suprise
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
Bad cylinder 3 misfire.
by Hemispheres. 12/14/18 02:49 PM
Small leak at toilet base - bad wax ring?
by Oro_O. 12/14/18 02:38 PM
Ok I take it back about Keurig
by StevieC. 12/14/18 02:29 PM
Edge 5W-30 7.9k miles '13 F150 5.0
by dustyroads. 12/14/18 02:11 PM
Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
wsalopek, jcr1293, maxwellk, BlueFog, Frank_G35
66682 Registered Users
79 registered members (2strokeNorthstar, AZjeff, 10ecfarmer, 86lxjunker, atikovi, Ag76, 11 invisible), 1,613 guests, and 40 spiders.
Topics295,081
Posts4,927,415
Members66,682
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
new truck oil change #4533187
10/03/17 05:21 PM
10/03/17 05:21 PM
Missouri
hardheaded Offline OP
Missouri
getting ready for the first oil change on new 17 chevy truck. what does everyone think of going with 5- 20 compared to the recommended 0-20 ? the 5-20 has higher levels of phosphous and boron compared to the 0-20.
Re: new truck oil change [Re: hardheaded] #4533189
10/03/17 05:23 PM
10/03/17 05:23 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Unless you're running it unusually hard I believe the consensus on pretty much all the new 0w20-spec engines is that it won't hurt them... but neither will 5w20.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: new truck oil change [Re: hardheaded] #4533192
10/03/17 05:30 PM
10/03/17 05:30 PM
FL
HappyLittlePony Offline
FL
The difference between a 5w20 and a 0w20 is minor. They recommend the 0w20 because, at a minimum, the 0w20 is at least a synthetic blend. I'd rather have a good 0w20 synthetic than a 5w20 conventional.
Re: new truck oil change [Re: hardheaded] #4533199
10/03/17 05:37 PM
10/03/17 05:37 PM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
Yep, 0w-20. It's they way to go. Make sure it's a DEXOS approved oil.
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
Re: new truck oil change [Re: hardheaded] #4533205
10/03/17 05:48 PM
10/03/17 05:48 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Having to use a special oil in Chevy's has taken them right off my buy list!
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: new truck oil change [Re: JohnnyJohnson] #4533214
10/03/17 05:58 PM
10/03/17 05:58 PM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
So no BMWs, Mercedes Benz's, VWs or Audi for you (JUST THE SHORT LIST). Sorry that your auto purchases are strictly limited to API Specs. Your life must be excruciatingly boring.
Re: new truck oil change [Re: hardheaded] #4533399
10/03/17 09:04 PM
10/03/17 09:04 PM
MT
jongies3 Offline
jongies3  Offline
MT
Don't go off the specs if you want to keep your warranty. Dexos is important to GM and it will void your powertrain warranty if they catch ya using the wrong grade in it.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM TG-3600 filter
1969 Mustang Mach 1 5.8 V8: PYB 10W-30 Napa Gold 1515 filter
1997 Ford F-250 HD 7.3 Powerstroke V8: T6 5W-40 FRAM PH-3786 filter
Re: new truck oil change [Re: hardheaded] #4533434
10/03/17 10:25 PM
10/03/17 10:25 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
At op temp they are both 20's ... What's the point of the change?
Re: new truck oil change [Re: hardheaded] #4533503
10/04/17 05:39 AM
10/04/17 05:39 AM
PENNSYLVANIA
Crobinson16 Offline
Crobinson16  Offline
PENNSYLVANIA
I have been trying to decide the same thing. I have been looking at running either a 5w20 or 5w30 in Mobil EP for my new 2017 5.3 silverado. I believe the noack of both are better which I gather is important on these new direct injection motors. Also from what I gather the the 5-30 is so close to the 5-20 it really won't make a difference. I have considered looking at a 0-30 but not sure if Mobil makes a 0-30. Plus it probably has a bunch of VI modifers and that would make the noack go up? My old 6.2 silverado I used Mobil 0 40 both flavors. It ran great.
I do believe these new ecotec motors are a little different. Till someone or myself gets inside one completely to check any kind main or rod bearing clearance nobody knows for sure.
Re: new truck oil change [Re: hardheaded] #4534904
10/05/17 07:04 PM
10/05/17 07:04 PM
PENNSYLVANIA
Crobinson16 Offline
Crobinson16  Offline
PENNSYLVANIA
I was hoping some of the experts would chime in. I certainly am not.
Re: new truck oil change [Re: hardheaded] #4535507
10/06/17 02:23 PM
10/06/17 02:23 PM
Missouri
Missouri
the only reaso i was going to go with the 5-20 was because it has higher levels of the anti-wear stuff in them. at mobil does. i think some of the reason for the thinner oils has to do with the valve timing and displacement on demand engines.
Re: new truck oil change [Re: hardheaded] #4535667
10/06/17 05:52 PM
10/06/17 05:52 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
The only valid reason I can think of to select a 5W- over a 0W- would be for lower NOACK.
There aren't too many places in the contiguous US where the 0W qual would matter, so the hunt for lower NOACK would maybe make a 5W qual oil a good choice.
Check out the very good UOAs on the PQIA site and see whether the 5W-20 syns exhibit lower NOACK volatility than the zeros. They probably will.
You could do a whole lot worse than selecting an oil based upon lower NOACK with any DI engine.
In the very unlikely event of a warranty claim involving the engine, you'd just say that you used any major brand twenty that had the dexos logo and leave it at that.
Unless the oil has obviously never been changed, you'll be fine.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: new truck oil change [Re: JohnnyJohnson] #4535732
10/06/17 07:28 PM
10/06/17 07:28 PM
Utah
CKN Offline
CKN  Offline
Utah
That....and the new diesels are not like the old ones (DEF, and $70,000)
Re: new truck oil change [Re: JohnnyJohnson] #4535820
10/06/17 09:24 PM
10/06/17 09:24 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
You pretty much have to or will have to use a special oil in anything new these days.
Re: new truck oil change [Re: jongies3] #4535865
10/06/17 11:32 PM
10/06/17 11:32 PM
Central Iowa
TiredTrucker Offline
Central Iowa
My Chevy manual does not say dexos is required, only recommended. And there are several TSB's out that state that if dexos1 is not available, then a synthetic of same viscosity is ok to use and will not void warranty. I rarely have followed any OEM's guidelines to the very letter on any engine I have owned. In the ball park, but not exactly. And I have never had a warranty concern.
And 0w20 and 5w20 are the same viscosity. There is no appreciable way that a dealer or GM themselves could tell the difference if they analyzed it. And I have not heard of one dealer analyzing anyone's oil. Even for warranty purposes. I have had warranty work done on many engines, both personal and commercial business vehicles, in almost 50 years and no dealer or OEM shop has even asked me about the oil, let alone tested it. And I have never had to produce a single documented piece of evidence of oil changes, and I have not personally heard of anyone having to. This all is a scare tactic to keep folks in line. I am sure it could happen in the most extreme of situations if the oil was like goo and the engine seized up.
The OP is from Missouri. A 5w20 would work just fine for that application, year round. Actually, the argument could be made very effectively that 5w20 could be a better idea, given the AFM design of those engines and the significantly lower NOACK of a 5w20 compared to 0w20 within the same brand and type of oil.
Some folks just worry too much.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Page 1 of 3 1 2 3
