I'm doing a drain and fill for a 2003 Suzuki XL7. I believe it's a 4sp Aisin 03-72LS. It's spec'd for Dex 3. Dex 5 is apparently backwards compatible although lower viscosity. The vehicle in in a very cold climate half the year, - 40c/-40f so a good synthetic would help a lot. Low Viscosity not necessarily a bad thing.
MotoMaster used to sell a Dex 3 and a Dex 5 ATF. It appears they still sell a Dex 3, but the Dex 5 is gone from shelves. Probably they don't want to pay licensing for "Dexron 5"? The product that appears to have replaced it is:
Which by the MSDS is made by Irving, likely their Transflo Multi-Vehicle https://www.irvingoil.com/sites/default/files/2023-09/TRANSflo LV_ENG.pdf.
Assuming it is, that product is licenced Dex 5.
Or, use MM Dex 3. Or Transmax Full Syn or Maxlife. After 2 or 3 drain and fills, on the last one, I'll add Lubegard Red.
Thoughts?
General PDP Template
www.canadiantire.ca
Thoughts?
