Alternative oil filters
by GeoffPD - 08/24/19 10:16 PM
PartSource Canada Delvac deal
by Bluestream - 08/24/19 09:57 PM
Chamberlain tractor pto clutch oil
by Jabbo - 08/24/19 09:37 PM
how to get out o2 sensor
by dogememe - 08/24/19 09:18 PM
Should I use a wash and wax for maintenance washes?
by littlehulkster - 08/24/19 08:53 PM
Michelin Rebate
by twouvakind - 08/24/19 08:47 PM
Meguiar's Ultimate Fast Finish.
by irv - 08/24/19 08:27 PM
Fram PH/TG/XG3593a cut open
by SlavaB - 08/24/19 08:12 PM
Supertech vs OEM
by Bettez88 - 08/24/19 08:05 PM
Exxon Mobile Synergy Supreme Friction Modifier
by IndyFan - 08/24/19 07:50 PM
Toyota oil cap funnel
by Patrick0525 - 08/24/19 07:07 PM
STUMPED (2002 BMW X5)
by Kira - 08/24/19 05:43 PM
Turtle Wax Zip wash/wax...garbage!
by gregk24 - 08/24/19 05:41 PM
Does Super Lube Oil make Good Electric Motor Oil
by vortex - 08/24/19 04:40 PM
26 degree temp swing in 24 hours
by gman2304 - 08/24/19 04:12 PM
FEDERATED PG4459F CUT OPEN
by 53' Stude - 08/24/19 03:58 PM
Reverse mortgage questions.
by callbay - 08/24/19 03:45 PM
Moly vs No Moly
by Navi - 08/24/19 03:08 PM
EricTwoCamaros, Subie5w30, Iautox, Mayadi, YachtRocket
69055 Registered Users
83 registered members (AdditiveOCD, 2003f7, AZjeff, 53' Stude, Alfred_B, 10 invisible), 1,565 guests, and 21 spiders.
Topics293,754
Posts5,046,147
Members69,055
Most Online3,532
Jul 30th, 2019
2010 EDGE brakes squeal only in reverse #4784002 06/11/18 03:20 PM
53' Stude Online Content OP
OP Online Content
Friends 2010 Ford EDGE. 70k on it and he just did rear rotors and pads and now hears squealing passenger rear brakes. Only in reverse. Any ideas?
Thanks gentlemen
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784006 06/11/18 03:25 PM
The Critic Offline
What brand of parts did you use?
2011 Toyota Prius 1.8L - 195K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 138K - Mobil 1 EP HM 5W-30
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784008 06/11/18 03:27 PM
OP Online Content
HE used MC or Motorcraft rotors and pads sir smile
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784010 06/11/18 03:29 PM
bdcardinal Online Content
Online Content
Did he wash the rotors with soap and hot water before installing?
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784016 06/11/18 03:36 PM
2
2009Edge Offline
2
My 09 Edge had the emergency brake in the small drum inside the rear rotors. could be the squeal origin.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784020 06/11/18 03:36 PM
OP Online Content
Im not sure but he did brake clean the rotors off he said
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784035 06/11/18 03:54 PM
SirTanon Offline
Sounds like he either didn't replace some or all of the hardware when he did the pads, or he forgot to clean and lube some of the pins... or maybe forgot to clean the hub surface.
2013 Nissan Altima SV - 2.5 liter/CVT - 118,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 67,000mi
2010 Ford Fusion - 274,500mi
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784314 06/11/18 08:43 PM
ddtmoto Offline
When they finish bedding in they may be fine. Patience....
Mustang GT 5.0 Brembo '11
ram 5.9
TL1000S
GSXR1000
DRZ400E
'09 GTZ1400 Concours
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784334 06/11/18 09:04 PM
H
hallstevenson Online Content
Online Content
H
Have him quickly re-do the pads and hardware and properly apply grease to the hardware (both sides). Remove the hardware, apply grease to the caliper frame, re-install the hardware, apply grease, then the pads.
Re: 2010 EDGE brakes squeal only in reverse [Re: 53' Stude] #4784390 06/11/18 09:59 PM
The Critic Offline
Probably a hardware issue. Have him make sure all of the rust was removed from the bracket before installing the new clips.
