New car wax score
by Marco620. 01/16/19 02:42 PM
Bought a used Cherokee Trailhawk
by Sunnyinhollister. 01/16/19 02:34 PM
Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
116 registered members (4WD, 53' Stude, 28oz, 2004tdigls, 2002 Maxima SE, 10 invisible), 2,214 guests, and 35 spiders.
Topics296,645
Posts4,956,535
Members66,950
Most Online2,577
Jan 14th, 2019
Page 1 of 3 1 2 3
2014 Camry, Iridium Plugs, 75,000 miles #4481605
08/07/17 08:25 AM
08/07/17 08:25 AM
Missouri, USA
Tlhfirelion Offline OP
Missouri, USA
I've always changed plugs in previous vehicles well before 100,000 miles. I always noticed an improvement in older cars in performance and at idle. It's now habit. Any 80's and 90's model vehicles get new plugs and wires every 50, 000 miles. Well, these new fandangled cars have me wondering if it's too early to change an iridium plug at 75,000 miles.
it's not an expensive venture but is it a waste? All I know about the iridiums is that they are supposedly longer life plugs, 100,000 miles according to the manufacturer. I don't believe in lifetime anything but that can be taken too far. So, whats the hive here say ?
Thank you in advance. smile have a good day!
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: Tlhfirelion] #4481608
08/07/17 08:29 AM
08/07/17 08:29 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I still have the originals in the 68k 2012 Camry. At 120k is the first big service where the spark plugs are changed out. I'd go 100-120k before changing them out. Spend the money in other places like detailing it. brake fluid flush, Throttle body clean, clean and lube all brake calipers, air and cabin filters, etc...
I'd be more tempted to have the dealer change the atf at that mileage than replacing the plugs.
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: SatinSilver] #4481611
08/07/17 08:33 AM
08/07/17 08:33 AM
Missouri, USA
Missouri, USA
This car has been a good car but the issue of not being able to do any transmission fluid changes myself grinds at me like you wouldn't believe. It was my fault for not checking that before the purchase and I may have taken a step back if I had known what that was like. Having to go to a mechanic to do a drain and fill irritates me big time. lol
The rotors will be turned and new pads put on this month along with a caliper greasing. Filters are all current, etc. Just the trans fluid and plugs is all thats needed.
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: Tlhfirelion] #4481618
08/07/17 08:40 AM
08/07/17 08:40 AM
Missouri, USA
Missouri, USA
If it matters, most of my driving is in hilly terrain at highway speeds. That little 4 banger can struggle sometimes.
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: Tlhfirelion] #4481621
08/07/17 08:43 AM
08/07/17 08:43 AM
TX
Lethal1ty17 Offline
Lethal1ty17  Offline
TX
My Genesis Coupe had the 100,000 mile Denso or NGK (can't remember) plugs in it. At 107k I measured the gap and they were almost perfect. Not much for buildup on them either.
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: Tlhfirelion] #4481622
08/07/17 08:43 AM
08/07/17 08:43 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I did have a rear driver's side caliper start to stick recently. The original brake fluid was in there plus the calipers had never been serviced. Put some new Wagner OEX ceramic pads on, new Napa reman caliper, brake fluid etc. I did have the dealer reprogram the ecu for tranny shifting issues. There is a torque converter tsb and a warranty extension to 7yrs/150k miles for a shudder tha occurs on TC lockup. As part of that service they clean the trans pan and install additonal magnets. So maybe before that expires I'll take it in and see if they will do the service/replacement.
My brother has a red 2014 Camry, no issues with it. There is a 2014.5 model that had something beefed up for the offset crash ratings.
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: Tlhfirelion] #4481623
08/07/17 08:43 AM
08/07/17 08:43 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Changed mine out at about 75k miles and saw zero difference. Will likely leave whats in for longer this time around.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: SatinSilver] #4481624
08/07/17 08:47 AM
08/07/17 08:47 AM
Missouri, USA
Missouri, USA
Mine is the 2014.5 model, SE to be exact. It did add the back up camera as standard and crash testing improved to deal with a poor offset head on rating if memory serves. Maybe I'll just leave them. I have noticed a very, very slight shudder when I first start driving the car but it goes away within a few seconds. Is there a way to drain our fluid thru the trans cooler lines or anything to avoid that contraption they have on the bottom of the transmission?
