Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
06/17/18 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
06/17/18 05:18 PM
Car Sales Scammers on Letgo
by ZZman
06/17/18 04:18 PM
Air shocks or Timbren for trailer towing ?
by Oldtom
06/17/18 04:10 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
72 registered (bismic1, alphadog, AVB, Buzzinhalfdozen, 12 invisible), 1310 Guests and 40 Spiders online.
65258 Members
67 Forums
285499 Topics
#4508621 - 09/06/17 12:19 AM HP Laserjet won't print
berniedd Offline
Loc: A Warm place to live in
The 6 year old Samsung printer died so I got a new HP M102 Laserjet for my Linux desktop. It didn't come with Linux drivers for the Lubuntu 14.04 LTS (10 yr old machine with 2.4 GHz procie and 2 GB RAM). So I downloaded a third party driver - hplip - and it installed without issue.The system shows the new printer is installed as the default printer and shows its icon with a fat green check mark. But if I try to print anything, the printer's green online LED starts to blink (indicating data transfer is ongoing) but doesn't do anything else. Doesn't even pull the bond paper into the machine. After a minute the LED blinking stops and the LED now glows steadily. No error messages are displayed.
I thought maybe it needs a more updated OS so I installed a more recent Lubuntu release: 16.10 version. But I got the same no go situation. I asked an IT guy for help and he suggested use the Terminal functiob and with the printer on and the desktop connected to the internet, type: sudo apt-get install cups, then press <enetr>. It downloaded a bunch of things but still no joy.I still get the same printer behavior and no print. What to do next?
I know it's not the printer at fault because I tried it on a Windows machine and it works fine there.
#4508659 - 09/06/17 02:28 AM Re: HP Laserjet won't print [Re: berniedd]
Dave9 Offline
Loc: Cincinnati, USA
This is why a free OS hasn't taken over the world by storm, that it "kinda" works and "maybe" things like hardware drivers work, but maybe not.
It seems fairly clear, you need to make a windows box your print server... unless you just enjoy running against the wind.
I'm no microsoft fan, but it is what it is. It's an example of why I find it annoying that MS manipulated the market and screwed consumers with a lasting effect over 20 years later.
#4508671 - 09/06/17 03:19 AM Re: HP Laserjet won't print [Re: berniedd]
Brad_C Offline
Loc: Perth, Western Australia
hplip is one of those unpleasant bits of software that has to be "just so". It *is* the "official" HP driver for Linux, but like most drivers written by manufacturers it's quite brittle. Unless you are compiling from scratch you seem to always need exactly the right versions to make it work. Cups is generally much nicer if it supports your printer.
Not much help, but before I buy hardware I always have a poke around to see how well it is supported. HP printers are usually pretty good but printing and scanning can be pretty fragile unless you know your way around the subsystems.
Oddly enough a quick search shows loads of people having issues with that model on Windows also. Again, brittle vendor drivers requiring just the right versions.
Is it too late to pack it up and return it?
#4508683 - 09/06/17 04:44 AM Re: HP Laserjet won't print [Re: berniedd]
alex_at Offline
Loc: Vienna, Austria
in the hplip software, I think it's in the last tab, make sure your printer is not stopped. That happens from time to time, at least on my machine with openSuse and a HP Color Laser.
#4508686 - 09/06/17 05:01 AM Re: HP Laserjet won't print [Re: Dave9]
Subdued Offline
Loc: Youngstown, NY
On the contrary, HP is well supported, but that printer in particular is plagued with driver issues, on a Linux OS AND Windows.
I have an old Laserjet Pro 1102w that works great with both cups and hplip.
2015 Jeep Cherokee 18k
2008 Chrysler Town & Country Touring 149k
2007 Toyota Yaris S 170k
#4508857 - 09/06/17 09:31 AM Re: HP Laserjet won't print [Re: berniedd]
mk378 Offline
Loc: USA
Return it and buy a Brother HL-L2340D. If you have an Ethernet network consider the 2360 or 2380. All have excellent Linux compatibility though you will need to plug the USB into a Windows machine or go through a bunch of menus to set up the wifi on the 2340.
#4519937 - 09/19/17 01:19 AM Re: HP Laserjet won't print [Re: berniedd]
Garak Offline
Loc: Regina, Saskatchewan, Canada
First thing I would try is delete the printer while it's plugged into the PC, then add it back in manually. That worked perfectly for plug and play for my older HP, in both Ubuntu and Mint, and got rid of a couple minor issues. Of course, your printer may be different. There is an HP site that lists functionality for their various printers when it comes to Linux.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
