I like to change my own oil and have found drain valves facilitate a clean change. Doing some research I came across the Stahlbus Oil Change Valve. I like the clean look and simple design so I went ahead and ordered/installed one to replace my oil drain plug. It has a copper o-ring gasket that is torqued to 15 ft lbs, a screw on cover and quality construction.
After changing my oil recently i was impressed with it's ease of use. I was able to drain the oil into two empty gallon water jugs easily and without a mess for recycling. I prefer to drain oil straight into gallon jugs with screw on tops that don't leak, like most of the designed oil change containers do. Just drop them off at Autozone & I'm good to go, with nary a drop of oil spilled.
i highly recommend the Stahlbus Oil Drain Valve.
