Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
jmd, alexislaborda, tbann, LisaMC, chops
67556 Registered Users
127 registered members (AandPDan, 53' Stude, 28oz, 928, 2015_PSD, 10 invisible), 2,240 guests, and 56 spiders.
Topics286,076
Posts4,902,070
Members67,556
Most Online2,967
Mar 10th, 2019
Which Lubegard, if at all? #4586127
11/26/17 10:02 PM
11/26/17 10:02 PM
Southeast
BlakeB Offline OP
BlakeB  Offline OP
Southeast
I'm gonna start using Valvoline Maxlife ATF in my 2007 Tacoma with the A750F transmission. I currently have a mix of WS and Maxlife in there, but will be doing an annual drain/fill with Maxlife. I've heard a lot of good things about Lubegard, but I'm not sure which kind to use. There are 2 types as far as I'm aware, the regular red stuff and the LG Platinum. Which one should I use with the Maxlife, if I should even use it at all?
If you have any success or failure stories as far as lubegard goes, I'd like to hear it. I'm not sure if it's even necessary but some absolutely swear by the stuff.
My truck has 83K miles, tranny was flushed around 60k, then drained and filled at about 80k. The fluid that's in there looked and smelled perfect when I drained/filled it in April. I also have a remote spin on filter installed, its a 10 micron hydraulic filter(napa 1269). I changed it after 20k(60-80k) and it had minimal debris in it. I have a thread in the transmission filter subforum, if you wanna see the filter cut open.
Re: Which Lubegard, if at all? [Re: BlakeB] #4586152
11/26/17 10:25 PM
11/26/17 10:25 PM
North Dakota
mphilleo Offline
mphilleo  Offline
North Dakota
I've had more luck with Lubegard Red than not. Mostly, I've used it on older cars running Supertech DEX III with the intention of fortifying it, with good results. The only outlier is a '93 Olds 98 where I noticed issues with slippage after using it. But that could have been an issue waiting in the wings. Since Maxlife is fully synthetic now, and no longer a blend, I don't see a huge benefit to using it if you've fully replaced your ATF. Doubly so if you have a transmission cooler besides the one in your radiator (tow package, self-installed).
Re: Which Lubegard, if at all? [Re: BlakeB] #4586167
11/26/17 10:54 PM
11/26/17 10:54 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
Use the Lubegard Red.
It is more aligned with your situation than the extra modifiers in the platinum.
I would also drain the PS reservoir at the same time and top it up with fresh atf and an ounce of the Lubegard - good maintenance. I have seen real rsults from using Lubegard in various places, engines (the biotech) too. The ester technology is not snake oil.
Re: Which Lubegard, if at all? [Re: Oro_O] #4586190
11/26/17 11:32 PM
11/26/17 11:32 PM
Southeast
BlakeB Offline OP
BlakeB  Offline OP
Southeast
The PS has been flushed 4 or 5 times, the fluid is in good shape, but the rack and pinion is starting to seep a little, just enough to wet the bottom of the boots. It's been seeping for 4 or 5 years, but I don't have to add fluid between flushes so I'm not gonna replace it until it's actually leaking. This isn't our road trip vehicle anymore and I rarely take it more than a couple hours from home. Lately I've only been putting about 5k miles per year.
Re: Which Lubegard, if at all? [Re: BlakeB] #4586200
11/26/17 11:58 PM
11/26/17 11:58 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
In that case, I would add more Lubegard to the ps reservoir. The esters could help the seals in the rack. Or use some of their ps fluid in lieu of atf in it.
Re: Which Lubegard, if at all? [Re: BlakeB] #4586203
11/27/17 12:07 AM
11/27/17 12:07 AM
Texas
4WD Offline
4WD  Offline
Texas
Was looking at a bottle at AZ ~ then I said: “self ~ you have a drain plug and a shelf full of synthetic Dex VI”-
So, is this any better than doing an extra 4 quart drain/fill in addition to my annual Fram XG16 change?
(8 quarts this year instead of the normal 4 quarts)?