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: SatinSilver] #4481625
08/07/17 08:49 AM
08/07/17 08:49 AM
Missouri, USA
Missouri, USA
regarding brake fluid. My dads trick was to drain out the reservoir with a turkey baster every 30,000 miles and fill that same exact amount of new brake fluid in. He NEVER had brake issues and never did a flush on vehicles having 250,000 miles. I guess it would get mixed in and after a few changes you'd replace the majority of the fluid? Thats what I always do. Maybe it's insanity but it works so far.
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: Tlhfirelion] #4481628
08/07/17 08:52 AM
08/07/17 08:52 AM
MN
oil_film_movies Offline
MN
Plugs: Yes iridiums can easily go 100,000 miles +.
Since 1995, cars have had OBDII software & sensors which throw codes when misfire is detected, and it actually identifies which cylinder is misfiring.
http://www.underhoodservice.com/common-causes-misfire-codes/ if you want to read some more.
Practically, as long as all the sensors & pumps are working properly and the spark plugs are still working, the cylinder will not misfire. Therefore, I say wait until your OBDII detects a misfire before replacing your sparkplugs. Even then, if you get the codes (MIL, or Check Engine Light), it may be a plugged fuel injector causing it, so you can even try Techron gas additive at first to clear the code. In any event, you don't have to do anything on cars these days until the OBDII light comes on!
I agree with you that differential and transmission fluids should be changed every, I'd say, 75,000 miles, just to get the metal particles out. The fluid chemistry itself holds up OK.
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: oil_film_movies] #4481634
08/07/17 08:57 AM
08/07/17 08:57 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Here's a pretty good video on the atf change from a community college instructor no less:
https://www.youtube.com/watch?v=cNcecuGzTDg
It's a long video.
With the brake fluid, the nasty stuff it at the end of the line down by the caliper. So that fluid doesn't get flushed out unless the brakes are bled at the caliper or sucked out via a machine.
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: Tlhfirelion] #4481654
08/07/17 09:11 AM
08/07/17 09:11 AM
New York
pbm Offline
pbm  Offline
New York
I'm with you on the non DIY transmission...I believe it's an attempt by the manufacturers to send people to the expensive dealer service department. If I was choosing between 2 vehicles...one that I could DIY...one that I couldn't....that would be the deciding factor.
'Journalism is Dead'
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: Tlhfirelion] #4481658
08/07/17 09:15 AM
08/07/17 09:15 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
It won't hurt, it may help, may not.
Some say pull them early to reduce the chance of the plug seizing and making it harder to get out if you wait the full mileage interval. To prevent it, you could pull them early, inspect, and reinstall, but if going to that trouble, just replace them IMO.
You also have the issue of even though the plug may still be "good" and fire just fine, it can cause poorer mileage and performance.
If they are easy to get to, why not though.
I am debating doing the Scion's plugs @ 50,000 miles (still 2+ years at current driving rate) because of the timeframe.
You do not just wait for the CEL to come on. If you notice issues, there can be things going on that do not set the CEL.
Misfires take a certain number of occurrences to set the light, or even a pending code. Waiting for damage to occur before repair is not a good idea. Is it not better to replace a part before failure?
2018 Hyundai Santa Fe: Dealer oil, Mahle filter, 5k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: GTX HM 5w-20, EcoGard, 1yr
1994 Honda VT1100c: Peak 15w-40, PSL, 5k
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: SatinSilver] #4481661
08/07/17 09:17 AM
08/07/17 09:17 AM
Missouri, USA
Missouri, USA
I've seen that video and it made me mad. lol All that work when a simple drain and fill plug would be cheaper and easier. I do think like was already said on here, they do this so we are forced to take it to a dealer to get worked on.
Re: 2014 Camry, Iridium Plugs, 75,000 miles [Re: blupupher] #4481662
08/07/17 09:18 AM
08/07/17 09:18 AM
Missouri, USA
Missouri, USA
They're right on top, very easy to get too. Maybe I will change em. smile
Page 1 of 3 1 2 3
