Factory Fill 2019 VW Jetta 1.4t
by DuckRyder - 11/20/19 08:12 PM
Castrol Edge Professional LL IV FE 0W/20 (VW508)
by DuckRyder - 11/20/19 08:08 PM
2019 Kia Sedona - Oil Filter Housing
by XpressAuto - 11/20/19 07:46 PM
Belt/ Tensioner wear
by bruckus - 11/20/19 07:42 PM
Eneos CVT fluid
by bbhero - 11/20/19 07:38 PM
Game changer?
by P10crew - 11/20/19 07:34 PM
Permatex Brake Lubricant
by Snagglefoot - 11/20/19 07:01 PM
2015 BMW 328i Pennzoil Platinum 5w40 Euro
by TurboJW - 11/20/19 06:55 PM
STP S2808 (Blue) now also a H/K clone
by wemay - 11/20/19 06:30 PM
New to shortwave radio
by cwilliamsws6 - 11/20/19 06:22 PM
Ford Tempo
by Eric Smith - 11/20/19 05:40 PM
quick FL-910s C&P
by BeerCan - 11/20/19 04:50 PM
Adding keyless entry to an older car
by atikovi - 11/20/19 04:36 PM
blind spot monitoring sensor 2017 jetta
by raaizin - 11/20/19 04:33 PM
Subaru Forester rear brakes
by Donald - 11/20/19 04:19 PM
Cummins ISX15 OCI
by The Critic - 11/20/19 04:07 PM
It's A Radial Robert
by Yah-Tah-Hey - 11/20/19 04:02 PM
London Real - youtube and TV...
by Shannow - 11/20/19 02:38 PM
Vehicle speed while passing
by joegreen - 11/20/19 02:15 PM
ImBoosted, XpressAuto, Jmpage388, baileyclarke, Jbloggs
69924 Registered Users
129 registered members (4WD, 007, 92saturnsl2, 2009Caraman, 11 invisible), 1,858 guests, and 22 spiders.
Topics297,696
Posts5,120,869
Members69,924
Most Online3,589
Nov 2nd, 2019
Any reason not to use Euro L or Euro AV in... #4782081 06/09/18 09:04 AM
9
99Saturn Offline OP
9
Any reason not to use Euro L or Euro AV in a non-Euro speced car? Specifically a, 06 Chevy Cobalt. I have a bunch of Pennzoil Platinum 5w30 from one of the Autozone clearances. TIA.
Add: Any issues if the car consumes a bit of oil between changes - 1/2 qt? (In other words anything to be concerns around the add pack and potential burning if I know the car already consumes?)
Re: Any reason not to use Euro L or Euro AV in... [Re: 99Saturn] #4782083 06/09/18 09:05 AM
1
1JZ_E46 Offline
1
You could run just about anything in a that car. Both of those oils are really good.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: Any reason not to use Euro L or Euro AV in... [Re: 99Saturn] #4782084 06/09/18 09:08 AM
W
Wolf359 Offline
W
Aren't those diesel oils? Probably ok to run in a gas engine, but I wouldn't bother with long change intervals.
Re: Any reason not to use Euro L or Euro AV in... [Re: 99Saturn] #4782102 06/09/18 09:32 AM
W
WobblyElvis Offline
W
Pennzoil Euro L and AV both meet SAE SN specs. If this is on the bottle I don't see how you can go wrong.
Re: Any reason not to use Euro L or Euro AV in... [Re: 99Saturn] #4782103 06/09/18 09:32 AM
M
maverickfhs Offline
M
Yes, that's what I have picked up, that these are low SAPS oils and should be good for 3K-5K interval.
Not intended for any longer OCIs.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Any reason not to use Euro L or Euro AV in... [Re: 99Saturn] #4782107 06/09/18 09:37 AM
slacktide_bitog Offline
A half quart during the entire OCI is no problem at all. Are using the OCI suggested by the OLM?
The PP Euro L 5w30 is licensed dexos2, and in Europe, GM uses dexos2 for all their cars (both gas/petrol and diesel).
