44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
5w30 vs 5w40 Mercedes E220 BLUETEC
by Costas00. 01/17/19 09:56 AM
Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
115 registered members (Alfred_B, 97prizm, abs, aircooled, Andy636, anndel, 12 invisible), 2,197 guests, and 48 spiders.
Topics296,732
Posts4,957,858
Members66,960
Most Online2,577
Jan 14th, 2019
Page 1 of 5 1 2 5
SJ replacement? #4622205
01/02/18 08:48 PM
01/02/18 08:48 PM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
Hey all
I am aware that the current SN is insufficient for a flat tappet motor like my small block (1985) BUT what about ďmodernĒ cars? I may swap my 2002 ES300 (SL if I remember correctly) for a 2001 LS430. Thatís SJ for sure, and a relatively high performance v8. Something feels funny about running sn blindly looking for some info. I change every 3k and usually use whatís API SAE certified and on sale. Currently working on a 7 gallon box of Partsmaster 5w30 full synthetic. I guess itís made by valvoline?
Anyway, would love to hear feedback on whatís best for 20 year old cars
Re: SJ replacement? [Re: Drew1987] #4622207
01/02/18 08:50 PM
01/02/18 08:50 PM
Chicago, IL
dparm Offline
dparm  Offline
Chicago, IL
By definition, the newer API spec is backward compatible for a vehicle requiring an older API spec.
In other words: a car that was made 20 years ago calling for API SJ can use API SN without any ill-effects. SN meets/beats all SJ requirements.
2017 Chevrolet Corvette Grand Sport
Re: SJ replacement? [Re: Drew1987] #4622224
01/02/18 09:07 PM
01/02/18 09:07 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Originally Posted By: Drew1987
.... a 2001 LS430. Thatís SJ for sure,.. and I usually use whatís API SAE certified and on sale.
Are you worried that new SN oils won't protect as well as a good API "SJ" would?
Re: SJ replacement? [Re: Drew1987] #4622318
01/02/18 10:49 PM
01/02/18 10:49 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Just add some stp to it so the old engine can have some nastalga. Lol!
Re: SJ replacement? [Re: Drew1987] #4622399
01/03/18 03:31 AM
01/03/18 03:31 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
Just to be absolutely clear, the technical basis on which the API makes these all encompassing, 'backwards compatibility' claims are tenuous to the point of being non-existent!
Are Group II/III SN oils more resistant to oxidation than a Group I SJ oil? Definitely yes, but is a Group II/III SN 5W20 better on tappet wear than a Group I SJ 10W30? I'm personally not so sure about that.
It all revolves around the role of ZDDP in the respective oils. Back in the day, ZDDP was added to Group I primarily as an Antioxidant with its Anti-wear properties sort of coming as a freebie (albeit a necessary one). Again back in the day, supplementary Antioxidants (hindered phenols & phenylenediamines which are routinely used today) were viewed as overly expensive, which put 'extra' pressure on oil formulators to max out on ZDDP to carry the oil over the line in SJ's oxidation-related engine tests.
One should also be aware that as we have moved from SJ to SN, changes in the specs have impacted on the chemical nature of ZDDPs used in oil. Today, you need to meet specified requirements for 'phosphorus volatility' which just didn't exist in the days of SJ. This has moved some companies to shift to 'heavier', less volatile ZDDPs. This is all fine and dandy until you factor in that the so-called 'activation temperature' of the ZDDP has increased and your low temperature wear protection has directionally been compromised.
In direct answer to the OP's question, in a very old car, if I couldn't readily find SJ oil, I'd use an SL oil in preference to an SN one and I would definitely not 'go thinner'. If you are truly concerned about wear, then a splosh of extra ZDDP wouldn't go amiss either.
Re: SJ replacement? [Re: Drew1987] #4622417
01/03/18 04:58 AM
01/03/18 04:58 AM
South OZ
KL31 Offline
KL31  Offline
South OZ
I'd listen to SonofJoe on this one. SN has reduced ZDDP limits.
Some modern oils, for example my favorite to grab on special here in Australia is Castrol Edge 5W30 A3/B4. It has many great approvals like MB229.5, ACEA A3/B4 and LL01 but it's "only" SL rated. This is because they have have used more ZDDP than the API SN allows. They didn't use more to make the oil worse.
So as suggested, a recent oil with recent euro approvals but only SL API rating is likely to have increased ZDDP levels and could very well be far superior to something that just has API SN approval only.
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
Re: SJ replacement? [Re: Drew1987] #4622426
01/03/18 05:29 AM
01/03/18 05:29 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
And bear in mind, the phos driver has been applied to all cars to allow inordinate "normal" oil consumption on a handful of cars that should have been fixed under warranty/recall to meet mandated emissions systems longevity.
As always, SoJ brings some great insights to the thread
Re: SJ replacement? [Re: Drew1987] #4622482
01/03/18 07:27 AM
01/03/18 07:27 AM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
Thanks all Thatís what I was worried about frown Iím talking about a 2001 Lexus LS430 i may even trade for my 2002 Es300. Ls has 146,000 already so the ďdamageĒ would already be done. This is pure insanity that oil isnít as protective as it was when 20 years ago. I wish someone would make a catalytic safe additive (not a fan of additives usually) that brings SN to a little better standard.
For my flat tappet smallblock, I use $8.20 per quart Brad Penn Green Oil which is 2000ish ppm zink and great for antiques. I so badly wish there was something at Walmart or one of the candy stores (autozone) that was $20/5qt jug that would be ok, but other than maybe diesel 15w-40, I donít think there is.
