Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
86 registered members (ARCOgraphite, Bailes1992, billt460, BamaE92, andyd, 12 invisible), 1,740 guests, and 67 spiders.
Topics286,446
Posts4,908,449
Members67,626
Most Online2,967
Mar 10th, 2019
15 GTI EA888/ Castrol 5w40/ 9458mi #4624566
01/05/18 08:17 AM
01/05/18 08:17 AM
NC
swaggerwagon Offline OP
NC
Another UOA on the GTI. Silicon went up, I did clean the air filter probably halfway through the OCI (APR Carbonio Intake). Have been driving on some salty roads lately.
Might make a switch to Motul/LM and see if they hold up a little more as far as viscosity. Thoughts?
Re: 15 GTI EA888/ Castrol 5w40/ 9458mi [Re: swaggerwagon] #4624619
01/05/18 09:18 AM
01/05/18 09:18 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Fuel dilution is causing viscosity drops, however metal wear rates are normal.
Agree with lab OCI could be extended further.
Re: 15 GTI EA888/ Castrol 5w40/ 9458mi [Re: swaggerwagon] #4624673
01/05/18 10:11 AM
01/05/18 10:11 AM
Florida
Artem Offline
Artem  Offline
Florida
A magnetic oil drain bolt should do WONDERS for that iron count, in my honest opinion.
Weird why viscosity is taking a beating. Could just be the oil not holding up to the abuse. 10k looks like a good place to call it quits but it is "technically" possible to go longer, if you want.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: 15 GTI EA888/ Castrol 5w40/ 9458mi [Re: zeng] #4624682
01/05/18 10:20 AM
01/05/18 10:20 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I guess the whole oil thing is the parts were kept seperated by the oil. We jack around runnng after some number or the latest article we find to read whether fact of internet fiction, but in the end it is the bottom line of keeping the parts seperated.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 15 GTI EA888/ Castrol 5w40/ 9458mi [Re: swaggerwagon] #4624700
01/05/18 10:33 AM
01/05/18 10:33 AM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
Thanks for posting this! My GTI has the same engine, and so far I've been using the same oil. I am only at 12k miles, but have been changing at 5k intervals. At 15k I was planning on doing a UOA. Do you drive your GTI fairly hard with that tune?
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1995 Mustang GTS
Re: 15 GTI EA888/ Castrol 5w40/ 9458mi [Re: swaggerwagon] #4624785
01/05/18 11:40 AM
01/05/18 11:40 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
That engine uses a cast iron engine block which may explain the iron count?
Me: 13' VW GTI 3 door 6 speed manual
Re: 15 GTI EA888/ Castrol 5w40/ 9458mi [Re: Artem] #4625091
01/05/18 04:26 PM
01/05/18 04:26 PM
NC
NC
It's a weird plastic drain plug VW uses. I used an extractor on this OCI.
I think 10K is fine too, especially since that is the VW recommended OCI
Re: 15 GTI EA888/ Castrol 5w40/ 9458mi [Re: swaggerwagon] #4625092
01/05/18 04:26 PM
01/05/18 04:26 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Good zinc at 1020 ppm and a nice retained TBN of 3.6 after ~ 9,500 miles.
Viscosity at ~ 10.5 is now in the 30 grade range. I'm guessing fuel dilution.
I'm with Artem above, you could go further, but why bother, 10k miles seems a good time to change the oil.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 15 GTI EA888/ Castrol 5w40/ 9458mi [Re: HemiHawk] #4625095
01/05/18 04:28 PM
01/05/18 04:28 PM
NC
NC
My wife daily drives it and she is not a tortoise. I think the fuel dilution is a result of the short commute to work/cold weather start ups.
Car has seen its fair share of road trips, whenever I drive, I like to get on it. We don't baby it.
