Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
33 registered members (bbhero, 4WD, bmod305, Bjornviken, anndel, billt460, 4 invisible), 497 guests, and 57 spiders.
Topics286,266
Posts4,905,501
Members67,589
Most Online2,967
Mar 10th, 2019
0w20 vs 0w30 #4634182
01/14/18 03:33 AM
01/14/18 03:33 AM
Maryland
2000Trooper Offline OP
Maryland
I havn't been able to find a whole lot of information on 0w20 and 0w30. Seems like people stick to either 20wt or 30wt per their manual and anything in regards to 20wt vs 30wt is a can of worms with the two sides fighting. I dont want this thread to turn into a [censored] show. Per my manual 0w20 is recommended, but I can use 30wt as well. I've been using 5w30, but with recent cold temperatures in the single digit Fahrenheit I get a lot of knocking/tapping sounds from the engine during cold start up for a good minute or two. As far as these kinds of cold temperatures go will 0w20 flow/pump better or 0w30. I know both oils have a 0w rating but I am comparing apples to oranges. If it helps the 0w30 oil will be Mobil 1 since it seems to be the only one with the ILSAC GF-5 rating, and the 0w20 would be a Toyota Genuine oil. I'm not trying to get into a whole debate about 20 vs 30 oil or why I'm using 30 weight oil. So if we could stick to facts I'd appreciate it.
Re: 0w20 vs 0w30 [Re: 2000Trooper] #4634185
01/14/18 03:44 AM
01/14/18 03:44 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
A bit hard to comment since TGMO has very little data out there.
The sounds that you are experiencing in single digit F temperatures should not be affected by either 0W20, 0W30, (or 5W30 really)...possibly the fact that things in general are colder.
Re: 0w20 vs 0w30 [Re: Shannow] #4634186
01/14/18 03:53 AM
01/14/18 03:53 AM
Maryland
Maryland
When temps get into high teens I dont experience these sounds. Maybe it's the specific 5w30 I'm using? I'm currently running ACDelco 5w30 full synthetic, I'll soon be at 5k and I'm going to switch to pennzoil ultra platinum. I'll see if I have the issue with the PUP. I ran the ACDelco stuff since it's labeled as full synthetic and costs me $3.67 USD a quart. I am planning on getting the used oil tested so that should be interesting.
Re: 0w20 vs 0w30 [Re: 2000Trooper] #4634211
01/14/18 05:31 AM
01/14/18 05:31 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
It's almost certainly not something related to your oil choice. Teens F 5W is fine. 0W will flow better at any sub-freezing temperature, but it's not absolutely necessary at moderate below freezing temps. Whatever you are experiencing, it's either normal or there is something else wrong.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: 0w20 vs 0w30 [Re: Johnny2Bad] #4634213
01/14/18 05:34 AM
01/14/18 05:34 AM
'Stralia
'Stralia
No it won't.
Re: 0w20 vs 0w30 [Re: 2000Trooper] #4634217
01/14/18 05:49 AM
01/14/18 05:49 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I think something else is going on there if the engine is making " knocking/tapping sounds" sounds for a minute or more. I'd start by trying a different oil filter and getting some oil pressure readings if the filter doesn't help. Single digit temps are not that cold for a 5W30 oil. I can see some ticking or tapping for a couple of seconds during a cold start depending on engine design, and how long the vehicle sat. A minute or more imo involves further investigation. I'd start with the items I mentioned.
God Bless Our Troops
Re: 0w20 vs 0w30 [Re: demarpaint] #4634232
01/14/18 07:16 AM
01/14/18 07:16 AM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
My lady's Camry certainly did sound different in 6F than say at 30F. I have Valvoline Maxlife Full Synthetic 5w30 in there. And at that low of a temp the car was much more loud and clattering than I have noticed at temps in the 20s or 30s. Granted it lasted a bit then after that it was sounding like normal. There's just something different about starting some vehicles at less than 10F that makes them sound a fair amount different than temps above that.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: 0w20 vs 0w30 [Re: bbhero] #4634255
01/14/18 08:17 AM
01/14/18 08:17 AM
Texas
Dallas69 Offline
Dallas69  Offline
Texas
I think the filter is the cause of most noises at really cold starts.
2009 Galant-ultra oil and filter
1987 Ford F-150 302
Smittys 5-30
Motorcraft filter
Re: 0w20 vs 0w30 [Re: 2000Trooper] #4634267
01/14/18 08:38 AM
01/14/18 08:38 AM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Or incorrect oil grade wink
Re: 0w20 vs 0w30 [Re: 2000Trooper] #4634377
01/14/18 10:17 AM
01/14/18 10:17 AM
Florida
Artem Offline
Artem  Offline
Florida
I know most on here will say, "ha! You call 10F cold? Try -58F for a change", blah blah blah but the fact of the matter is, metals shrink and expand with temp and the colder it is, the more it effects the internals and externals of the engine parts. Clearances can be WAY OFF and until it warms up and expands back to spec, "SOME" can experience excessive engine noise during this period.
My Mazda 3 has been raised in FL since 3 miles on the clock and every time some cold front comes thru, the engine sounds WAY different during cold start at say, 30s F vs the typical 60F let alone how it sounds during "cold start" when it's 95F outside in the morning.
@2000Trooper, you can definitely try a 0w20 but I honestly doubt much will change. If anything, the new oil could be helping to lower startup noise and you could probably get the same result by pouring in new 0w30 or even 5w30.
I think there's nothing you can do in such temps except to deal with it until it warm back up or get a engine block heater.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: 0w20 vs 0w30 [Re: 2000Trooper] #4634461
01/14/18 11:20 AM
01/14/18 11:20 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: 2000Trooper
As far as these kinds of cold temperatures go will 0w-20 flow/pump better or 0w-30?
For all practical purposes, there should not be any SIGNIFICANT differences between the two.
Re: 0w20 vs 0w30 [Re: 2000Trooper] #4634483
01/14/18 11:38 AM
01/14/18 11:38 AM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
What car is this for?
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: 0w20 vs 0w30 [Re: 2000Trooper] #4634551
01/14/18 12:23 PM
01/14/18 12:23 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Why not just use 0w20 all the time since your car recommends it? Thats what I would do. Like the others, I dont think it will solve your problem. What filter are you using?
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: 0w20 vs 0w30 [Re: 2000Trooper] #4635164
01/14/18 10:04 PM
01/14/18 10:04 PM
Maryland
Maryland
I'm using OEM toyota filters(YZZD1), and I made the jump from 0w20 to 5w30 because I drive the engine hard both in regards to speed and over sized tires.
Re: 0w20 vs 0w30 [Re: 2000Trooper] #4635182
01/14/18 10:28 PM
01/14/18 10:28 PM
New Braunfels
Bryanccfshr Offline
Bryanccfshr  Offline
New Braunfels
Which is what Toyota says to do in the owners manual.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
