Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
29 registered members (bmod305, Brad_C, Chesterr, clinebarger, carlprop, alcyon, 2 invisible), 679 guests, and 64 spiders.
Topics286,442
Posts4,908,225
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Why not just use 0w oils? #4722602
04/10/18 10:30 AM
04/10/18 10:30 AM
Oakville,Ontario
Volvoeric Offline OP
Oakville,Ontario
Sorry if this is a dumb question, but... if a 0w30 oil is in theory, the same as a 10w30, why dont we just all use the 0w30?
Re: Why not just use 0w oils? [Re: Volvoeric] #4722616
04/10/18 10:47 AM
04/10/18 10:47 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Re: Why not just use 0w oils? [Re: Volvoeric] #4722625
04/10/18 11:00 AM
04/10/18 11:00 AM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
In Canada I'd use 0w-30. In Florida 5w-30 is fine, and it's cheaper. To me it's more about climate than anything else.
2017 Honda Odyssey SE, 18K
2013 Honda Accord LX, 59K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Why not just use 0w oils? [Re: Volvoeric] #4722626
04/10/18 11:01 AM
04/10/18 11:01 AM
NJ, USA
MotoTribologist Offline
NJ, USA
I choose 0W oils over 5W or 10W at each opportunity.
To answer your question though, the reason should be cost. I don't really price compare on the retail end so maybe I'm wrong, but I should think 0W oils are more expensive on the shelf. They are definitely more expensive to manufacture.
Re: Why not just use 0w oils? [Re: Volvoeric] #4722637
04/10/18 11:19 AM
04/10/18 11:19 AM
Oakville, Ontario
Patman Offline
Global Moderator
Patman  Offline
Global Moderator
Oakville, Ontario
More VII, so it won't be as shear stable. In the case of my Corvette, I don't need to worry about cold starts, and I want an oil that will stay solidly in grade, especially if I get a little bit of fuel dilution due to the direct injection. So I wouldn't consider a 0w30 there. In my Honda, I've had a problem with M1 0w20 thinning out too much for my liking as well, so I bought some Pennzoil Ultra Platinum 5w20 for it's next interval to see if it maintains it's viscosity better.
BTW, welcome fellow Oakville resident! smile
2018 Corvette, 9k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 149k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,113k, GC 0w40 & Fram Ultra
Re: Why not just use 0w oils? [Re: Volvoeric] #4722645
04/10/18 11:27 AM
04/10/18 11:27 AM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
The 0W vs 10W aspect matters for oil burning engines. From what I've read on here, the lighter 0W may slip past worn rings and burn more easily compared to a 10W.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Why not just use 0w oils? [Re: MotoTribologist] #4722646
04/10/18 11:27 AM
04/10/18 11:27 AM
Florida
hatt Offline
hatt  Offline
Florida
What benefits will I see with a 0W vs a 10W in Florida?
2013 F150 5.0, Delo XLE CK-4 10W-30, Baldwin B7449
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Why not just use 0w oils? [Re: Volvoeric] #4722649
04/10/18 11:30 AM
04/10/18 11:30 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
Patman- Have you had that M1 tested from your new Vette yet? You might want to look into a more robust oil if you really like the car and plan to keep it... wink
You think that M1 sheared in your Honda, what do you think its gonna do when you beat on that Vette? M1 isn't the oil it used to be, not even close...
Que the M1 fanboys... hornets hide
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Why not just use 0w oils? [Re: Volvoeric] #4722651
04/10/18 11:32 AM
04/10/18 11:32 AM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I was told burn-off is a consideration when using 0W oils. Their light weight makes them more susceptible to loss as a volatile. Given that the average motorist doesn't check their oil, and oil changes have been extended, there is a serious concern that many people would run their engine low on oil. Also for this same reason, 0W oils can only be produced as a synthetic to reduce this loss.
Re: Why not just use 0w oils? [Re: hatt] #4722655
04/10/18 11:33 AM
04/10/18 11:33 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Most likely you have a lower NOACK, less prone to shearing oil using a 10W in Florida. IMO a better choice for Florida.
God Bless Our Troops
Re: Why not just use 0w oils? [Re: Volvoeric] #4722656
04/10/18 11:36 AM
04/10/18 11:36 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
I do. Getting ready to pour five quarts of Mobil I 0W-30 AFE in my 04 Camry V6.Nothing wrong with Mobil I 5W-30. Very good product.
Re: Why not just use 0w oils? [Re: hatt] #4722660
04/10/18 11:48 AM
04/10/18 11:48 AM
NJ, USA
NJ, USA
Probably nothing discernible
Re: Why not just use 0w oils? [Re: racin4ds] #4722665
04/10/18 11:53 AM
04/10/18 11:53 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Ahh yes, this bovine excrement again. I see you don't tire of rolling this steaming wheelbarrow load out whenever the chance presents itself smirk
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Why not just use 0w oils? [Re: OVERKILL] #4722678
04/10/18 12:02 PM
04/10/18 12:02 PM
PimTac Offline
PimTac  Offline
Yep it’s just shark meat for the sharks. The “My brand is better than yours” argument is just plain childish.
Re: Why not just use 0w oils? [Re: OVERKILL] #4722711
04/10/18 12:28 PM
04/10/18 12:28 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Yeah, except it is partially true ...
Page 1 of 4 1 2 3 4