Same with the Lexus (Lexi?) either of them will see 28,000 miles per year with me, $8/quart oil may not seem a lot of money but things add up when your a family of 4 conservatively living in one income. I know thatís personal but it sheds some light on why this maters to me.
I use 89 octane in our Honda 3.5. 91+ in tne Lexus 3.0. Always seek out the original equipment but not from the dealer. Like Denso and Aisin. So Iím not cheap, but after I find whts best, I look for the best price on that
Re: SJ replacement? [Re: Drew1987] #4622755
01/03/18 01:27 PM
01/03/18 01:27 PM
Waco, TX
Waco, TX
Brad Penn has a lot of zinc (ZDDP) but is missing a LOT of other additives that a normal passenger car motor oil needs. It is most certainly NOT designed for long oil change intervals.
Did you know too much ZDDP is actually a BAD thing?!?!?!
Valvoline VR1 Racing oil has a lot of zinc. So does Pennzoil racing oil.
Re: SJ replacement? [Re: Drew1987] #4623176
01/03/18 09:27 PM
01/03/18 09:27 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Rotella t4 meets SM even though it doesn't claim it and has 1150ppm zinc iirc. M1 0w-40 also has high zinc. SN allows more zinc with the heavier grades so move up to a 5 or 10w-40
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: SJ replacement? [Re: Drew1987] #4623286
01/04/18 12:14 AM
01/04/18 12:14 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Note, too, that it does depend on spring pressures, as well. A lot of older flat tappet engines are surviving out there, just that they don't have an aggressive profile.
For those who want to pay, of course, there are ZDDP enhanced oils out there. Some are semi-affordable, others are nuts, and there are additives. Valvoline VR1 10w-30 might be one of the simplest options out there.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: SJ replacement? [Re: Linctex] #4623308
01/04/18 01:40 AM
01/04/18 01:40 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
I'd dispute this argument that too much ZDDP is a bad thing. It's reputed that too much ZDDP causes corrosion. Maybe once upon a time, in the dim and distant past, when ZDDP was the ONLY additive in oil & when ZDDPs were 'under-based' it might have been true; but not now.
When oil formulators set about putting together an oil, ZDDP is probably THE additive you want to use most of. It has both anti-wear & antioxidant properties. It's also fantastic at reducing TEOST deposits and has much overlooked load bearing properties. To cap it off, it's dirt cheap and relatively simple to manufacture. The only reason you don't use more of it is because the specs physically prevent you from doing so because of concerns about catalyst poisoning (personally I think the cat poisoning thing is overdone and reflects the fact that Americans have in the past been far too tolerant of engine oils with stupidly high Noack volatilities).
Most of the oils I put together typically contained between 800 - 1000 ppm Phosphorus (around 0.9 to 1.1% ZDDP) but I would have had no qualms whatsoever in using double that amount. Of course there's a secondary argument to be had about whether high levels of ZDDP are economically sensible. Most additives tend to conform to the Law of Diminishing Returns and ZDDP is no exception. You get far more performance bang for the buck by going from zero to 0.1% ZDDP than you do from going from say 0.9% to 1.0% ZDDP. Going from 1.9% to 2.0% ZDDP might give you so little incremental performance that it becomes more sensible to consider adding another type of additive (like going from zero to 0.1% Moly).
Re: SJ replacement? [Re: Drew1987] #4623343
01/04/18 04:57 AM
01/04/18 04:57 AM
South OZ
KL31 Offline
KL31  Offline
South OZ
Most oil formulations won't go too silly either with ZDDP, probably not in their best interests to murder engines. Even specialty oils here like Penrite racing have 2200ppm of zinc (combined total with boron included in stated amount). Nothing too drastic.
It seems to pop up around here that too much ZDDP is bad. Never is an amount given when these discussions are running. SonOfJoe, can there be a harmful amount? And forget about cat poisoning, they're like $200 maybe $300 to replace with aftermarket, less if you DIY and fail less than things like starter motors, alternators, water pumps, which can cost far more. Just interested in actual engine related issues that can arise from ridiculous levels of zddp?
Re: SJ replacement? [Re: KL31] #4623349
01/04/18 05:10 AM
01/04/18 05:10 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
KL31,
the only stuff that I've ever been able to find is a kind of intergranular cracking/stress corrosion cracking process that lets cam material spall from the faces.
I think that's the corrosion reference, but a bit misplaced.
(for example, in the high temperature metals at work, we have to choose marking pens, NDT chemicals and antisiezes that are free of low melting point metals and chlorine...they get into the grain boundaries and upset the apple cart).
Re: SJ replacement? [Re: SonofJoe] #4623351
01/04/18 05:16 AM
01/04/18 05:16 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Always good to have you around Joe.
Like many Australians I've been raised on Penrite oil, and their HPR-30, which has been very popular for decades here, contains 1450 ppm Phos and 1570 ppm Zinc. If this was causing an engine problem you would have thought somebody would have noticed in the last 30 or 40 years. I think this is close to double the ILSAC limit.
To add to your list above of what ZDDP brings to an oil, not only is it an antioxidant to protect the oil and an anti-wear to protect the metal, it's also strongly quenches LSPI events in modern TDI engines. It's effect is exponential, so a little bit more has a big effect in stopping Low speed preignition.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Page 1 of 5 1 2 5
