03/18 08:34 PM
07/03/18 08:34 PM
Connecticut
cheesepuffs Offline
cheesepuffs  Offline
Connecticut
I have a VCM 3.5 Honda and mine burns oil. I ran PPHM and it slowed it (coming from conventionals) but didnít stop it so Iím trying 0W-20 M1 EP HM now for the high PAO content. I would highly recommend using a synthetic. People that say PYB is fine have never owned one of these engines. Mine absolutely drank conventional. Like, ďcheck the dipstick with 30 or 40 percent left on the OLM, and find it to be completely dryĒ kind of drank it. I had to add 3.5 quarts of oil that day to get it the full mark. Donít use conventional and DO check the oil level often.
2008 Honda Accord Coupe V6
Re: New (used) car. What oil? [Re: cheesepuffs] #4804432
07/03/18 08:36 PM
07/03/18 08:36 PM
Raleigh NC
JLoy Offline OP
JLoy  Offline OP
Raleigh NC
Will do... Thanks for the advice.
Re: New (used) car. What oil? [Re: JLoy] #4804434
07/03/18 08:40 PM
07/03/18 08:40 PM
NC
Vladiator Offline
Vladiator  Offline
NC
Mobil1 or Castrol in 0w30/0w40 flavor will serve you well. And Get the VCM muzzle.
Re: New (used) car. What oil? [Re: JLoy] #4804437
07/03/18 08:43 PM
07/03/18 08:43 PM
Connecticut
cheesepuffs Offline
cheesepuffs  Offline
Connecticut
Sure thing. I wouldnít overly stress about it, as I doubt your newer one will burn as much as my earlier engine, but itís definitely something to keep an eye on to at least establish what your rate of burn off is if there is any.
Re: New (used) car. What oil? [Re: JLoy] #4804476
07/03/18 09:28 PM
07/03/18 09:28 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
With the proper ratings oil is oil.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: New (used) car. What oil? [Re: cheesepuffs] #4804480
07/03/18 09:32 PM
07/03/18 09:32 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
How much does your Honda coupe burn now on good synthetic oil??
I like that Honda coupe look/style a lot. Sharp car indeed.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: New (used) car. What oil? [Re: bbhero] #4804568
07/03/18 11:22 PM
07/03/18 11:22 PM
Raleigh NC
JLoy Offline OP
JLoy  Offline OP
Raleigh NC
At 300k miles the 01 Accord smokes none but uses (leaks) about a half a quart between oil changes at 5-6k mile oil chany intervals. Usually Quaker state or super tech 5w-20...I say leaks because the valve cover gasket has a small leak and there is a drip underneath that I suspect is probably the rear main oil seal. All original engine. I did rebuild the transmission about 30k ago. No reason not to expect another 100k out if this Accord.
https://raleigh.craigslist.org/cto/d/2001-honda-accord-ex/6632910993.html
Re: New (used) car. What oil? [Re: JLoy] #4804623
07/04/18 03:00 AM
07/04/18 03:00 AM
Athens, GA
ctechbob Offline
ctechbob  Offline
Athens, GA
FYI, if you haven't, replace the VTEC solenoid gasket. Super common to have them leak.....a LOT. Wifes car leaked like a sieve that and was the problem.
2008 Acura TL Type S - 154k
2003 Honda Accord V6 - 207k
2000 Honda Accord I4 - 321k
Current Oil - Milesyn SXR5W30
Current Filter - Partsmaster 61334
