Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
Geardaddies, 01ws666, ariefnrst, tcoffin014, Schm1d
66658 Registered Users
103 registered members (ArrestMeRedZ, andyd, Alfred_B, 28oz, 4WD, 15 invisible), 1,910 guests, and 38 spiders.
Topics294,983
Posts4,925,346
Members66,658
Most Online2,553
Oct 27th, 2018
Pennzoil Euro L 5w-30, ~2000 Miles 2013 Camaro LS3 #4444127
06/28/17 04:05 PM
06/28/17 04:05 PM
Austin, TX
Geoff Offline OP
Geoff  Offline OP
Austin, TX
Car: 2013 Chevy Camaro
Engine: V-8 6.2L LS3
Transmission: 6 speed manual
Oil capacity: 8 qts
Oil Pennzoil Platinum 5w-30 Euro L ACEA C3 Dexos2
I really like this oil. Held up well with 2 days for track use (about 200 miles at mostly full throttle). No oil consumption.
2015 Audi A3
2013 Chevy Camaro LS3/NPP
2008 Chevy Suburban
2004 Land Rover Discovery
2007 Supra 22V
Re: Pennzoil Euro L 5w-30, ~2000 Miles 2013 Camaro LS3 [Re: Geoff] #4444135
06/28/17 04:31 PM
06/28/17 04:31 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Not a very stout additive package. Then again, for a short OCI and track days no need for all that Calcium, Moly, and/or Magnesium. It wouldn't be my choice for a newer V8 Camaro but it seems to have worked fine for you.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Pennzoil Euro L 5w-30, ~2000 Miles 2013 Camaro LS3 [Re: Geoff] #4444225
06/28/17 06:19 PM
06/28/17 06:19 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
No tin, no lead = nice! I think your using the right oil.
I'm going to be a real quack job and give my personal opinion in which you should take with a grain of salt.
I'm guessing C3 and low saps oils utilize a more expensive additive(s) that doesn't show up on a UOA.
Something the oil blenders deem too costly and unnecessary to meet the specs of oils like a Dexos 1 5W30.
I'm thinking the C3 and low saps additive(s) have better anti-wear properties than of API Starburst oils.
Low saps oils are the future. Lets revisit this page in 2025 to see if I'm right.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Pennzoil Euro L 5w-30, ~2000 Miles 2013 Camaro LS3 [Re: Geoff] #4444359
06/28/17 08:35 PM
06/28/17 08:35 PM
WI.
dblshock Offline
dblshock  Offline
WI.
til they figure it all out run a W/40 specially if your beating on it like that.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Pennzoil Euro L 5w-30, ~2000 Miles 2013 Camaro LS3 [Re: 69GTX] #4444382
06/28/17 09:07 PM
06/28/17 09:07 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I think that's what GM is recommending for Camaros for track days, a dexos2 rather than a dexos1, contrary to the Vette recommendation. wink
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Pennzoil Euro L 5w-30, ~2000 Miles 2013 Camaro LS3 [Re: Geoff] #4444551
06/29/17 05:18 AM
06/29/17 05:18 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Yes it's a Dexos2 oil, so a low (or mid) SAPS Euro C3 oil. But it is a high HTHS oil with 3.5 cP or more. This is more HTHS than the regular Dexos1 oil which is about 3.1 cP.
It did it's job well and protected your engine. Look at the KV100 of 10.8 cSt after two days of hard track use, that is higher than virgin PP 5W30 (10.3 cSt). A C3 5W30 is a much stronger oil than a ILSAC 5W30.
My 2 cents. If you need an API SN 5W-30 oil, you have two main choices.
- for light duty and fuel economy, get an ILSAC GF-5 and Dexos1 oil
- for heavy duty and track work, get an ACEA C3 and Dexos2 oil
OP has the right oil for the right job.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Pennzoil Euro L 5w-30, ~2000 Miles 2013 Camaro LS3 [Re: dblshock] #4444993
06/29/17 12:41 PM
06/29/17 12:41 PM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
The VOA of Euro L 5w30 that was posted in the VOA section, was actually slighty into the 40wt range (12.63 cSt, IIRC)
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: Pennzoil Euro L 5w-30, ~2000 Miles 2013 Camaro LS3 [Re: Geoff] #4445084
06/29/17 02:17 PM
06/29/17 02:17 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Nice report. Oil is working great in your engine. No reason to fix what isn't broken.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: Pennzoil Euro L 5w-30, ~2000 Miles 2013 Camaro LS3 [Re: Brons2] #4445106
06/29/17 02:44 PM
06/29/17 02:44 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Which would make it almost the same viscosity as the newer M1 0w-40 FS (12.8 cSt).
1969 Ply GTX/RRs
Re: Pennzoil Euro L 5w-30, ~2000 Miles 2013 Camaro LS3 [Re: Geoff] #4445277
06/29/17 06:01 PM
06/29/17 06:01 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Here is a link to the PDF spec sheet for the oil
(PP Euro L 5W30)
It's listed 100C Viscosity is 12.1 cSt.
