Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
27 registered members (BlakeB, Bailes1992, Camprunner, 77GrandPrix, 10WSmuckers, 3 invisible), 807 guests, and 35 spiders.
Topics290,867
Posts4,851,561
Members66,044
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
0w30 or 5w30 for 0w20 specked car #4540625
10/11/17 08:23 PM
10/11/17 08:23 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
Planning on going grade higher on the next oil change. Not sure either go 0w or 5w. As far as start up temp iím Not concerned as I live in TX. Looks like 5w has better NOACK compared to 0w so this is plus. What would you suggest folks?
2016 Honda Pilot 3.5V6 PP 0W20
2017 Honda Civic 1.5T Amsoil SS 5W30
Re: 0w30 or 5w30 for 0w20 specked car [Re: parshisa] #4540634
10/11/17 08:27 PM
10/11/17 08:27 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
2004 Corolla 124805
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: 0w30 or 5w30 for 0w20 specked car [Re: JohnnyJohnson] #4540643
10/11/17 08:32 PM
10/11/17 08:32 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
That is 20 weight, not 30
Re: 0w30 or 5w30 for 0w20 specked car [Re: parshisa] #4540650
10/11/17 08:38 PM
10/11/17 08:38 PM
MN
oil_film_movies Offline
MN
Any 5w30 full synthetic you see at Walmart will do. dexos1 Gen2 is better, which many are going to anyway.
Re: 0w30 or 5w30 for 0w20 specked car [Re: parshisa] #4540660
10/11/17 08:46 PM
10/11/17 08:46 PM
Wet side WA
Wet side WA
So you ran 20 weight all through the hot Texas summer but now with winter coming you want to switch to 30?
Can you share your logic with us? Are your cars using oil?
2004 Corolla 124805
2006 Duramax 74277
Re: 0w30 or 5w30 for 0w20 specked car [Re: parshisa] #4540669
10/11/17 08:53 PM
10/11/17 08:53 PM
New Mexico, USA
jimbrewer Offline
jimbrewer  Offline
New Mexico, USA
Prius manual says you can go to 5w-20 instead of 0W-20 assuming it is still fancy-pants oil in an emergency and only for one change. If it's that bad, why would they let you use it even once?
Re: 0w30 or 5w30 for 0w20 specked car [Re: parshisa] #4540670
10/11/17 08:54 PM
10/11/17 08:54 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Go for 10w-30 for lowest NOACK. In TX 0, 5, 10w is all the same
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: 0w30 or 5w30 for 0w20 specked car [Re: parshisa] #4540677
10/11/17 09:00 PM
10/11/17 09:00 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Until upwards of 200K I'd be running 5w20 unless I was working the engine real hard, even in the heat. I've done recurring maintenance on four different J35A6/7's and with three of the four over 160K they give no feedback that the 5w20 I put in them is too thin.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: 0w30 or 5w30 for 0w20 specked car [Re: JohnnyJohnson] #4540681
10/11/17 09:03 PM
10/11/17 09:03 PM
Danh Offline
Danh  Offline
I think the OP has discovered there is a fuel dilution issue with one or both of his Hondas and a 30 weight oil might offset some of the viscosity dilution.
Re: 0w30 or 5w30 for 0w20 specked car [Re: JohnnyJohnson] #4540683
10/11/17 09:03 PM
10/11/17 09:03 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
No need to seek for the logic. Just want to go higher on vis. Winter is not a concern, this is TEXAS
Re: 0w30 or 5w30 for 0w20 specked car [Re: Danh] #4540686
10/11/17 09:05 PM
10/11/17 09:05 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
FD is definitely a concern. I also want to see if the engine will sound better - metal sound makes me aick
Re: 0w30 or 5w30 for 0w20 specked car [Re: Danh] #4540694
10/11/17 09:24 PM
10/11/17 09:24 PM
Buffalo, NY
Nickdfresh Offline
Nickdfresh  Offline
Buffalo, NY
Good thing you spoke for him. Anything else you want to tell us about him?
Re: 0w30 or 5w30 for 0w20 specked car [Re: Nickdfresh] #4540703
10/11/17 09:30 PM
10/11/17 09:30 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
Looks like weíre getting biased here. Ok, yes thereís fuel dilution, and yes I want to try to offset it some. Yes, engine sounds a bit [censored] to my taste, hope thicker oil will do better job with that regard. Thatís it. Back to initial question: would 0 or 5 make a difference? Personal previous experience supported by UOA is appreciated
Re: 0w30 or 5w30 for 0w20 specked car [Re: parshisa] #4540711
10/11/17 09:36 PM
10/11/17 09:36 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
I'd stick with 0W20 for your Honda. Try Pennzoil Platinum 0W20.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 5W20
Re: 0w30 or 5w30 for 0w20 specked car [Re: parshisa] #4540713
10/11/17 09:40 PM
10/11/17 09:40 PM
Buffalo, NY
Nickdfresh Offline
Nickdfresh  Offline
Buffalo, NY
Except the UOA in question didn't show ANY fuel dilution...
Page 1 of 3 1 2 3
