Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
I'm on a Lawn Boy jag
by andyd. 09/18/18 01:13 PM
Old (New) Tires
by ET16. 09/18/18 12:05 PM
iOs 12 for Apple
by madRiver. 09/18/18 12:01 PM
Synthetic oil overrated??
by Ablebody. 09/18/18 12:01 PM
Ferrari Monza SP 1/2
by DeepFriar. 09/18/18 11:58 AM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
102 registered members (2004tdigls, alcyon, ArrestMeRedZ, 08z06, 2015_PSD, 69Torino, 12 invisible), 1,752 guests, and 34 spiders.
Topics290,612
Posts4,847,423
Members66,004
Most Online3,590
Jan 24th, 2017
Great video on lubrication engineering #4640726
01/20/18 10:00 AM
01/20/18 10:00 AM
Mississippi
Deerslayer Offline OP
Mississippi
Re: Great video on lubrication engineering [Re: Deerslayer] #4640761
01/20/18 10:25 AM
01/20/18 10:25 AM
Indiana
Indydriver Offline
Indydriver  Offline
Indiana
Well, I made it through six minutes. I think I got the gist of his experience: thinner provides better protection due to quicker circulation on start-up. What did he talk about for the other 38 minutes?
2014 Camaro 2SS/RS LS3 Vert 14,000 M1
2012 Sienna 79,000 M1
2007 Tahoe 140,000 PP
Re: Great video on lubrication engineering [Re: Deerslayer] #4640766
01/20/18 10:30 AM
01/20/18 10:30 AM
Mississippi
Mississippi
He covers quite a few more topics in the other 38 minutes of video
Re: Great video on lubrication engineering [Re: Indydriver] #4640897
01/20/18 12:42 PM
01/20/18 12:42 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Which is wrong. As long as the oil is pumpable, each rotation of the oil pump moves the same volume of oil regardless of viscosity.
Itís physics. Thinner oil does not magically make a positive displacement pump increase pumping capacity.
Now in the cold, a thinner oil could have less resistance to flow, thus making it easier to start. But the thin oil takes the same amount of time to fill the galleries as the thicker stuff
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: Great video on lubrication engineering [Re: Deerslayer] #4641231
01/20/18 07:03 PM
01/20/18 07:03 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
I nearly turned it off at the startup wear/flow , but sat through it.
I give him a solid 7.5/10.
It IS worth a listen provided you weed out a couple of those things, and also note that he's talking racing.
Some pearls that the average BITOGer needs to understand, and he makes the point.
* NASCAR run 20s, to reduce friction/make power. it's not just a retrofit into older small blocks, it was enabled by the technology to microfinish parts.
* clearances and oil pressures on the big ends and rods, versus viscosity, and failures in early adopters of thin.
* Viscosity index is good...provided you can get there without VII.
* Cams and pston ring life is additive dependent.(*)
* Drag cars on 0W5, NASCAR on 0W20, dirt track on 20W50 in addition to the above have different operating regimes, and cooling...that needs to be taken into account.
(*) He's a bit fixated on flow, but again in the context of different forms of racing, he's got some points, particularly related to valvetrain.
* some racing series have multiple heats and small number of laps...his premise is that volume flow rate to the cams is important there.
* Valve spring and rocker arm life (in series with stock rockers) has to do with cooling, which he equated with flow, but then goes on to explain that front left valve gear get trashed in circle track. My take there is the flow up the pushrod is the same for each of those locations, it's the amount of pooling that's giving the cooling effect...more flow might help 'though.
Re: Great video on lubrication engineering [Re: SilverFusion2010] #4641240
01/20/18 07:11 PM
01/20/18 07:11 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Yep, that's one of the holes in his presentation, the statement multiple times about the oil getting there quicker, and 70% of wear is at startup, and the statement that residual oil doesn't help.
But he nearly gets there when talking about side leakage and oil pressure.
There's clearly a difference, and certainly more so on cold oil...enough to make a difference when running the ragged edge of spring pressures and cam profiles ?
maybe
But again, it's the warmup phase, not the gallery filling time that he uses a few times.
Re: Great video on lubrication engineering [Re: Shannow] #4644595
01/24/18 04:32 AM
01/24/18 04:32 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
The picture of the Ferrari F1 car is precious, too. Joe Gibbs annual oil revenues are probably less than what Shell pays to the Ferrari team for sponsorship. wink
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Great video on lubrication engineering [Re: SilverFusion2010] #4644700
01/24/18 08:21 AM
01/24/18 08:21 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
It’s physics. Thinner oil does not magically make a positive displacement pump increase pumping capacity.
Well not according to this video which has been shown several times. This is the extreme side of cold and vis, but the point is thinner oils flow to the top end quicker than thicker oils. Engine test starts about the 5 min mark.
https://www.youtube.com/watch?v=OWiQyR7PWII
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Great video on lubrication engineering [Re: tig1] #4644703
01/24/18 08:29 AM
01/24/18 08:29 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Ahhh, the old tig1 wheelout of oils at and beyond the limits of pumpability...how many times ???
Why do you keep wheeling THIS out ???
Re: Great video on lubrication engineering [Re: Shannow] #4644704
01/24/18 08:29 AM
01/24/18 08:29 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Are you not really advanced (i.e 1978) AI ???
Re: Great video on lubrication engineering [Re: Shannow] #4644712
01/24/18 08:43 AM
01/24/18 08:43 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
[quote=tig1]Well not according to this video which has been shown several times. This is the extreme side of cold and vis, but the point is thinner oils flow to the top end quicker than thicker oils. Engine test starts about the 5 min mark.
It simply shows the time lag with oil flow to the upper end of an engine, at least for me. Again this demo is at the extrems of oil wt and temp. I get that, but I have experienced this myself in my own engines many years ago in -20F temps using 10-40 oils. Thanks for asking.
Gerald
M1 0-20 EP
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Great video on lubrication engineering [Re: tig1] #4644715
01/24/18 08:49 AM
01/24/18 08:49 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Gerald
Yeah, but the quoted video was about starting and racing engines under various conditions, NOT about starting an engine 30F below it's rated temperature range.
Wasn't it ?
Re: Great video on lubrication engineering [Re: Deerslayer] #4644994
01/24/18 02:30 PM
01/24/18 02:30 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
I was referring to SilverFusion's comment and the Esso video, nothing to do about the OP's video. Sorry you were confused.
M1 0-20 EP
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Great video on lubrication engineering [Re: tig1] #4645112
01/24/18 04:31 PM
01/24/18 04:31 PM
Garak Offline
Garak  Offline
Note that SilverFusion2010 pointed used the qualifier, "[a]s long as the oil is pumpable...." In the video in question, one of the oils was not pumpable.
Re: Great video on lubrication engineering [Re: Garak] #4645201
01/24/18 06:17 PM
01/24/18 06:17 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Note the video I provided compared 0-30 synthetic to 10-30 dino(lots of wax in the oil) and was pumpable at 6:40-7:00 or so. Normally folks claim 10-30 dino flows(pumpable) great even at very cold temps. Not sure what you mean one of the oils was not pumpable?
M1 0-20 EP
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
