TRW calls for TES389/TES295 fluid for their THP 60 steering box. Truck is a 2006 Freightliner M2
https://www.trwaftermarket.com/globalass...1-june-2016.pdf
I am currently using Mobil Multi Vehicle ATF
https://mobiloil.com/en/automatic-transmission-fluid/multi-vehicle-atf
It meets Dex III, which is what was originally specified for this box
Mobil Dex VI does not list TES389 as a spec it meets.
https://mobiloil.com/en/automatic-transmission-fluid/dexron-vi-atf
Can Dex VI be used? Is it any way superior to the Multi Vehicle ATF, which is also a synthetic blend? Is there an issue with viton seal compatibility?
