New frontier 4.0 V6
by passgas55. 06/19/19 12:14 AM
Top 5 reliable, affordable car makers?
by Elkins45. 06/18/19 10:16 PM
Rear positive camber
by wing0. 06/18/19 09:44 PM
Odd vehicle / tags on I-70
by Marco620. 06/18/19 09:43 PM
Repainted bumper cover vs OEM
by DTS419. 06/18/19 09:37 PM
Sweet Ice Tea
by BlueOvalFitter. 06/18/19 09:30 PM
17 F150 6R80 ATF oil change
by MagneticFX. 06/18/19 08:49 PM
Best solution for crack in vinyl seat
by paulri. 06/18/19 07:50 PM
Lower Tier Interstate batteries @ Costco?
by Onetor. 06/18/19 07:46 PM
75W90 suggestions?
by WillB. 06/18/19 07:37 PM
Big R - Mag1 Synthetic $12.99
by RamFan. 06/18/19 07:30 PM
No title after 2.5 months?
by Shaman. 06/18/19 07:18 PM
Downgrade Windows 10?
by Robster. 06/18/19 07:17 PM
AC PF2257G Any good?
by Oldtom. 06/18/19 06:48 PM
New tire time...225/55/19, all seasons...
by Ws6. 06/18/19 06:48 PM
Rockauto Code
by Recalculating. 06/18/19 06:27 PM
Side Mirror Partially Stuck
by ET16. 06/18/19 06:15 PM
DTS419, chakir, 9J460, Petethedog, RenewableLubeBen
68429 Registered Users
42 registered members (4WD, bdcardinal, carlprop, BlakeB, ajchien, 4 invisible), 979 guests, and 22 spiders.
Topics290,643
Posts4,990,092
Members68,429
Most Online2,967
Mar 10th, 2019
How much damage was likely done? #4786264
06/13/18 09:40 PM
06/13/18 09:40 PM
Southeast Texas
gfh77665 Offline OP
gfh77665  Offline OP
Southeast Texas
I bought a used Chevy Silverado (5.3) almost a year ago, just after the great Harvey flood. It had 145K miles at that time. I checked the vehicle over pretty good when I bought it, and I remember seeing nice red Trans fluid on the dipstick then.
I have since driven about 15,000 miles, and I checked the fluid again this week and found the fluid level almost 2 inches above the crosshatch mark. I don't know how I missed the overfill earlier, but I suppose I did.
I took it to an independent shop and they did a BG flush, and the fluid is now new, and at the correct level. The truck has never exhibited any trans symptoms. Shifts have always been correct. The fluid was still red at the time of change.
My question is, all things considered, how much damage (if any) was done? Should I worry much? Thanks.
Re: How much damage was likely done? [Re: gfh77665] #4786265
06/13/18 09:42 PM
06/13/18 09:42 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Was the trans at operating temp and the truck on a level surface when you checked it both times?
Re: How much damage was likely done? [Re: Reddy45] #4786267
06/13/18 09:43 PM
06/13/18 09:43 PM
Southeast Texas
gfh77665 Offline OP
gfh77665  Offline OP
Southeast Texas
Yes. Its pancake flat here where I live.
Re: How much damage was likely done? [Re: gfh77665] #4786283
06/13/18 09:58 PM
06/13/18 09:58 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I'd say that if no drivability concerns have manifested, you're probably fine.
"Zed's dead baby, Zed's dead."
Re: How much damage was likely done? [Re: gfh77665] #4786309
06/13/18 11:01 PM
06/13/18 11:01 PM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
Is it leaking in from the transfer case?
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: How much damage was likely done? [Re: gfh77665] #4786310
06/13/18 11:05 PM
06/13/18 11:05 PM
Southeast United States
TheLoneRanger Offline
The problem with overfilling is that the ATF will get up into the gears and air bubbles will be created, then the air mixed with fluid will cause slippage. I doubt if 2 inches overfilled would cause any trouble at all.
Some days you eat the bear, some days the bear eats you.....
Re: How much damage was likely done? [Re: gfh77665] #4786312
06/13/18 11:10 PM
06/13/18 11:10 PM
Southeast Texas
gfh77665 Offline OP
gfh77665  Offline OP
Southeast Texas
Never had any leaks. No issues ever noticed.
Re: How much damage was likely done? [Re: gfh77665] #4786317
06/13/18 11:20 PM
06/13/18 11:20 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Really to full and it would be blowing fluid out the breather. If that never happened, no big deal smile
Re: How much damage was likely done? [Re: gfh77665] #4786329
06/14/18 12:00 AM
06/14/18 12:00 AM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
Sorry, but I have to ask. Did you check the ATF with the engine running?
1997 Maxima 201k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 200k, VWB + SSS + Rislone cocktail, MGL51516
Re: How much damage was likely done? [Re: gfh77665] #4786331
06/14/18 12:04 AM
06/14/18 12:04 AM
Southeast Texas
gfh77665 Offline OP
gfh77665  Offline OP
Southeast Texas
Yes.
Re: How much damage was likely done? [Re: gfh77665] #4786342
06/14/18 12:58 AM
06/14/18 12:58 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
If it's not broken don't fix it.
Re: How much damage was likely done? [Re: gfh77665] #4786346
06/14/18 01:28 AM
06/14/18 01:28 AM
Malaysia
zeng Online content
zeng  Online Content
Malaysia
Originally Posted By: gfh77665
...... and I checked the fluid again this week and found the fluid level almost 2 inches above the crosshatch mark......
...... The fluid was still red at the time of change.
No damage.
Move on.
Re: How much damage was likely done? [Re: gfh77665] #4786368
06/14/18 03:56 AM
06/14/18 03:56 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I think you'll be fine, besides, worrying about it isn't going to change a thing. Drive on.
God Bless Our Troops
Re: How much damage was likely done? [Re: rooflessVW] #4786414
06/14/18 06:18 AM
06/14/18 06:18 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
+1 Probably nothing. It sounds like it was possibly filled to the full/Hot mark when cold. To move it up the stick that amount doesn't necessarily translate to a whole lot in the pan. I wouldn't loose any sleep over it.
Re: How much damage was likely done? [Re: Trav] #4786428
06/14/18 06:42 AM
06/14/18 06:42 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
In line with what Trav just said:
So much fuss was made over checking the fluid in my auto I got the bug to check it several times during a day of local driving whenever I did a drain & fill.
I'd be careful in the first place and have done a few D&F's over the years.
I'd always find level spots to park and follow the method.
The fluid's level would dance about all day long.
I concluded the key was to let the car be still THEN do the gear range row (P to L to P SLOWLY then check level within 20 seconds).
You maybe got a false level reading
