I have not been changing the oil on my Mazda5 (been going to Valvoline) but I am going to start doing it myself. It has some annoying plastic covering the underside of the engine bay with a hole for the oil filter and a hole for the drain plug. I'd like to keep all the plastic intact and just use an oil filter canister-type remover on the end of ratchet. I assumed there would be somewhere I can look up the size/# of flutes I need but [censored] if I can't find this info....
I think a 74mm 14 fluted will work - anyone know where I can look this info up to be sure?
