2010 EDGE brakes squeal only in reverse
In the shop
Friends 2010 Ford EDGE. 70k on it and he just did rear rotors and pads and now hears squealing passenger rear brakes. Only in reverse. Any ideas? Thanks gentlemen
SW Ohio
Have him quickly re-do the pads and hardware and properly apply grease to the hardware (both sides). Remove the hardware, apply grease to the caliper frame, re-install the hardware, apply grease, then the pads.
CA
Originally Posted By: car51
HE used MC or Motorcraft rotors and pads sir smile
Probably a hardware issue. Have him make sure all of the rust was removed from the bracket before installing the new clips.
