Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
06/17/18 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
06/17/18 05:18 PM
Car Sales Scammers on Letgo
by ZZman
06/17/18 04:18 PM
Air shocks or Timbren for trailer towing ?
by Oldtom
06/17/18 04:10 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
72 registered (bismic1, alphadog, AVB, Buzzinhalfdozen, 12 invisible), 1310 Guests and 40 Spiders online.
65258 Members
67 Forums
285500 Topics
Page 1 of 2 1 2 >
#4511519 - 09/09/17 12:30 PM 1996 F150 Water pump replacement
terry274 Offline
Loc: TN
While changing the oil in my 1996 Ford F150 I noticed coolant dripping off the frame. This is a 302 V8 with 133,000 miles. I bought the truck used and I believe the water pump was changed in 2014 at 110,000 miles. (According to the Carfax I received)
The leak is NOT coming from the weep hole. It appears to be from the gasket itself. Researching this particular job indicates a problem with the bolts seizing into the timing chain cover and breaking when removal is attempted. The leak may be coming from the timing chain cover.
I just took another look, and I am 90% sure the timing chain cover is the source of the leak. This appears to be a Big Job.
Does anyone have any pointers?
1996 Ford F150
2012 Honda Accord
2009 Ford Taurus
#4511534 - 09/09/17 12:44 PM Re: 1996 F150 Water pump replacement [Re: terry274]
bdcardinal Offline
Loc: Santa Barbara, CA
Don't break the bolts. Some are obsolete and the ones still available cost more than the truck is worth. Dorman does make some of them.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#4511535 - 09/09/17 12:45 PM Re: 1996 F150 Water pump replacement [Re: terry274]
Chris142 Online   content
Loc: Deplorable in apple valley, ca
You will need a pulley puller to get the balancer off. The timing cover is likely corroded and will need to be replaced.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4511538 - 09/09/17 12:54 PM Re: 1996 F150 Water pump replacement [Re: terry274]
Merkava_4 Offline
Loc: Clovis, CA
Consult the factory service manual for the procedures. Don't try to go in blind.
#4511572 - 09/09/17 01:47 PM Re: 1996 F150 Water pump replacement [Re: terry274]
Linctex Offline
Loc: Waco, TX
I did it on my 1996 Explorer 5.0 engine, the harmonic balancer needed to come off.
#4511609 - 09/09/17 02:48 PM Re: 1996 F150 Water pump replacement [Re: terry274]
terry274 Offline
Loc: TN
Ok, I've been reading up on this and I am getting ready to tackle the job. I just placed an order with RockAuto:
I am hoping to be able to reuse the timing cover.
I still need to line up a harmonic balance puller.
1996 Ford F150
2012 Honda Accord
2009 Ford Taurus
#4511621 - 09/09/17 03:06 PM Re: 1996 F150 Water pump replacement [Re: terry274]
Originally Posted By: terry274
Ok,
mine came from harbor freight 20+ yrs ago.
#4511638 - 09/09/17 03:30 PM Re: 1996 F150 Water pump replacement [Re: terry274]
9050lx Offline
Loc: FL
You may want to replace the balancer while its off,rubber around the steel can slip, should be 50 ounce imbalance.May also do a timing chain while in there.
#4511675 - 09/09/17 04:35 PM Re: 1996 F150 Water pump replacement [Re: 9050lx]
andyd Offline
Loc: Marshfield , MA
I'll give you the balancer, but the chain should be fine. grin2
Thick oil is better grin2
#4511684 - 09/09/17 04:47 PM Re: 1996 F150 Water pump replacement [Re: terry274]
Merkava_4 Offline
Loc: Clovis, CA
I don't know why anyone would want to work on a car without the service information; makes no sense to me.
#4511691 - 09/09/17 04:53 PM Re: 1996 F150 Water pump replacement [Re: Merkava_4]
terry274 Offline
Loc: TN
I do indeed have the factory manual on CD. I was just asking for pointers as to what to watch for or common problems not covered in the manual. Such as broken water pump bolts.
I am considering changing the timing chain set, but I plan on waiting until I have it apart to inspect the old chain.
1996 Ford F150
2012 Honda Accord
2009 Ford Taurus
#4511694 - 09/09/17 04:56 PM Re: 1996 F150 Water pump replacement [Re: 9050lx]
terry274 Offline
Loc: TN
The harmonic balancer is over $200 at RockAuto. It's not getting replaced if I can keep from damaging the original one.
1996 Ford F150
2012 Honda Accord
2009 Ford Taurus
#4511701 - 09/09/17 05:00 PM Re: 1996 F150 Water pump replacement [Re: terry274]
SubieRubyRoo Offline
Loc: Winchester, Indiana
Use an air wrench or small impact to remove the bolts. Typically the quick shock will break the corrosion free without snapping the heads off... ask me how I know frown
The $200 is more than 50% of the way for a high-quality balancer; the factory rubber ringed ones are junk when they were new. Make sure you get a double roller timing set and it should be the last time you need to open the front of the engine.
#4511702 - 09/09/17 05:01 PM Re: 1996 F150 Water pump replacement [Re: terry274]
Merkava_4 Offline
Loc: Clovis, CA
I wish you would've said that in the first place. I get anxiety attacks whenever someone starts asking for information without having a service manual.
#4511705 - 09/09/17 05:06 PM Re: 1996 F150 Water pump replacement [Re: Merkava_4]
terry274 Offline
Loc: TN
Sorry blush
1996 Ford F150
2012 Honda Accord
2009 Ford Taurus
Page 1 of 2 1 2 >
