AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
64 registered members (2003f7, Aero540T, 2010Civic, agpatel, alphadog, Aichiguy, 4 invisible), 1,281 guests, and 61 spiders.
Topics286,439
Posts4,908,173
Members67,622
Most Online2,967
Mar 10th, 2019
Suzuki Swift Sport engine oil #4588765
11/29/17 01:07 PM
11/29/17 01:07 PM
Finland
puliukk0 Offline OP
puliukk0  Offline OP
Finland
Hello, thanks for awesome site!
Some (stupid?) questions:
I got fantastic little Suzuki with 1.6L 16 valve m16a 92kw/136hp 7200rpm redline, timing chain, 11.1:1 comp ratio engine...
Suzukis first fill is something 0w-20 (for emission, older model with same engine had 5w-30), service manual is very broad/vague for oil specs. Anything from a 0w-20 all the way to a 20w-40 and everything in between from SG to SM classification!
Our (Finland) Suzuki service uses Mobil 1 ESP 5W-30.
I changed oil even it was changed 5000km (3000miles) ago (because you never know buying used cars), i put my work places Liqui Moly 4200 (5w-30, and Liqui say that this is for my car)
We got here -20c to +25c (-4 to 77f) so im using 5w-30 oils at least winter.
Im going some track days at summer, im just asking is there really any REAL benefit to use 40 weight oil couple track days?
Or any harm use M1 5w-30 ESP/Liqui Moly 4200 oil at gasoline car, with or without track days?
Should i buy something else?
Or am i just little paranoid? These are rare cars on here, so i dont want to kill it. laugh
I normally use older engines (usually turbos) with M1 0w-40, nothing problem with that... smile
Im thinking running max 12 months or max 7500km (5000miles) per oil change (stock is 12month/15 000km/10000miles), seems to be about 2 oil changes per year.
Tell me your opinion or knowledge. Thanks much. smile
Re: Suzuki Swift Sport engine oil [Re: puliukk0] #4588768
11/29/17 01:10 PM
11/29/17 01:10 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
welcome to BITOG!
'18 Dodge Grand Caravan GT - 26k KM - AMSOIL SS 0w20
'06 Hyundai Santa Fe - 535k KM AMSOIL SS 0w30
Re: Suzuki Swift Sport engine oil [Re: puliukk0] #4588841
11/29/17 01:58 PM
11/29/17 01:58 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
You guys have M1 D1 5W30 ESP?? I'm pretty jealous! Based on my experience with M1 D1 5W40, I would just run it all the time and use oil analysis to determine how often to change it.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Suzuki Swift Sport engine oil [Re: bullwinkle] #4588877
11/29/17 02:15 PM
11/29/17 02:15 PM
Finland
puliukk0 Offline OP
puliukk0  Offline OP
Finland
It seems to be 100% same as USA's "M1 5W30 ESP", its called Mobil 1™ ESP Formula 5W-30 in here.
Heres link to europe/english mobil site: http://www.mobil1.co.uk/synthetic-engine-oils/esp-formula-5w-30.aspx?tabs=specifications#tabs
If somebody wants to know datasheet of Liqui Moly 4200 here is it: https://pim.liqui-moly.de/pidoc/P000323/3706-TopTec42005W-30-33.0-en.pdf
Re: Suzuki Swift Sport engine oil [Re: puliukk0] #4588878
11/29/17 02:16 PM
11/29/17 02:16 PM
South OZ
KL31 Offline
KL31  Offline
South OZ
Mobil 1 0w40 would work good for cold winter and some track days. Is on the thin side of 40 too so it will be fine. The M1 0W40 can go to 10000 miles easily in most cases. You could run it for the full 12 months and 10k miles. The only thing to consider is the track days and you may change oil earlier if you do quite a few.
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
Re: Suzuki Swift Sport engine oil [Re: bullwinkle] #4588880
11/29/17 02:18 PM
11/29/17 02:18 PM
New England
Virtus_Probi Offline
New England
I don't think the OPer is talking about a Delvac oil, M1 5W30 ESP seems to be common in Europe and largely targeted to diesel passenger cars that are much more common there than in the US.
I have used that ESP oil in my DIT engine and thought maybe my gas mileage dropped just a bit compared to plain ol M1 5W30, the ESP product is pretty thick at 100C for a 5W30 and also has a high HTHS for that grade (3.58?). Given that level of high temp protection as well as a low NOACK loss of around 6%, maybe it is a good choice for track use?
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: Suzuki Swift Sport engine oil [Re: puliukk0] #4588892
11/29/17 02:26 PM
11/29/17 02:26 PM
Finland
puliukk0 Offline OP
puliukk0  Offline OP
Finland
Ah sorry, i didnt see that "D1". Yes Delvac oil are here pretty "rare" in here. Only used at semi-trailer trucks and big Mercedes vans. Delvac is marketing here as "truck (semi-trailer) oil".
So yes, we use ESP not Delvac in here.
Maybe i go tomorrow to local shop to buy Mobil ESP, its seems to be better than Liqui Moly, HTHS is 3.58 vs 3.5.
HTHS is the thing what i need, if im right? Thanks for fast answers smile
Re: Suzuki Swift Sport engine oil [Re: puliukk0] #4589077
11/29/17 05:38 PM
11/29/17 05:38 PM
PimTac Offline
PimTac  Offline
There is not really much difference at all between 3.58 and 3.5. Use whichever is less expensive and or more readily available.
Congrats on the new Suzuki. Those are great cars with excellent engines.
Cannot see signatures any longer so it doesn’t matter.