Re: Which Lubegard, if at all? [Re: BlakeB] #4586239
11/27/17 03:45 AM
11/27/17 03:45 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Lubegard red for that application.
God Bless Our Troops
Re: Which Lubegard, if at all? [Re: 4WD] #4586247
11/27/17 04:13 AM
11/27/17 04:13 AM
Southeast
BlakeB Offline OP
BlakeB  Offline OP
Southeast
That's kinda my dilemma as well, I'm not sure if it really makes any difference. I already have fresh fluid in there, which is more than most people can say. I don't wanna mess with the frictional characteristics of the fluid much, this truck is used to tow and haul a lot of the time. My transmission runs way on the cool side, usually not more than 130°F, 185° or so towing in the summer, 200°F tops. The truck is short tripped daily though, less than a mile with several stops in-between, so if the lubegard would help protect the solenoids and valvebody from excessive wear from all of the starting and stopping that would be a plus.
Re: Which Lubegard, if at all? [Re: BlakeB] #4586358
11/27/17 09:32 AM
11/27/17 09:32 AM
Michigan
khittner Offline
khittner  Offline
Michigan
Save some money and save your anxiety for something more important. Your tranny will be as good as you're likely to need it to be, for as long as you need it to be, if you just use the MaxLife ATF, and change it periodically, like every 30K. Every "tough guy" with a truck, doing "tough-guy truck stuff" thinks their use of the tough truck meets or exceeds whatever the tough guys in the commercials for "taking-care-of-tough-trucks stuff" are doing to theirs. Probably not.
Re: Which Lubegard, if at all? [Re: BlakeB] #4586379
11/27/17 09:51 AM
11/27/17 09:51 AM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
I've got maxlife and LG platinum in my Tacoma. No ill effects in nearly 30K miles.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Which Lubegard, if at all? [Re: BlakeB] #4586396
11/27/17 10:08 AM
11/27/17 10:08 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: BlakeB
The truck is short tripped daily though.... protect the solenoids and valvebody from excessive wear from all of the starting and stopping that would be a plus.
This is absolutely of no consequence.
"short tripping" is harmful to ENGINES..... not transmissions.
Re: Which Lubegard, if at all? [Re: BlakeB] #4586397
11/27/17 10:08 AM
11/27/17 10:08 AM
Texas
4WD Offline
4WD  Offline
Texas
Do you know what your filter micron rating is … I find having a drain plug and external filter (superior to the pan filter) makes things very quick/easy once it is set up . My filter case catches some good airflow too …
Re: Which Lubegard, if at all? [Re: BlakeB] #4586419
11/27/17 10:25 AM
11/27/17 10:25 AM
Rainville, USA
JEL01 Offline
JEL01  Offline
Rainville, USA
Yep skip it, those are stout transmissions and 30-40k drain and fills are all they need to outlive the body of the truck
Cars I maintain:
02 MB CLK430-Edge 0w40
05 Honda Accord V6-Maxlife 5w30
13 Lexus RX350 AWD-M1 AFE 0w20
02 Toyota Tundra 4x4 M1 5w30
Re: Which Lubegard, if at all? [Re: 4WD] #4586630
11/27/17 02:41 PM
11/27/17 02:41 PM
Southeast
BlakeB Offline OP
BlakeB  Offline OP
Southeast
10 micron nominal, beta ratio 2/20=5/17
Re: Which Lubegard, if at all? [Re: Linctex] #4586643
11/27/17 02:56 PM
11/27/17 02:56 PM
Southeast
BlakeB Offline OP
BlakeB  Offline OP
Southeast
I disagree, transmissions need more frequent maintenance if they have a severe duty cycle, which Allison specifies as more than one stop per mile. I have 3-4 stops per mile minimum a lot of the time. I recognize that my transmission isn't an Allison, but they are a reputable mfg of a similar piece of equipment. My average speed is around 13 MPH. More shifts does equal more wear, it has to.
https://www.kwds.at/fileadmin//user_upload/Downloads/Service/FluidIntervals-Allison.pdf