Re: Any reason not to use Euro L or Euro AV in... [Re: 99Saturn] #4782108 06/09/18 09:39 AM
skyactiv Offline
Those are the EXACT oils you want in your car if you consume oil. They have lower SAPS than typical PCMO oils and therefore leave less ash to accumulate in the catalyst. Low SAPS oils contain Expensive high performance anti wear polymers not in your typical engine oil. They don't show up in a VOA or UOA.
I think the Euro AV might be a mid SAPS oil or the same as Euro L? The reported specs can be skewed by the maker to hide it. Make one product appear worse than it is. It is done to save on licensing fees. SOPUS doesn't wanna pay GM for people buying oil for a VW as an example.
Sold: 13' VW GTI 3 door 6 speed manual
Me: 18' Elantra Sport 6 speed manual
Re: Any reason not to use Euro L or Euro AV in... [Re: 99Saturn] #4782152 06/09/18 10:14 AM
CT8 Offline
Why would there be reasons?
Re: Any reason not to use Euro L or Euro AV in... [Re: slacktide_bitog] #4782160 06/09/18 10:24 AM
9
99Saturn Offline OP
9
Thanks all, seems like I should have no concern, as long as the OCI is reasonable.
I try to keep it to 5K. It's my parent's car, just helping out with the maintenance when I can. I ask them to keep it around 5K miles, which sometimes gets pushed if they forget. OLM takes the OCI out to ~7K or 7.5K. I think it is just a countdown clock, as my OLM (also an '06 Cobalt) does the same, even though it sees a ton of short trips.
Re: Any reason not to use Euro L or Euro AV in... [Re: 99Saturn] #4782309 06/09/18 02:14 PM
T
Trav Offline
T
No issues with low SAPS anymore, Tier 3 took care of that issue. Many Euro dealers are no longer stocking obsolete specs oils like VW 502 and BMW LL-01 anymore for the shop. Now its mostly 504/507 and LL-04
Re: Any reason not to use Euro L or Euro AV in... [Re: Trav] #4782443 06/09/18 05:58 PM
B
Bjornviken Offline
B
They have bouth. Do you know if low saps oil is good for ethanol fuels like e10?
Re: Any reason not to use Euro L or Euro AV in... [Re: 99Saturn] #4782471 06/09/18 06:43 PM
L
Linctex Offline
L
I highly highly highly doubt changing the oil before 7,500 miles -
is going to extend the life of that car AT ALL..... Not even a tiny bit.
Re: Any reason not to use Euro L or Euro AV in... [Re: Bjornviken] #4782495 06/09/18 07:05 PM
T
Trav Offline
T
Sure it is, Germany has had E10 available for a while now but not mandatory, no alternative oil required per new car owners manual.
Edit: You should use Euro V or VI fuel, 10 ppm sulfur, the old Euro IV had 50 and requires mid SAPS for longest oil life.
Re: Any reason not to use Euro L or Euro AV in... [Re: 99Saturn] #4782556 06/09/18 08:06 PM
N
nap Offline
N
I keep hearing that the certifications are what counts, not the VOAs.
So, if this oil is API SN certified, why is it good for only half of the OCI of other API SN oils?
Are the API SN tests defective in some way?
Re: Any reason not to use Euro L or Euro AV in... [Re: nap] #4782603 06/09/18 09:29 PM
G
Garak Offline
G
Particularly if one isn't running ULSG, it makes a difference, since starting TBN is lower. This has been going on for some time with there being a disparity as to what oil a car should run in Europe versus North America, with European OEMs even having different OCIs and/or different specs on either side of the pond. Using LL01 in North American BMW gassers versus LL04 in Europe is a prime example.
Are the SN tests defective in some ways? Perhaps. They're not terribly demanding, but aside from that, there's only so much SN can tell you. Just having SN doesn't automatically qualify it as a long drain oil. SN can be anything from the a very basic SAE 30 conventional to a C3 like in this thread or an A3/B4 or an E7, E9. Yes, the certifications do count, and a C3 oil isn't the same as an ILSAC oil which isn't the same as an A3/B4.
All other things being equal and you were solely trying to maximise your OCI, would you choose an A3/B4 or a C3, with both having SN, assuming the vehicle just called for an SN multigrade of some sort?
Plain, simple Garak.
