Originally Posted By: slacktide_bitog
Originally Posted By: ST2008
If I were you, I would replace the valve cover gasket. It's very easy to replace it and the gasket is very cheap. You can find lot of DYI video in Youtube.
Are you kidding? The valve cover gaskets are almost IMPOSSIBLE to replace on the 1MZ and almost any transverse V6
If you do replace them, get either Beck/Arnley or Mahle/Victor Reinz. Either brand will be reboxed OEM gaskets. While you're back there, replace the spark plugs and wires. Get NGK wires, and Bosch Platinum Ir Fusion spark plugs. I know a lot of people don't like Bosch, but the 1MZ uses special 2-prong double plugs, and in a transverse V6 with no cutouts for the back plugs without complete disassembly, iridium is a
MUST! And the only multi-prong iridium made for the 1MZ is the Bosch Platinum Ir Fusion (it has 4 prongs, which should be fine). Iridium should last at least 100k, whereas platinum is only good for 60k.
Holy [censored]! You're [censored] right! I did some search and it is a suicide mission to replace the valve cover gasket in this engine. This convinces me to never buy a V6 engine car.
