OVERKILL
$100 Site Donor 2021
Originally Posted By: PimTac
Something else to ponder here; if a spec sheet for a oil says its pumping limit is -35F for example that doesn’t mean the oil will follow that spec to exactly -35F. I’m guessing there might be some variance in oil batches and so on. So you could have temps at -25F and that oil will be having difficulties. It is not an exact science.
I may be be wrong but is not the variance around 10%?
The spec sheets don't indicate pump limits, they indicate, if provided, the viscosity results at the predefined testing temperatures for the Winter designation the oil claims. A 5w-30's MRV is tested at -35C/-31F. There is no guarantee that it doesn't gel just a few degrees below that. It failed the 0w-30 designation either on CCS or MRV, which is why it isn't branded as such.
Performance also degrades in service, and IIRC (and Shannow can correct me if I'm wrong) but an oil is allowed to slip a W-rating over its service life.
