195/65R Yokohama Avid Ascend GT
by Marco620. 06/19/19 01:01 AM
New frontier 4.0 V6
by passgas55. 06/19/19 12:14 AM
Top 5 reliable, affordable car makers?
by Elkins45. 06/18/19 10:16 PM
Rear positive camber
by wing0. 06/18/19 09:44 PM
Odd vehicle / tags on I-70
by Marco620. 06/18/19 09:43 PM
Repainted bumper cover vs OEM
by DTS419. 06/18/19 09:37 PM
Sweet Ice Tea
by BlueOvalFitter. 06/18/19 09:30 PM
17 F150 6R80 ATF oil change
by MagneticFX. 06/18/19 08:49 PM
Best solution for crack in vinyl seat
by paulri. 06/18/19 07:50 PM
Lower Tier Interstate batteries @ Costco?
by Onetor. 06/18/19 07:46 PM
75W90 suggestions?
by WillB. 06/18/19 07:37 PM
Big R - Mag1 Synthetic $12.99
by RamFan. 06/18/19 07:30 PM
No title after 2.5 months?
by Shaman. 06/18/19 07:18 PM
Downgrade Windows 10?
by Robster. 06/18/19 07:17 PM
AC PF2257G Any good?
by Oldtom. 06/18/19 06:48 PM
New tire time...225/55/19, all seasons...
by Ws6. 06/18/19 06:48 PM
DTS419, chakir, 9J460, Petethedog, RenewableLubeBen
68429 Registered Users
32 registered members (Duke, aba4430, amh, berniedd, bernau, 3 invisible), 721 guests, and 25 spiders.
Topics290,645
Posts4,990,135
Members68,429
Most Online2,967
Mar 10th, 2019
Page 1 of 7 1 2 7
Merc 3.0CRD Oil advice please. #4761678
05/19/18 07:05 AM
05/19/18 07:05 AM
England
Tikka Offline OP
Tikka  Offline OP
England
Hi
I have a 2008 Grand Cherokee with the Merc OM642 Diesel unit in it. I have no DPF fitted, Jeep only fitted them on new model in UK I believe.
My oil spec is 229.51.Will I be ok using any Oil that is Merc approved to 229.51 or is it not as simple as that?
I am looking for ultimate Engine and Turbo protection rather then fuel economy.
What are the ingredients in the oil I should be looking for? Indeed are all 229.51 oils made to the same 'recipe'?
Any suggestions on viscosity range? My handbook calls for a 5w-30. The UK has a relatively moderate climate.
Forgive me if any of my questions are a little naÔve but I am just learning and am finding the subject very interesting.
Many thanks.
Tikka.
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761697
05/19/18 07:23 AM
05/19/18 07:23 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
229.51 has been superseded by 229.52.
Yes any oil with 229.52 certifications will be fine.
Also, 5W-30 would be fine for England.
I had over a hundred OM642s non-DPF in my Sprinter fleet. As well, I recommend only using OE MB oil filters for the engine.
Friend of mine had the exact same JGC as you have. Traded it in as local Jeep dealer was clueless on how to maintain the truck.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761710
05/19/18 07:37 AM
05/19/18 07:37 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Any MB 229.51 would do, and it's more likely to be an xW40 in my country.
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761724
05/19/18 07:57 AM
05/19/18 07:57 AM
England
Tikka Offline OP
Tikka  Offline OP
England
Hi Danno
Thanks for helping.
I noticed the 229.52 spec but I wonder when the specs move on for different engines whether they start removing ingredients that may be good for my older engine. Maybe I am over thinking this?
Yes I will only use genuine filters. I read the long thread about these filters on the oil filter section of the forum.
At the moment my Jeep is getting PETRONAS Syntium 5w-30 as fitted by Jeep Dealer.
Diesel Jeeps are by far the most common in UK. Petro ones are rare due to our very high taxes on fuel.
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761727
05/19/18 07:59 AM
05/19/18 07:59 AM
England
Tikka Offline OP
Tikka  Offline OP
England
Hi Zeng
Thanks for you help.
I am guessing you guys use a 40 weight due to your hot climate?
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761793
05/19/18 09:14 AM
05/19/18 09:14 AM
Danno Offline
Danno  Offline
229.52 covers 229.51 spec so you're good to use it.
I know MB extended OCI with the launch of 229.52, so you shouldn't have worries.
2010 Mazda 3 2.0L
2009 Venza V6 AWD
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761875
05/19/18 10:53 AM
05/19/18 10:53 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
I believe 229.52 is identical to 229.51, with the exception of a more stringent fuel economy test. I would stick with 229.51. More options.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4762088
05/19/18 03:22 PM
05/19/18 03:22 PM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
MB 229.52 is more stringent than 229.51 in areas of oxidative thickening and fuel economy, and is otherwise the same, according to Lubrizol. Mobil 1 0W-30 ESP meets MB 229.52.
https://online.lubrizol.com/relperftool/pc.html
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4762216
05/19/18 05:59 PM
05/19/18 05:59 PM
California
CleverUserName Offline
California
If youíre looking for the ultimate in engine and turbo protection, then a Low-Mid SAPS oil isnít the best choice. I think you probably want the additional AW additives an E7 or E9 synthetic Diesel engine oil. E7 or E9 in 5w30 or 5w40 would be the lube for you.
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4762270
05/19/18 06:44 PM
05/19/18 06:44 PM
Texas
DallasTexas Offline
DallasTexas  Offline
Texas
I have a OM648 CDI with DPF. To protect the DPF I use MB 229.31 or MB 229.51 which is usually Mobil Delvac 1 ESP. I tend to worry more about DPF.
06 E320 CDI 98k miles
14 Sienna 33k miles
96 E300 297k miles Donated
Re: Merc 3.0CRD Oil advice please. [Re: DallasTexas] #4762582
05/20/18 02:53 AM
05/20/18 02:53 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Since when Mobil1 Delvac ESP carries MB 229.31 or .51?
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4762593
05/20/18 04:00 AM
05/20/18 04:00 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Yes, I'd access to Total Quartz Ineo MC3 5W40 MB 229.51 C3.
Re: Merc 3.0CRD Oil advice please. [Re: zeng] #4762609
05/20/18 05:12 AM
05/20/18 05:12 AM
England
Tikka Offline OP
Tikka  Offline OP
England
Not PETRONAS I see. Any particular reason as I presume it is readily available?
Re: Merc 3.0CRD Oil advice please. [Re: CleverUserName] #4762612
05/20/18 05:19 AM
05/20/18 05:19 AM
England
Tikka Offline OP
Tikka  Offline OP
England
Hi
Would a 228.51 spec suit my needs better? If I am reading things correctly 228.51 seems to be a diesel specific spec.
According to Mercedes this spec is ok on the om642 without dpf.
https://bevo.mercedes-benz.com/d/d/en/Spec_223_2.pdf
They seem to be a more Truck and commercial vehicle oil. Although still low saps.
Re: Merc 3.0CRD Oil advice please. [Re: DallasTexas] #4762614
05/20/18 05:24 AM
05/20/18 05:24 AM
England
Tikka Offline OP
Tikka  Offline OP
England
Hi
I do not have dpf so I hope I have a little more wriggle room with lube choice
Page 1 of 7 1 2 7
