Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
37 registered (BusyLittleShop, bbhero, carviewsonic, Charlie2015, 2015_PSD, 2 invisible), 1002 Guests and 36 Spiders online.
65282 Members
67 Forums
285682 Topics
#4659290 - 02/07/18 05:06 PM Benefit to D1G2 in older vehicles?
RonRonnster Offline
Loc: Idaho
First, let me define "older vehicles" - any multi-port injected vehicle older than 2010ish. I have been noticing that the red bottle MaxLife and most other syn-blend or conventional type oils don't meet the Dexos 1 Gen 2 certification - barring some exceptions. I know that a big reason for the Gen2 spec was protection against LSPI in DI engines. According to the GM marketing machine, it also provides these benefits (pulled from the ACDelco site):
"Advantages of dexos1 Gen 2 Full Synthetic Engine Oils:
Helps maintain maximum fuel economy
Reduces sludge and improves engine cleanliness
Significantly reduces low speed pre-Ignition
Offers superior wear protection
Reduces turbocharger deposits
Improves oxidation control
Is a Full synthetic oil without the full synthetic price."
So back to my original question - If I'm a regular user of these types of oils, should I care that red bottle MaxLife (or similar) doesn't meet the Gen2 spec in a non-DI vehicle? Personally, I'm running full syns at the moment, but I've used the high-mileage blends in the past. If I'm considering this type of oil for my older vehicle, is there a tangible benefit to the upgraded Gen2 formulations, or is it just marketing fluff?
- 2007 GMC Yukon XL Denali - 6.2L / 81k mi.
- 1998 Chev K1500 4x4 - 5.7L / 155k mi.
#4659298 - 02/07/18 05:15 PM Re: Benefit to D1G2 in older vehicles? [Re: RonRonnster]
JustN89 Offline
Loc: DFW
It's not all marketing fluff, but you shouldn't worry about running MaxLife (or other HM brands) in any engine not specified to run d1g2.
#4659493 - 02/07/18 08:28 PM Re: Benefit to D1G2 in older vehicles? [Re: RonRonnster]
oil_film_movies Offline
Loc: MN
Valvoline MaxLife full synthetic is dexos1 Gen2. LSPI prevention, sure, yet dexos1 Gen2 also has new timing chain wear tests and oxidation tests.
Its progress. A tougher spec than before. Proven better oil thru tests.
